Author Topic: shutdown button on desktop  (Read 3816 times)
Offline opiumpoetry
« on: February 27, 2019, 09:38:02 pm »
Found this little article on how to create a single-click shutdown button situated on the desktop. I tried it and it works. https://community.linuxmint.com/tutorial/view/1113
« Last Edit: March 01, 2019, 01:28:34 am by rossvassilev »
You can learn a lot from a dummy (that would be ME).:P
Re: shutdown button on desktop
« Reply #1 on: February 27, 2019, 10:57:10 pm »
 :-\ Where's the link??
Offline opiumpoetry
« Reply #2 on: March 01, 2019, 01:29:07 am »
OOPS! :D Just added it.  ;D
« Reply #3 on: March 01, 2019, 01:53:41 am »
 8)
Offline stevesveryown
  • Peppermint Fan
    • stevesveryown
« Reply #4 on: March 05, 2019, 03:23:51 pm »
I just create a launcher with the peppermint-logout command. I did one before and my wife would always seem to hit it and shut down the system while she was doing something.
Sent from my SM-G950U using Tapatalk
« Reply #5 on: March 05, 2019, 08:01:15 pm »
 :D
That's why it isn't there in the first place  ;)
« Reply #6 on: March 06, 2019, 04:44:57 am »
Yep, I've never really understood why people want either a desktop icon or a panel item to shut down .. seems to be an accident waiting to happen to me, and a waste of panel/desktop space (through duplication) .. but each to their own right :)
Offline rayzer
  • Graphics n Stuff
« Reply #7 on: March 06, 2019, 03:05:29 pm »
i have the actions buttons added to mine but iconified then set it up so only Log Out.. is selected. give you the choice to cancel or shutdown etc if accidentally hit
Offline opiumpoetry
« Reply #8 on: March 16, 2019, 07:31:17 pm »
The action buttons on my panel only had logout working, nothing else. And how do you shutdown a pc without a button? Just use the power button on the keyboard? Isn't that bad for the pc?
Offline Reddi-eng
« Reply #9 on: September 03, 2019, 06:11:28 am »
I'm new to this distro and forum.
Has ths question been answered?
« Reply #10 on: September 03, 2019, 09:10:04 am »
Hi Reddi-eng,
See the first message in this thread. It was not really a question, but more a statement about how to accomplish something (together with a link to the instructions for doing it). The other messages were mostly about the pros and cons of doing it.
And BTW: welcome to Peppermint and the forum.
« Reply #11 on: September 03, 2019, 04:17:20 pm »
There's a better solution if you really want a shutdown icon on the desktop .. or would you prefer it on the panel ?
Now we're in the systemd era I'd suggest:-
systemctl poweroffand/or
systemctl rebootis MUCH preferable to messing around the permissions of the:-
/sbin/shutdownutility, as prompted by the link in the first post here.
Neither of those require root permission, or hacking the permissions of /sbin/shutdown
« Last Edit: September 03, 2019, 04:19:28 pm by PCNetSpec »
Offline opiumpoetry
« Reply #12 on: November 18, 2019, 07:12:17 pm »
There's a better solution if you really want a shutdown icon on the desktop .. or would you prefer it on the panel?
Actually, some file managers allow you to add desktop icons to the panel, like Thunar, I think. I did that and yes, it looks better on the panel than on the desktop.
« Reply #13 on: November 19, 2019, 03:58:49 am »
You don't require Thunar (or any other file manager) to add a launcher to the xfce4-panel .. you can right-click ANY launcher in the main menu and select "Add to Panel" .. so really all you need to do is create a properly formatted .desktop file and have it in one of the correct directories, so it shows in the main menu.
There is even a way you add a launcher DIRECTLY to the panel, that contains your own command and icon.
