Author Topic: Connecting to internet only in recovery mode.  (Read 1132 times)
Offline jpm
  • Peppermint version(s): peppermint nine
« on: February 13, 2019, 09:55:38 am »
I have peppermint 9 My internet works only on recovery mode I have wifi connection. This problem has been for a while it sometimes works just fine for a day or two but now my connection is down again I'm writing this in recovery mode and I took these lists from terminal in recovery mode. should I take these also in normal boot?
lsusb
Bus 002 Device 002: ID 2232:1005 Silicon Motion WebCam SCB-0385N
Bus 003 Device 003: ID 3938:1031
Bus 003 Device 002: ID 0a5c:219c Broadcom Corp.
sudo lshw -C network
  *-network
       product: BCM4313 802.11bgn Wireless Network Adapter
       vendor: Broadcom Inc. and subsidiaries
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: wlp3s0
       version: 01
       serial: 90:a4:de:ea:57:5f
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=wl0 driverversion=6.30.223.271 (r587334) ip=192.168.1.108 latency=0 multicast=yes wireless=IEEE 802.11
       resources: irq:16 memory:fe900000-fe903fff
  *-network
       physical id: 0
       bus info: pci@0000:05:00.0
       logical name: enp5s0
       version: 06
       serial: e8:03:9a:23:10:ec
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168e-3_0.0.4 03/27/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:18 ioport:d000(size=256) memory:d0004000-d0004fff memory:d0000000-d0003fff
iwconfig
wlp3s0    IEEE 802.11  ESSID:"DNA-Mokkula-2G-G38TJB"
          Mode:Managed  Frequency:2.447 GHz  Access Point: D0:D7:83:4C:1E:FE
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
enp5s0    no wireless extensions.
ifconfig
enp5s0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether e8:03:9a:23:10:ec  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 389  bytes 40435 (40.4 KB)
        TX packets 389  bytes 40435 (40.4 KB)
wlp3s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.108  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::c8d0:414d:51bb:63ff  prefixlen 64  scopeid 0x20<link>
        inet6 fdd0:d783:4c1e:fd00:4b:4db9:b70d:59dc  prefixlen 64  scopeid 0x0<global>
        inet6 2001:14bb:440:dc9d:abae:99fb:d6ed:e0af  prefixlen 64  scopeid 0x0<global>
        inet6 2001:14bb:440:dc9d:d0d7:834c:1efd:2  prefixlen 128  scopeid 0x0<global>
        ether 90:a4:de:ea:57:5f  txqueuelen 1000  (Ethernet)
        RX packets 4841  bytes 5393136 (5.3 MB)
        RX errors 0  dropped 0  overruns 0  frame 1323
        TX packets 2965  bytes 349130 (349.1 KB)
        device interrupt 16
sudo iwlist scan
wlp3s0    Scan completed :
          Cell 01 - Address: D0:D7:83:4C:1E:FE
                    Channel:8
                    Frequency:2.447 GHz (Channel 8)
                    Quality=70/70  Signal level=-21 dBm
                    Encryption key:on
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
                              24 Mb/s; 36 Mb/s; 54 Mb/s
                    Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
                    Mode:Master
                    Extra:tsf=0000000000000000
                    Extra: Last beacon: 16ms ago
                    IE: Unknown: 0015444E412D4D6F6B6B756C612D32472D473338544A42
                    IE: Unknown: 010882840B162430486C
                    IE: Unknown: 030108
                    IE: Unknown: 2A0100
                    IE: Unknown: 32040C121860
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                    IE: Unknown: 0B050100130000
                    IE: Unknown: 46053208010000
                    IE: Unknown: 2D1AFE191BFFFF000001000000000000000000000000000000000000
                    IE: Unknown: 3D16080F1600000000000000000000000000000000000000
                    IE: Unknown: 4A0E14000A002C01C800140005001900
                    IE: Unknown: 7F080500080000000040
                    IE: Unknown: DD7A0050F204104A0001101044000102103B00010310470010D96C7EFC2F8938F1EFBD6E5148BFA81210210006487561776569102300064875617765691024000631323334353610420004313233341054000800060050F2040001101100084875617765694150100800020000103C0001031049000600372A000120
                    IE: Unknown: DD090010180201000C0000
                    IE: Unknown: DD180050F2020101840003A4000027A4000042435E0062322F00
          Cell 02 - Address: 38:60:77:9E:3C:3C
                    Channel:11
                    Frequency:2.462 GHz (Channel 11)
                    Quality=29/70  Signal level=-81 dBm
                    Encryption key:on
                    ESSID:"ec2ead"
                    Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s
                              36 Mb/s; 48 Mb/s; 54 Mb/s
                    Mode:Master
                    IE: Unknown: 0006656332656164
                    IE: Unknown: 010482848B96
                    IE: Unknown: 03010B
                    IE: Unknown: 2A0100
                    IE: Unknown: 2F0100
                        Group Cipher : TKIP
                        Pairwise Ciphers (2) : CCMP TKIP
                    IE: Unknown: 32080C1218243048606C
                    IE: Unknown: 2D1AFC181BFFFF000000000000000000000000000000000000000000
                    IE: Unknown: 3D160B080000000000000000000000000000000000000000
                    IE: Unknown: DD790050F204104A0001101044000102103B00010310470010887752E1E61A16017F387C34BDBDBA4310210005436973636F10230005436973636F1024000631323334353610420007303030303030311054000800060050F204000110110006656332656164100800022008103C0001011049000600372A000120
                    IE: Unknown: DD090010180200F02C0000
                    IE: WPA Version 1
                        Group Cipher : TKIP
                    IE: Unknown: DD180050F2020101800003A4000027A4000042435E0062322F00
          Cell 03 - Address: 84:9F:B5:A8:B8:19
                    Channel:1
                    Frequency:2.412 GHz (Channel 1)
                    Quality=48/70  Signal level=-62 dBm
                    Encryption key:on
                    ESSID:"HUAWEI BTV"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 6 Mb/s; 9 Mb/s
                              11 Mb/s; 12 Mb/s; 18 Mb/s
                    Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
                    Mode:Master
                    IE: Unknown: 000A48554157454920425456
                    IE: Unknown: 010882848B0C12961824
                    IE: Unknown: 030101
                    IE: Unknown: 0706464920010D14
                    IE: Unknown: 23021E00
                    IE: Unknown: 2A0100
                        Group Cipher : CCMP
                    IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
                    IE: Unknown: 32043048606C
                    IE: Unknown: 0B050200000000
                    IE: Unknown: 2D1A2D1117FF00000000000000000000000100000000000004060A00
                    IE: Unknown: 3D1601080400000000000000000000000000000000000000
                    IE: Unknown: 7F080000008000000000
                    IE: Unknown: DD08AC853D8201000000
          Cell 04 - Address: FA:8F:CA:53:D5:EF
                    Channel:6
                    Frequency:2.437 GHz (Channel 6)
                    Quality=26/70  Signal level=-84 dBm
                    Encryption key:off
                    ESSID:"Olohuone.m"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
                    Mode:Master
                    IE: Unknown: 000A4F6C6F68756F6E652E6D
                    IE: Unknown: 010882848B960C121824
                    IE: Unknown: 030106
                    IE: Unknown: 2A0100
                    IE: Unknown: 2D1A8D1103FFFF000000000000000000000000000000000000000000
                    IE: Unknown: 3B025100
                    IE: Unknown: 3D1606000100000000000000000000000000000000000000
                    IE: Unknown: 7F080500800000000040
                    IE: Unknown: 3B11040102030405060708090A0B0C11808182
enp5s0    Interface doesn't support scanning.
 rfkill list
0: hci0: Bluetooth
   Soft blocked: no
   Hard blocked: no
1: samsung-wlan: Wireless LAN
   Soft blocked: no
   Hard blocked: no
2: samsung-bluetooth: Bluetooth
   Soft blocked: no
   Hard blocked: no
3: phy0: Wireless LAN
   Soft blocked: no
   Hard blocked: no
4: brcmwl-0: Wireless LAN
   Soft blocked: no
   Hard blocked: no
Re: Connecting to internet only in recovery mode.
« Reply #1 on: February 13, 2019, 10:44:25 am »
Yes, run the commands when it's not working so we can see what the difference is.
Offline jpm
« Reply #2 on: February 13, 2019, 11:03:13 am »
Here is the list from normal boot.
lsusb
  *-network
       physical id: 0
       version: 01
       width: 64 bits
       clock: 33MHz
  *-network
       physical id: 0
       version: 06
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
 iwconfig
          Mode:Managed  Frequency:2.427 GHz  Access Point: D0:D7:83:4C:1E:FE
          Power Management:on
ifconfig
        RX packets 1226  bytes 93694 (93.6 KB)
        TX packets 1226  bytes 93694 (93.6 KB)
        RX packets 18  bytes 2087 (2.0 KB)
        RX errors 0  dropped 0  overruns 0  frame 154
        TX packets 158  bytes 27303 (27.3 KB)
        device interrupt 16
sudo iwlist scan
                    Channel:4
                    Frequency:2.427 GHz (Channel 4)
                    Quality=70/70  Signal level=-25 dBm
                    Encryption key:on
                    Mode:Master
                    IE: Unknown: 030104
                    IE: Unknown: 2A0100
                        Group Cipher : CCMP
                    IE: Unknown: 0B050100060000
                    IE: Unknown: 3D16040D1600000000000000000000000000000000000000
          Cell 02 - Address: FA:8F:CA:53:D5:EF
                    Channel:6
                    Quality=22/70  Signal level=-88 dBm
                    Encryption key:off
                    ESSID:"Olohuone.m"
                    Mode:Master
                    IE: Unknown: 030106
                    IE: Unknown: 2A0100
                    IE: Unknown: 3D1606080000000000000000000000000000000000000000
                    Channel:1
                    Quality=43/70  Signal level=-67 dBm
                    Encryption key:on
                    ESSID:"HUAWEI BTV"
                    Mode:Master
                    IE: Unknown: 030101
                    IE: Unknown: 2A0100
                        Group Cipher : CCMP
rfkill list
0: hci0: Bluetooth
   Soft blocked: no
   Hard blocked: no
   Soft blocked: no
   Hard blocked: no
   Soft blocked: no
   Hard blocked: no
   Soft blocked: no
   Hard blocked: no
   Soft blocked: no
   Hard blocked: no
« Reply #3 on: February 13, 2019, 05:04:18 pm »
What we a really need you to do is post those outputs from a NON working wireless .. so next time wireless doesn't work, copy the output from those commands into a text file and save it .. then do whatever you need to do to get back online .. then post the output contained in the text file.
Also, can you explain what you mean by "Recovery Mode" ?
and is your routers SSID: DNA-Mokkula-2G-G38TJB ?
And can you also post the output from:
lspci -vnn | grep -i net
Offline jpm
« Reply #4 on: February 14, 2019, 06:40:29 am »
That second post that I posted in this thread that List from "normal boot" is taken when it doesn't connect to internet. By recovery mode I mean that I select at the boot those "additional choices" (I don't know what it says in English version I'm using Finnish and it says "peppermint lisävalinnat" or something like that). And I boot my linux from the latest kernel that says (recovery mode) and when it takes me to that page where you can choose fixing broken packages etc. that first option normal start up or something like that. So my graphics are quite funky when I use my os this way but it connects to internet.
Offline jpm
« Reply #5 on: February 14, 2019, 06:43:10 am »
These are from working internet
03:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4313 802.11bgn Wireless Network Adapter [14e4:4727] (rev 01)
   Subsystem: Wistron NeWeb Corp. BCM4313 802.11bgn Wireless Network Adapter [185f:051a]
05:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 06)
   Subsystem: Samsung Electronics Co Ltd RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [144d:c589]
Offline jpm
« Reply #6 on: February 14, 2019, 06:52:02 am »
Now it just started to work again on normal boot. This really weird it works for a day or two and then it stops to work for day or two.
