Author Topic: (SOLVED) Remove Manjaro xfce?  (Read 2385 times)
Re: Remove Manjaro xfce?
« Reply #15 on: February 11, 2019, 05:09:39 am »
What pin said.
If you boot to a Peppermint USB stick (or DVD) and select "Try Peppermint", then you're in a "Live" environment.
Offline penrose1950
(SOLVED) Re: Remove Manjaro xfce?
« Reply #16 on: February 11, 2019, 05:09:49 am »
Thank you,I used a DVD to install Peppermint 9.
« Last Edit: April 05, 2019, 07:46:03 am by penrose1950 »
« Reply #17 on: February 11, 2019, 05:11:56 am »
It doesn't need to be a USB, a DVD is also a "Live" environment .. so where I said "LiveUSB" just swap that for "LiveDVD" and you'll be good :)
Offline penrose1950
« Reply #18 on: February 11, 2019, 06:04:00 am »
thank you i  have updated grub and deleted  /dev/sda2 and i have gone to gparted  but i dont know what to resize to ?
Offline penrose1950
« Reply #19 on: February 11, 2019, 06:05:32 am »
« Reply #20 on: February 11, 2019, 06:07:01 am »
Your picture is broken.
Please use an external host for your pictures, imgur for example.
Offline penrose1950
« Reply #22 on: February 11, 2019, 06:13:56 am »
« Reply #23 on: February 11, 2019, 06:16:05 am »
Still can't see it.
Can you upload it on imgur and provide a link?
Offline penrose1950
« Reply #24 on: February 11, 2019, 06:17:18 am »
« Last Edit: February 11, 2019, 06:34:47 am by PCNetSpec »
« Reply #25 on: February 11, 2019, 06:23:12 am »
I can't tell you how large you might want it.
Mark /dev/sd1 and choose Partition -> Resize.
Now, you can move the slider to the right until you're happy with the size. The press aply and wait until it finishes doing it's job.
Remember don't move the start of the partition!  ;)
Offline penrose1950
« Reply #26 on: February 11, 2019, 06:34:32 am »
thank you i have resized and this is what i have now,just got to update grub again.
http://imgbox.com/T2lZDa9l
« Last Edit: February 11, 2019, 06:35:54 am by PCNetSpec »
« Reply #27 on: February 11, 2019, 06:36:40 am »
And does the system boot now ?
If so, you're done.
If not and grub is now broken, boot back to the LiveUSB/LiveDVD and run these commands in sequence:
sudo mount /dev/sda1 /mntthen
for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; donethen
sudo chroot /mntthen
grub-install /dev/sdathen
update-grubThen hit Ctrl+D to exit the chroot environment.
and finally reboot without the LiveUSB/LiveDVD
« Last Edit: February 11, 2019, 06:43:30 am by PCNetSpec »
Offline penrose1950
« Reply #28 on: February 11, 2019, 06:45:05 am »
thank you everyone for the help i have rebooted and all back to normal.
« Reply #29 on: February 11, 2019, 06:59:13 am »
Great stuff :)
Can you please remember to mark the topic (SOLVED) .. TIA :)
