Author Topic: "Failed to send D Bus Message; No running instance of xcfe4-panel was found"  (Read 596 times)
Offline mick
  • Recovering Apple Addict
Hi i'm currently running Peppermint 9 with the XCFE desktop, but whenever i push the windows key, I get this message.  Any ideas?
thank you.
Yeah, run:
xed ~/.config/peppermint-control-center/xbindkeys.conf
find the 3 section that currently read
"xfce4-popup-whiskermenu"
    Alt+F1
    Control+Escape
    Super_L
and change them to
"lxpanelctl menu"
    Alt+F1
"lxpanelctl menu"
    Control+Escape
"lxpanelctl menu"
    Super_L
SAVE the file, then log off/on (or reboot)
That key should now open the lxpanel menu.
Offline mick
that worked perfectly.  thank you.
