Author Topic: VPN (Proton VPN) and NetworkManager: setup and maintain WiFi connection  (Read 1084 times)
Offline Timmi
  • Peppermint version(s): 6
Has anyone managed to successfully use the service on Linux while keeping WiFi intact?
Here is a link to setting up the ProtonVPN service on Linux, using NetworkManager.
https://protonvpn.com/support/linux-vpn-setup/
(I've tried both options A and B)
I have successfully created a "connection" profile in NetworkManager following their instructions.
But the problem with this, is that the new VPN connection replaces the WiFi connection.
You choose one or the other, WiFi or VPN.
I need to use it in conjunction with WiFi.
On Windoze it works fine - they set it up so that a program runs to handle your encryption and connect to the VPN, sending it all through your existing WiFi connection.
Does anyone know of a workaround, so that you can create that VPN tunnel, over your existing WiFi connection?
Whether it be WiFi at home, in the office, or at a public hotspot or café.
« Last Edit: February 09, 2019, 01:03:40 am by Timmi »
Re: VPN (Proton VPN) and NetworkManager: setup and maintain WiFi connection
« Reply #1 on: February 09, 2019, 06:10:06 am »
Do they do a free version, so I can test their instructions ?
It'll probably look that way in neworkmanager, but I'd expect them to be bridged.
Does it work with a wired connection ?
« Last Edit: February 09, 2019, 06:14:45 am by PCNetSpec »
Offline Timmi
« Reply #2 on: February 10, 2019, 11:48:03 am »
1. Do they do a free version, so I can test their instructions ?
2. It'll probably look that way in neworkmanager, but I'd expect them to be bridged.
3. Does it work with a wired connection ?
1. yes, they have a free version.
2. hmm, I hadn't thought of that.  I don't recall a command that would have created the bridge - unless resolvconf did that.
If I knew for sure that it was bridged, then I could look towards my credentials, and create another connection profile in case that server was too congested.
3. old one has iffy connector, can't rely on it.  I should go out and buy one (but just to test?)
« Last Edit: February 10, 2019, 12:20:04 pm by Timmi »
« Reply #3 on: February 10, 2019, 12:19:18 pm »
Basically yes, just as a test does it work with a wired connection but not with a wireless one ?
Offline Timmi
« Reply #4 on: February 10, 2019, 12:25:34 pm »
I'll get a cable, and get back to you.
 Thank you.
« Last Edit: February 10, 2019, 12:31:37 pm by Timmi »
« Reply #5 on: February 10, 2019, 03:48:41 pm »
IIRC, access to VPN is only available for paid accounts... I use them on my phone now, instead of gmail which is force-stopped and disabled...
Offline Timmi
« Reply #6 on: February 13, 2019, 01:58:28 pm »
It did not work with a cable either.
I guess I was on the wrong track with my original question.
(and just to clarify, I'm configuring using one of the  free servers, not one of the paid ones.  there are 4 servers in the list I used to use all the time without issue in Windoze, I know they should work well)
« Reply #7 on: February 13, 2019, 03:31:50 pm »
So you can't connect to anything using the VPN connection?
Offline Timmi
« Reply #8 on: February 14, 2019, 03:46:13 am »
Nope.
And I don't know how to figure out what I'm doing wrong.
I found a support request page, and have sent a request, to save us all some time.
Not sure if they'll provide support for the free service.  I'll keep you all posted.
