Author Topic: Can’t login after update  (Read 1811 times)
Offline mick
  • Recovering Apple Addict
« on: February 08, 2019, 01:05:17 pm »
Hello and thanks In advance for the help.  I just did sudo apt-get upgrade, and then update in terminal. After that, two bad things happened. First, I was unable to restart or shutdown my computer. When I clicked the windows key, then clicked the button to open the shutdown/restart options, I received an error message. So I manually shut down my laptop.
2.  Now when I turn on my laptop, peppermint starts, then asks for my password to log in to my account. But when I enter my pw, it says “failed to start session.”  Likewise, when I try to log in to a guest session, it says “failed to start session”
I ran BIOS diagnostics on my computer and found no problems. Also I have used peppermint OS on this laptop for some time with no problems.
Help??
Re: Can’t login after update
« Reply #1 on: February 08, 2019, 02:04:31 pm »
At the login screen, hit Ctrl+Alt+F3
Log in in text mode, then run:
sudo service lightdm restartdo you get any error message ?
Offline mick
« Reply #2 on: February 08, 2019, 02:21:24 pm »
Thank you. No error message. I was able to log in in text mode and input the text. Then it reverted to the original login screen and I was unable to log in for exact same reason as before.
Offline mick
« Reply #3 on: February 08, 2019, 02:25:43 pm »
When I repeat the ctrl+alt+f3 command I am still logged in in text mode if that helps
« Reply #4 on: February 09, 2019, 01:42:30 am »
df -hdo any of the lines contain 100% (or very close), other than any that start with /dev/loop
Offline mick
« Reply #5 on: February 09, 2019, 09:01:50 am »
my dev/sda1 is 48%.  the other 7 or 8 lines are all 0% or 1%.
my friend helped me switch over to the xfce desktop instead of the standard peppermint desktop, and in that way i am able to use my computer relatively normally.  except that every time i push the window key i get a message that says "Failed to send D-Bus Message; no running instance of xfce4-panel was found."
i still want to resolve the previous situation, but thats where its at for the moment so i can continue to access my data.
Offline mick
« Reply #6 on: February 09, 2019, 09:32:44 am »
correction-- LXDE desktop.  :)
« Reply #7 on: February 09, 2019, 03:03:25 pm »
okay I'm lost now .. so you can log on now or not ?
If not, did this breakage occur immediately after installing LXDE ?
Offline mick
« Reply #8 on: February 10, 2019, 05:20:47 pm »
thank you for continuing to help.
first something broke after i updated and i was unable to log in.
second (between my last post on feb 8 and your first post on feb 9) my friend was able to get me back up and running on the LXDE desktop, but not on peppermint.
as of now, i am fully functional on the LXDE desktop, but would like to return to the Peppermint9 original desktop setup.
i would happily accept any kind of reset that allows me to keep my data.
« Last Edit: February 10, 2019, 05:23:14 pm by mick »
« Reply #9 on: February 11, 2019, 05:16:33 am »
So when you get to the login screen, you're now able to choose between LXDE and Peppermint as the session ?
Can you post the output from
ls -a /usr/share/xsessionsand
ls -al ~/.configand
sudo fdisk -land
cat /etc/lsb-release
I'm trying to figure out whether your friend just added an LXDE session to Peppermint, or whether he installed a whole other distro
« Last Edit: February 11, 2019, 05:24:38 am by PCNetSpec »
Offline mick
« Reply #10 on: February 11, 2019, 05:58:17 am »
i am not able to choose.  The startup screen has the original peppermint wallpaper, but then it starts the LXDE desktop.
xsessions says;
.   LXDE.desktop     Peppermint.desktop                ubuntu.desktop
..  openbox.desktop  ubuntu-communitheme-snap.desktop  xfce.desktop
.config says;
total 212
drwxr-xr-x 47 mick mick 4096 Feb 10 20:00  .
drwxr-xr-x 32 mick mick 4096 Feb 11 07:52  ..
drwxr-xr-x  2 mick mick 4096 Sep 19 15:24  autostart
drwxr-xr-x 16 mick mick 4096 Jan  8 14:59  chromium
drwxr-xr-x  2 mick mick 4096 Feb  8 19:31  clipit
drwxrwxr-x  2 mick mick 4096 Jan 30 10:22  dassault-systemes
drwxrwxr-x  2 mick mick 4096 Oct 21 22:27 'Dassault Systemes'
drwx------  2 mick mick 4096 Feb 11 07:52  dconf
drwxrwxr-x  3 mick mick 4096 Oct 21 22:27  DraftSight
drwx------  2 mick mick 4096 Sep 20 10:42  enchant
drwx------  2 mick mick 4096 Feb  4 13:57  evince
drwxrwxr-x  3 mick mick 4096 Jan 30 10:25  freeplane
drwxr-xr-x  2 mick mick 4096 Feb  9 12:21  gedit
drwxr-xr-x  2 mick mick 4096 Feb 10 19:42  goa-1.0
drwxr-xr-x  3 mick mick 4096 Sep 19 15:24  google-chrome
drwxrwxr-x  2 mick mick 4096 Sep 25 10:49  GottCode
drwx------  2 mick mick 4096 Feb 10 20:00  gtk-2.0
drwx------  2 mick mick 4096 Feb 11 07:52  gtk-3.0
drwx------  3 mick mick 4096 Feb 10 19:42  ibus
drwxr-x--x  7 mick mick 4096 Dec 17 16:05  inkscape
drwx------  2 mick mick 4096 Sep 20 10:09  leafpad
drwxrwxr-x  2 mick mick 4096 Feb  9 10:37  libfm
drwxrwxr-x  3 mick mick 4096 Sep 25 10:56  libreoffice
drwxrwxr-x  2 mick mick 4096 Nov 19 10:53  linuxmint
drwx------  3 mick mick 4096 Feb  8 19:31  lxpanel
drwxrwxr-x  4 mick mick 4096 Feb  8 19:31  lxsession
drwxrwxr-x  2 mick mick 4096 Dec 13 16:46  lxsession-default-apps
drwxrwxr-x  2 mick mick 4096 Jan 30 10:13  MicroQuill
-rw-rw-r--  1 mick mick  477 Jan 15 10:39  mimeapps.list
drwxr-xr-x  2 mick mick 4096 Feb 10 19:42  nemo
drwxr-xr-x  2 mick mick 4096 Sep 19 15:24  nitrogen
drwxrwxr-x  2 mick mick 4096 Feb  8 19:31  openbox
drwx------  2 mick mick 4096 Feb 10 19:31  orage
-rw-rw-r--  1 mick mick   89 Jan 11 16:47  pavucontrol.ini
drwx------  3 mick mick 4096 Feb  8 19:31  pcmanfm
drwxr-xr-x  2 mick mick 4096 Feb 10 18:55  peppermint-control-center
drwx------  2 mick mick 4096 Jan 28 09:22  pulse
-rw-rw-r--  1 mick mick  477 Feb 10 20:00  QtProject.conf
drwxr-xr-x  2 mick mick 4096 Sep 19 15:24  sakura
drwxrwxr-x  2 mick mick 4096 Feb 10 20:04  sonic-pi.net
drwxrwxr-x  2 mick mick 4096 Oct 21 22:27  SWActivation
drwxr-xr-x  5 mick mick 4096 Jan 30 18:37  transmission
-rw-r--r--  1 mick mick 3881 Jan 28 09:21  Trolltech.conf
drwxrwxr-x  2 mick mick 4096 Feb 10 20:13  uk.ac.cam.cl
drwx------  2 mick mick 4096 Feb 10 19:42  update-notifier
-rw-------  1 mick mick  633 Sep 19 15:30  user-dirs.dirs
-rw-rw-r--  1 mick mick    5 Sep 19 15:30  user-dirs.locale
drwx------ 16 mick mick 4096 Feb 10 22:46  vivaldi
drwxr-xr-x  2 mick mick 4096 Jan  7 22:23  vlc
drwxr-xr-x  2 mick mick 4096 Feb  8 14:29  xed
drwxr-xr-x  5 mick mick 4096 Feb 10 09:29  xfce4
drwx------  2 mick mick 4096 Nov 13 11:04  xviewer
drwxrwxr-x  2 mick mick 4096 Sep 20 11:09  yelp
fdisk says;
[sudo] password for mick:
Disk /dev/sda: 119.2 GiB, 128035676160 bytes, 250069680 sectors
Disklabel type: dos
Disk identifier: 0xe13fb09c
Device     Boot Start       End   Sectors   Size Id Type
/dev/sda1  *     2048 250068991 250066944 119.2G 83 Linux
release says;
DISTRIB_ID=Peppermint
DISTRIB_RELEASE=9
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Peppermint 9 Nine"
« Reply #11 on: February 11, 2019, 06:17:41 am »
On the login screen, to the right of your username is there a little circular icon with the LXDE swift on it ? .. if you click that icon, are you offered "Peppermint" as an option ?
Offline mick
« Reply #12 on: February 11, 2019, 07:46:21 am »
I was set to automatically login to my account.
I changed that, rebooted, and YES, one of the options is "Peppermint [default]".
I selected peppermint, logged in, and am using it now.  Its a reset version (not set up how i had it before), but all my data seems to be there.  the window key doesn't seem to work, but i think i know how to fix that :)
if i can't, i'll make a different post.
thank you for all your help.
« Reply #13 on: February 11, 2019, 11:48:09 am »
Yeah just undo the changes you made in your other topic.
And if you're happy this is (SOLVED) now, can you please remember to mark the topic so...
You can do this by editing the FIRST posting in this topic, and changing
Subject: Can’t login after update (SOLVED)
« Last Edit: February 11, 2019, 11:49:58 am by PCNetSpec »
