Author Topic: Requesting an Ethernet network address forever  (Read 3386 times)
Offline carmen
  • Peppermint version(s): Peppermint Four
« on: August 08, 2014, 01:01:20 pm »
For various reasons (moving, etc.) I hadn't opened/updated my netbook for a long time. But when I got my internet installed I used it to test and see if it was working (it was), and then I did a Skype call later that week, and it gave me trouble and I messed with the settings until it worked (sorry I can't be more specific here, I didn't think I'd need to remember once it started working...), and then the next time I tried to use the internet it wouldn't work no matter what I did with the settings. It's really frustrating because it worked those other times... why isn't it working now?
I tried to find a solution on the internet, but I am a newbie and maybe I don't know how to phrase my search... So now I am asking here. I'll try to include what's needed the first time but let me know if I leave something out.
The internet, router, and cable are all okay, the desktop computer uses them fine.
Here's what I got for inxi -F
Here's what I got for lspci -vvnn
Here's what I got for ifconfig
Re: Requesting an Ethernet network address forever
« Reply #1 on: August 08, 2014, 01:05:54 pm »
can you post the output from:
sudo lshw -C networkand
sudo iwlist scanningand
iwconfigand
rfkill list
is this a new router ?
« Reply #2 on: August 08, 2014, 01:16:56 pm »
Could it be because you are running Peppermint OS Four?  You say you haven't updated for a long time so maybe you are unaware that Pepper OS Four is no longer supported.  It no longer receives updates.  Peppermint Five was released 23 June 2014.  Maybe a fresh Peppermint Five installation would do the trick.  Good luck  ;)!
« Reply #3 on: August 08, 2014, 01:20:36 pm »
I kind of doubt that, AndyInMokum. I still have Peppermint four on one machine (although it will soon be gone) and see nothing like carmen is reporting.
However, I see and agree with your point: carmen should update (new install) Peppermint 5 !!!  ;)
« Last Edit: August 08, 2014, 01:22:31 pm by Slim.Fatz »
« Reply #4 on: August 08, 2014, 01:21:40 pm »
Nice spot Andy :)
I'd still expect wireless to connect, but Peppermint 4 is dead so Peppermint 5 should probably be the OP's next move.
@ Slim.Fatz
I agree wireless should still work in Peppermint 4 .. but if we're going to need to install anything, it's going to be REALLY difficult in Peppermint 4 .. so I'd still advise a move to Peppermint 5 (which will probably fix the issue anyway).
« Last Edit: August 08, 2014, 01:23:52 pm by PCNetSpec »
Offline carmen
« Reply #5 on: August 11, 2014, 12:01:34 pm »
Okay, I will go up to Peppermint 5 and see what happens.  I'll let you know how that goes. Thanks!
