Author Topic: Touchpad accidentaly brings up the right-click context menu while scrolling.  (Read 2176 times)
Offline Specter
  • C#, Cryptocurrency, Finance.
Hello, everybody!
It's not that big of a deal, but sometimes it's annoying while working.
The problem is in the title; the touchpad brings up the right-click menu while making quick scrolls. Is there a way to tweak these particular settings to disable the right-click menu while making fast scrolls?
Edit: After looking around i probably need to adjust the doble and single-click speed and delay. Are there any suggestions on how to accomplish that in Pepp 9?
Edit2: Slightly moving the pointer counts as a click/tap; slightly scrolling causes a doble-click/tap.
Thanks in advance!
« Last Edit: February 05, 2019, 12:27:04 pm by Specter »
"forever is composed entirely of nows"
See if changing to these settings in the Peppermint Control Center (Touchpad Options) helps:-
Offline Specter
Nope, the problem persists. Slightly moving the cursor causes a single tap. Same with the scrolling, it causes a two-finger tap.
I need to move/scroll longer distance not to trigger a tap/click.
Edit: If I am to guess, the fix should be something like this:
If cursor moves 2 or more pixels do not count as a tap.
Tap/Click and Two-Finger Tap/Click shouldn't occur while cursor is moving.
P.S. Im not a programmer :D
« Last Edit: February 05, 2019, 01:28:05 pm by Specter »
What's the output from:
xinput --list
Offline Specter
$ xinput --list
⎡ Virtual core pointer                    id=2 [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              id=4 [slave  pointer  (2)]
⎜   ↳ SynPS/2 Synaptics TouchPad              id=12 [slave  pointer  (2)]
⎣ Virtual core keyboard                    id=3 [master keyboard (2)]
    ↳ Virtual core XTEST keyboard              id=5 [slave  keyboard (3)]
    ↳ Power Button                            id=6 [slave  keyboard (3)]
    ↳ Video Bus                                id=7 [slave  keyboard (3)]
    ↳ Power Button                            id=8 [slave  keyboard (3)]
    ↳ Lenovo EasyCamera: Lenovo EasyC          id=9 [slave  keyboard (3)]
    ↳ Ideapad extra buttons                    id=10 [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard            id=11 [slave  keyboard (3)]
Maybe i should edit the finger tap settings in synaptics?
Synaptics Finger (270): 25, 30, 0
Synaptics Tap Time (271): 180
Synaptics Tap Move (272): 263
Synaptics Tap Durations (273): 180, 180, 100
Synaptics ClickPad (274): 0
Synaptics Middle Button Timeout (275): 75
But I don't really know what I am doing. Just read a bunch of forums. I will wait for your assistance. Thanks for helping me!
Can we have the full output from:
xinput --list-props 12BTW, it can't hurt to experiment with setting in here .. changes will only last until you next log off/on (or reboot) anyway.
Offline Specter
How to edit those settinngs btw?  :D
$ xinput --list-props "SynPS/2 Synaptics TouchPad"
Device 'SynPS/2 Synaptics TouchPad':
Device Enabled (140): 1
Coordinate Transformation Matrix (142): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
Device Accel Profile (265): 1
Device Accel Constant Deceleration (266): 2.500000
Device Accel Adaptive Deceleration (267): 1.000000
Device Accel Velocity Scaling (268): 12.500000
Synaptics Edges (269): 1511, 5433, 1271, 4607
Synaptics Two-Finger Pressure (276): 282
Synaptics Two-Finger Width (277): 7
Synaptics Scrolling Distance (278): 119, 119
Synaptics Edge Scrolling (279): 0, 0, 0
Synaptics Two-Finger Scrolling (280): 1, 1
Synaptics Move Speed (281): 1.000000, 1.750000, 0.033411, 0.000000
Synaptics Off (282): 0
Synaptics Locked Drags (283): 0
Synaptics Locked Drags Timeout (284): 5000
Synaptics Tap Action (285): 2, 3, 0, 0, 1, 3, 0
Synaptics Click Action (286): 1, 1, 0
Synaptics Circular Scrolling (287): 0
Synaptics Circular Scrolling Distance (288): 0.100000
Synaptics Circular Scrolling Trigger (289): 0
Synaptics Circular Pad (290): 0
Synaptics Palm Detection (291): 0
Synaptics Palm Dimensions (292): 10, 200
Synaptics Coasting Speed (293): 20.000000, 50.000000
Synaptics Pressure Motion (294): 30, 160
Synaptics Pressure Motion Factor (295): 1.000000, 1.000000
Synaptics Resolution Detect (296): 1
Synaptics Grab Event Device (297): 0
Synaptics Gestures (298): 1
Synaptics Capabilities (299): 1, 0, 1, 1, 1, 1, 1
Synaptics Pad Resolution (300): 78, 51
Synaptics Area (301): 0, 0, 0, 0
Synaptics Noise Cancellation (302): 8, 8
Device Product ID (260): 2, 7
Device Node (261): "/dev/input/event5"
Can you post the output from
synclient -land would it be enough for us to simply disable double-finger tap = right-click ?
We can test this in a non-persistent way first.
Offline Specter
I would prefer to keep the double-finger right-click. Btw the problem is there even without the double finger tap.
For example:
If I'm on Youtube and i try to move the cursor slightly and quickly it registers as a click and opens a video even though the cursor moves.
Here is the output:
$ synclient -l
Parameter settings:
    LeftEdge                = 1511
    RightEdge               = 5433
    TopEdge                 = 1271
    BottomEdge              = 4607
    FingerLow               = 25
    FingerHigh              = 30
    MaxTapTime              = 180
    MaxTapMove              = 263
    MaxDoubleTapTime        = 180
    SingleTapTimeout        = 180
    ClickTime               = 100
    EmulateMidButtonTime    = 75
    EmulateTwoFingerMinZ    = 282
    EmulateTwoFingerMinW    = 7
    VertScrollDelta         = 119
    HorizScrollDelta        = 119
    VertEdgeScroll          = 0
    HorizEdgeScroll         = 0
    CornerCoasting          = 0
    VertTwoFingerScroll     = 1
    HorizTwoFingerScroll    = 1
    MinSpeed                = 1
    MaxSpeed                = 1.75
    AccelFactor             = 0.0334113
    TouchpadOff             = 0
    LockedDrags             = 0
    LockedDragTimeout       = 5000
    RTCornerButton          = 2
    RBCornerButton          = 3
    LTCornerButton          = 0
    LBCornerButton          = 0
    TapButton1              = 1
    TapButton2              = 3
    TapButton3              = 0
    ClickFinger1            = 1
    ClickFinger2            = 1
    ClickFinger3            = 0
    CircularScrolling       = 0
    CircScrollDelta         = 0.1
    CircScrollTrigger       = 0
    CircularPad             = 0
    PalmDetect              = 0
    PalmMinWidth            = 10
    PalmMinZ                = 200
    CoastingSpeed           = 20
    CoastingFriction        = 50
    PressureMotionMinZ      = 30
    PressureMotionMaxZ      = 160
    PressureMotionMinFactor = 1
    PressureMotionMaxFactor = 1
    ResolutionDetect        = 1
    GrabEventDevice         = 0
    TapAndDragGesture       = 1
    AreaLeftEdge            = 0
    AreaRightEdge           = 0
    AreaTopEdge             = 0
    AreaBottomEdge          = 0
    HorizHysteresis         = 8
    VertHysteresis          = 8
    ClickPad                = 0
See how you get on with
synclient TapButton2=0?
Offline Specter
This disables the double finger tap. It didn't fix the problem. I should probably edit MaxTapTime and MaxDoubleTapTime.
Try it then and let us know how you get on.
Offline Specter
I've managed to fix my problem. The problem was still there even after installing Pep10.
After reading some manual pages of SYNAPTICS I've found that the command I was looking for was MaxTapMove (Maximum movement of the finger for detecting a tap)
the default settings in my case was MaxTapMove=263, which means that after moving my finger slightly it registered as tap.
I've fixed it by changing the settings to MaxTapMove=70, If someone have this problem you can tweak it to your needs. I no longer have accidental taps and clicks.
Nicely figured out, and thanks for posting the solution .. all adds to the database between my ears (oh and here on the forum) :)
MaxBrainStore=101   :))
