Author Topic: (Bug report) Desktop icon position resets after wallpaper is changed: workaround  (Read 510 times)
Offline tinkereR
  • Consciously Eclectic
  • Peppermint version(s): Peppermint 8 Respin
I've been testing Pmint 9 Respin 2 in a VM. Kind of taste testing, if you will.
Minor bug with the desktop icons, as the title suggests. I enabled the Computer, Home, and Recycle icons via dconf. Prob is, their positions on the desktop are reset every time I make alterations to the wallpaper. Theming aside, the install is relatively vanilla. I also noted the same bug during a live session. I'm just wondering if this bug can be reproduced on other systems? I've yet to install or test this release on physical hardware. Still have an old pmint 8 partition on SSD that hasn't been booted in a year (long story, busy college student lol)
Screenshot examples below:
In the first image, my trash icon has been manually positioned to the bottom right corner. The second screenshot was taken after switching the wallpaper. The icon has been re-positioned to its default position.
Update:
Just got home and did some further testing. I was trying to configure Nitrogen (the default wallpaper manager) to use separate images across 2 monitors. This was easily accomplished after creating a launcher for
nitrogen --force-setter=xinerama
Interesting enough, managing wallpapers this way does not invoke the aforementioned anomaly  :-\
Love the distro. Just thought I'd put this out in the open for reference.
Many thanks
Perhaps its just resentful of me dressing it up to more closely resemble that 'other' mint? ;)
Theme was generated via oomox, GTK2 resources and matching xfwm4 borders borrowed from the original Shiki-WIse/Gnome Colors set (available in repos)
« Last Edit: January 10, 2019, 07:03:13 pm by docR »
i7 4790k @4.4 GHz, MSI Z97 PC Mate, EVGA GTX 950, HyperX  x2 8 GB (16 GB) DDR3, Adata SU650 240 GB, 2 TB WD Green 5400 RPM, 2 TB Seagate Barracuda 7200 RPM
Hmm, this
sounds pretty cool, I wasn't even aware it had that option .. thanks for that :)
Is there any downside for single monitor setups (or non-nvidia setups) ? .. what I'm asking is should I just make the default launcher run that command ?
Offline tinkereR
Hmm, this
I randomly found this command on a forum after some googling. I wasn't aware of the option until now either. It seems to behave with single and dual-monitor configs alike, which is nice.
There is a caveat, however. After quitting the session (rebooting/logging out), the wallpaper is reverted to the last wallpaper applied via stock nitrogen/wallpaper manager, which is odd  :-\
I'm wagering this conflict can be resolved... somehow
Would be awesome to have this as the pmint default.
Since I managed to flag down the Big Cheese, I'm wondering if you could take a looksy here:
https://github.com/TomaszGasior/gtk3-mushrooms/wiki/Screenshots
https://forum.manjaro.org/t/gtk3-classic-gtk3-mushrooms-gtk3-with-my-own-patches/30230/41
I tested Manjaro XFCE not long ago. I don't care for Arch myself as I feel rolling distros are too unpredictable. Part of the reason I dislike Win10. I'm pretty busy nowdays, so I can't bother to babysit my computer and image clone it every week, haha. What I did find rather intriguing are the GTK patches they've applied to their XFCE edition. Really does boost system-wide continuity by a factor of 10. I'm wondering if these patches can be inspected, and perhaps applied to Peppermint?
« Last Edit: January 11, 2019, 02:33:41 pm by docR »
Hmmmm .... the Big Cheese .... could it be that we have a new moniker for PCNetSpec (aka PCNeverSleeps)?  :D
I'll look through the nitrogen code when I have time.
Odd that:
man nitrogen
doesn't mention that option :-\
Ahh:
nitrogen --help
does:-
nitrogen --help
Usage:
--force-setter=[arg]
Force setter engine: xwindows, xinerama, gnome
--head=[arg]
Select xinerama/multihead display in GUI, 0..n, -1 for full
--help, -h
Prints this help text.
--no-recurse
Do not recurse into subdirectories
--restore
Restore saved backgrounds
--save
Saves the background permanently
--set-auto
Sets the background to the given file (auto)
--set-centered
Sets the background to the given file (centered)
--set-color=[arg]
background color in hex, #000000 by default
--set-scaled
Sets the background to the given file (scaled)
--set-tiled
Sets the background to the given file (tiled)
--set-zoom
Sets the background to the given file (zoom)
--set-zoom-fill
Sets the background to the given file (zoom-fill)
--sort=[arg]
How to sort the backgrounds. Valid options are:
* alpha, for alphanumeric sort
* ralpha, for reverse alphanumeric sort
* time, for last modified time sort (oldest first)
* rtime, for reverse last modified time sort (newest first)
« Last Edit: January 11, 2019, 04:55:33 pm by PCNetSpec »
