Author Topic: Joining P9 to Active Directory domain <SOLVED>  (Read 1170 times)
Offline MNFrozenfish
  • Smile! - It makes people wonder what you're up to.
  • Peppermint version(s): Peppermint 9 Respin-64 bit / P10
« on: January 04, 2019, 07:29:00 pm »
I apologize in advance as I'm sure this has been answered before, but I am unable to find a solution in searching the forum.
My question is, how do I join a Peppermint 9 box to a Windows AD domain and configure an auto login with an AD account on that box?
Thanks in advance
« Last Edit: January 07, 2019, 12:39:49 pm by MNFrozenfish »
Re: Joining P9 to Active Directory domain
« Reply #1 on: January 05, 2019, 06:18:09 am »
Peppermint 9 is built upon Ubuntu 18.04, so see if this helps
https://bitsofwater.com/2018/05/08/join-ubuntu-18-04-to-active-directory/
« Reply #2 on: January 05, 2019, 05:18:38 pm »
Thanks for the information. Looks like it will work, I will mark as Solved when I have had a chance to test. I've been away since P5, so I'm a bit rusty.  ;)
« Reply #3 on: January 05, 2019, 07:18:10 pm »
Wow!  Welcome back, MNFrozenfish!!
I'm happy to see you, and that unforgettable name of yours, back in the forum!  You were one of the first guys from Peppermint's old forum who helped me get started with Linux when I began playing with Peppermint 3 back then on a flash drive.  And as you can see, Linux Peppermint OS has matured a lot since the Peppermint 3, 4, and 5 days, even though Peppermint's community and forum has remained as supportive and fun as as ever.
Glad to see you again, MNFrozenfish!! :)
« Reply #4 on: January 06, 2019, 10:12:30 am »
Yeah please let us know how you get on, it'll be useful information for others with the same network setup.
You might also need SMBv1 .. here's a good place to start for that:
https://forum.peppermintos.com/index.php/topic,7507.msg76938.html#msg76938
« Reply #5 on: January 06, 2019, 02:33:26 pm »
Returns - The topic or board you are looking for appears to be either missing or off limits to you.
Looks like I need to be more active on the forum.  :D ;D ::) :-\
« Reply #6 on: January 07, 2019, 04:43:46 am »
That's because he linked to a thread in a part of the forum that's restricted to Trusted Users and higher.
« Reply #7 on: January 07, 2019, 11:12:53 am »
My apologies .. here's what the linked post said...
I had to set up some mapped network drives on a bunch of Windows 10 workstations yesterday .. to automount some shares from some older NAS's.
Well I spent half a day trying to figure out why one single Windows 10 machine flatly refused to allow me to browse the network. It turns out that
a) The NAS's were using SMB v1
b) If you install Windows 10 >= 1709 SMB v1 isn't installed
c) If you Installed an earlier version of Win10 where SMB v1 was installed, then applied the "Fall Creators" update .. the update would uninstall SMB v1 after 15 days if it didn't detect it had been used in that time.
https://support.microsoft.com/en-gb/help/4034314/smbv1-is-not-installed-by-default-in-windows
Now IIRC we've had some questions previously on the forum from people saying stuff like "PM9 screwed up my network shares, they worked in PM8" or "PM9 can't see my Win10 PC", etc.
So if this comes up again, probably the easiest solution would be to make sure SMB v1 is installed/enabled in both Windows 10 .. AND .. Peppermint 9
Instructions for enabling SMB v1 in Peppermint 9 can be found here:
https://forum.peppermintos.com/index.php/topic,7086.msg72516.html#msg72516
Instructions for making sure SMB v1 is installed in Windows 10:-
  • Search in the start menu for ‘Turn Windows features on or off’ and start it.
  • In the resulting dialog window search for ‘SMB1.0/CIFS File Sharing Support’ in the list of options offered, and tick the box next to it.
  • Click OK and Windows will download/install it .. You should then be prompted to reboot the PC, but if not reboot anyway.
(it's important that you REBOOT Windows because it does that very 'Windowy' thing where it's installed as part of the shutdown and bootup process)
As additional info, it turns out there was a firmware update available for the NAS's in question that enabled a later version of SMB (3 I think) .. but even after updating the firmware and enabling the later SMB .. then rebooting EVERYTHING .. Windows STILL couldn't see the NAS's.
So it looks like SMB >= v2 is a bit hit and miss in both Windows and Linux at the moment .. hence this post.
« Reply #8 on: January 07, 2019, 12:24:01 pm »
I was able to join the domain following:
It took a bit of tweaking to the paths and scripts, but for the most part just followed the post.
I didn't need any of the "Might need" links to get it connected.
Thanks again.
Footnote: The purpose of the box in question was to run a house built Unity application that Windoze updates breaks regularly. After talking to my fellow techs we have determined that a P9 box with Comodo AV will serve the purpose without adding it to the domain. The curious part of me still had to test and now I know.  :)
Now to set up an autologin account that auto starts the app...
Re: Joining P9 to Active Directory domain <SOLVED>
« Reply #9 on: January 07, 2019, 02:49:20 pm »
Nice .. glad it works, thanks for letting us know :)
