Author Topic: How i like to set my peppermint  (Read 607 times)
Offline steve-o
  • Peppermint version(s): 8+9
« on: January 04, 2019, 10:31:51 am »
set clock %a %B %e %G %k:%M
pluma ~/.Xresources
Xft.dpi: 96
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
install bleachbit
sudo nvidia-xconfig
screen tearing
sudo nvidia-settings
autostart nvidia-settings --assign CurrentMetaMode="nvidia-auto-select +0+0 { ForceFullCompositionPipeline = On }"
GRUB_GFXMODE=1920x1080
GRUB_GFXPAYLOAD_LINUX=keep
sudo update-initramfs -u
sudo update-grub2
clear your terminal
cat /dev/null > ~/.bash_history && history -c && exit
clean  rm -v -r ~/.mozilla
« Last Edit: January 04, 2019, 03:16:34 pm by zebedeeboss »
Re: How i like to set my peppermint
« Reply #1 on: January 04, 2019, 11:24:32 am »
pluma in PM8/9 ?
Online zebedeeboss
« Reply #2 on: January 04, 2019, 03:15:33 pm »
Hi steve-o,
Welcome to the Forums
You need to encapsulate the terminal output with the Insert, Code # function.  For extra long outputs, please use the Spoiler, Sp function.  If youíre a Chromium Browser and/or a Google Chrome user, please don't combine these functions.  For some reason, they donít work well together with these browsers.  The formatting gets all goofed up.  Only use one or the other  ;).  These forum functions preserve the original format of the output.  This makes it easier for future visitors to relate to their own issues.  These functions are found in the forum editor, above the,  :-[ Embarrassed and  the :'( Cry emoticon respectively.  Use the Preview button to check how it'll look after you post it to forum.  I hope this helps  ;) I have done it for you this time
Linux User #565092
P10 x64 Desktop - AMD Threadripper 2950X - 32Gb RAM - NVIDIA RTX2080Ti 11Gb - 2 x 27" 4k 3840x2160 - 1 x 34" 5120x2160
P9/10 @ P9 x64 Laptop - i7-7700HQ @ 2.80GHz - 8Gb RAM - Nvidia GTX1050 4Gb - 15.6" HD 1920x1080
