Author Topic: WIFI suddenly disapperead (3days after installation) [SOLVED]  (Read 1047 times)
Offline hek
« on: January 02, 2019, 09:12:50 am »
Hello there.
I'm completely new to linux and recently bought a cheap windows 10 notebook to get started with it, and was delighted by Peppermint during the first few days.  Great work!  However, now I have a chance to learn more about the working of this operating system because for no apparent reason to myself, the WIFI doesnt't work on the third day.  It's a few days since the occurunce; I have started to understand more about linux and the terminal and have read around various forums but i feel like Im completely new to it and I need to ask more experienced people who can read the output from my terminal, and hopefully guide me on the way to more knowledge of this problem and eventually to fix it. Can anyone guide me in the right direction?
lsp -vnn
01:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. Device [10ec:b822]
Subsystem: Hewlett-Packard Company Device [103c:831b]
Flags: fast devsel, IRQ 255
I/O ports at 1000 [size=256]
Memory at a1200000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [148] Device Serial Number 00-e0-4c-ff-fe-b8-22-01
Capabilities: [158] Latency Tolerance Reporting
Capabilities: [160] L1 PM Substates
Kernel modules: r8822be
hek@hek-HP-Stream-Laptop-11-ah1XX ~ $ sudo lshw -C network
  *-network UNCLAIMED
       product: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:01:00.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress cap_list
       configuration: latency=0
       resources: ioport:1000(size=256) memory:a1200000-a120ffff
~ $ iwconfig
~ $ sudo ifconfig
[sudo] password for hek:
enx00909e9aaa52: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.67  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 2806:10b7:2:5158:60ed:cadd:55a3:71ec  prefixlen 64  scopeid 0x0<global>
        inet6 2806:10b7:2:5158::3  prefixlen 128  scopeid 0x0<global>
        inet6 fd7c:b15d:8610:7800:60ed:cadd:55a3:71ec  prefixlen 64  scopeid 0x0<global>
        inet6 2806:10b7:2:5158:a990:16b8:2f68:307d  prefixlen 64  scopeid 0x0<global>
        inet6 fd7c:b15d:8610:7800:f5e3:5776:b0cc:b0ff  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::5a93:9199:6b15:b102  prefixlen 64  scopeid 0x20<link>
        ether 00:90:9e:9a:aa:52  txqueuelen 1000  (Ethernet)
        RX packets 11659  bytes 12636043 (12.6 MB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 10341  bytes 1125225 (1.1 MB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 875  bytes 77190 (77.1 KB)
        TX packets 875  bytes 77190 (77.1 KB)
~ $ sudo iwlist scan
enx00909e9aaa52  Interface doesn't support scanning.
~ $ rfkill list
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
« Last Edit: January 02, 2019, 09:27:13 pm by hek »
Re: WIFI suddenly disapperead (3days after installation)
« Reply #1 on: January 02, 2019, 09:54:39 am »
Hi Hek,
Welcome to the forums
You need to encapsulate the terminal output with the Insert, Code # function.  For extra long outputs, please use the Spoiler, Sp function.  If you’re a Chromium Browser and/or a Google Chrome user, please don't combine these functions.  For some reason, they don’t work well together with these browsers.  The formatting gets all goofed up.  Only use one or the other  ;).  These forum functions preserve the original format of the output.  This makes it easier for future visitors to relate to their own issues.  These functions are found in the forum editor, above the,  :-[ Embarrassed and  the :'( Cry emoticon respectively.  Use the Preview button to check how it'll look after you post it to forum.  I hope this helps  ;)
I have done it for you this time
Regards Zeb....
ps answers to your problem should arrive soon :)
« Reply #2 on: January 02, 2019, 11:24:32 am »
Do you get any output from:
lsmod | grep r8822beif not, does wireless spring to life if you run:
sudo modprobe r8822be
Offline hek
« Reply #3 on: January 02, 2019, 11:44:37 am »
~ $ sudo modprobe r8822be
modprobe: ERROR: could not insert 'r8822be': Required key not available
got nothing out of the first one, completely blank reply...
« Reply #4 on: January 02, 2019, 12:43:55 pm »
Okay, try disabling "secureboot" in your BIOS.
I'm guessing there's been a firmware update and the new firmware for that hardware isn't signed.
Offline hek
« Reply #5 on: January 02, 2019, 03:07:35 pm »
That's done it!  WIFI is working again, thanks a lot!
For reference it's a HP Stream 11 laptop.
Thanks again!
« Last Edit: January 02, 2019, 03:09:17 pm by hek »
« Reply #6 on: January 02, 2019, 03:27:08 pm »
You're most welcome, glad I could help :)
