Author Topic: Youtube Video Recording (SOLVED).  (Read 2542 times)
Offline s2
« on: December 30, 2018, 07:45:44 am »
i searched within Synaptic Package Manager and found what appears to be a package to record youtube videos.
not sure what i should do next to get this to download and install.
need help from the Peppermint crew.
thanks...
« Last Edit: March 23, 2020, 07:48:57 pm by s2 »
Re: Youtube Video Recording
« Reply #1 on: December 30, 2018, 08:04:52 am »
Hi s2
What's the name of this package ?
Offline s2
« Reply #2 on: December 30, 2018, 11:51:51 am »
junior-video    1.24Ubuntu1      Debian Jr. Video
« Reply #3 on: December 30, 2018, 12:44:40 pm »
I've never heard of junior-video before but it installs as Kaffeine which I have heard of, I don't see it being a you tube recorder in fact I can't get it to play you tube videos but it can can play TV channels (presumably with a tuner card installed ) it also plays DVD's well.
I don't know exactly what you're looking for but if it's just you tube streaming I would suggest SMplayer which comes with a youtube player (SM Tube) or if you want to download youtube videos i would suggest youtube-dl both are available in the repos
Good luck
« Last Edit: December 30, 2018, 12:51:17 pm by emegra »
« Reply #4 on: December 30, 2018, 02:17:40 pm »
If you're looking to downlload YouTube video's I'd suggest you donload this file
For Peppermint 8
https://launchpad.net/~nilarimogard/+archive/ubuntu/webupd8/+files/youtube-dlg_0.4-1~webupd8~xenial4_all.deb
OR
For Peppermint 9
https://launchpad.net/~nilarimogard/+archive/ubuntu/webupd8/+files/youtube-dlg_0.4-1~webupd8~bionic9_all.deb
then double-click it to install.
You'll then find it in the menu at:-
Menu > Internet > YouTube DL GUI
« Reply #5 on: December 30, 2018, 03:00:43 pm »
Or, if you're just trying to record videos to upload to YouTube and have them in the correct format, you can record them in any format you want and use Openshot to convert them to YouTube's format. That's what I do. My iPhone records them in .mov format and I convert them to YouTube HD (.mp4 with the correct codec) using that program. :)
Offline kuppuswamy
  • Peppermint version(s): peppermint 9 x64
« Reply #6 on: December 31, 2018, 11:24:49 pm »
For Peppermint 9
       Thanks PCNetSpec  for the link to Youtube download.  I installed it on Peppermint 9 and downloaded two video streams.
Ulluvathu Ellam Uairvullal
« Reply #7 on: January 01, 2019, 02:28:56 pm »
Glad I could help :)
inventiv.us
  • Guest
« Reply #8 on: January 14, 2019, 01:23:57 pm »
For Peppermint 9
You'll then find it in the menu at:- Menu > Internet > YouTube DL GUI
I'll have to try that out myself.
Up until now, I've always used browser extensions to accomplish that.
That's the really really really simple way.
I'm bringing this up, because most users coming from Windoze probably go that route.
There are a couple caveats to browser extensions though:
1. permissions. When you click "add to firefox", it will show you the permissions it needs to function - but very often, lots of permissions it doesn't need but wants.  To resolve this, when I search for "extensions"/"add-ons", I open all the ones I am curious about in tabs, I click "add" but I don't confirm - I just leave that list open.  And I compare them all.  I also try to select extensions that have lots of users and 4 stars, because the younger apps tend to be buggy.
2. video download extensions slow down your browser a lot! (because they're scraping the code of each tab for signs of videos to list as available for download)  Disable as soon as you're finished using.
3. also, don't expect to find any extensions to download from youtube for the Chrome web browser, as google owns both.
« Reply #9 on: January 14, 2019, 02:35:01 pm »
YouTube DL GUI also gives you a few options too, such as to rip just the audio, or to download them in different formats, or to queue loads of links then download them all in one go, etc.
Offline stevesveryown
  • Peppermint Fan
    • stevesveryown
« Reply #10 on: January 15, 2019, 08:16:53 pm »
This is a simple, but awesome, tool. I just had to think who's live streams should I download.....  :-\ ;)
« Reply #11 on: January 15, 2019, 09:39:51 pm »
[...] who's live streams should I download.....  :-\ ;)
LoL  :D
Offline Ralph
  • Peppermint version(s): I've used 4,5,6,7,8,9
« Reply #12 on: January 16, 2019, 10:37:32 am »
I did not know about YouTube DL GUI.  I wanted to try it out so I clicked on the Peppermint 8 link. It did not install because I was missing one package. After doing some digging I was able to find a ppa with all the packages needed and get it installed. After looking it over, it reminds me allot of ClipGrab.  ClipGrab installs as an appimage and installs with all the packages it needs. I installed it on my desktop. Then made it executable.  I have used it and it seems to work just fine for my needs. If and when I don't want it anymore I can just delete it and it is all gone.
If anyone is interested you can find it at:    https://clipgrab.org/
PS. It works with Windows and Mac also.
A little knowledge is dangerous, I'm proof of it.
  • Peppermint Fan
    • stevesveryown
« Reply #13 on: January 16, 2019, 04:32:10 pm »
I had installed it on Pepp 9 but when I went to install it on Pepp 8 I had a dependency issue, missing python-two-dict(>=1.2).  :-\
« Reply #14 on: January 16, 2019, 05:31:23 pm »
Here's the missing dependency for Peppermint EIGHT:
https://launchpad.net/~nilarimogard/+archive/ubuntu/webupd8/+files/python-twodict_1.2-1~webupd8~xenial0_all.deb
download it, and install it before you install this (again for Peppermint EIGHT)
let me know if there are any other missing dependencies.
« Last Edit: January 16, 2019, 05:34:07 pm by PCNetSpec »
