Author Topic: Peppermint 9 Respin installer always crashes  (Read 963 times)
Offline Matthew
  • Peppermint version(s): Peppermint 10 & 10 Respin
« on: December 27, 2018, 05:58:58 pm »
I've been trying to install the new Peppermint 9 respin.  Every attempt results in an error message that makes no sense to me.  I did run the md5sum before creating the USB thumb drive.  Any suggestions?
We're sorry; the installer crashed. After you close this window, we'll allow you to file a bug report using the integrated bug reporting tool. This will gather information about your system and your installation process. The details will be sent to our bug tracker and a developer will attend to the problem as soon as possible.
Traceback (most recent call last):
  File "/usr/lib/ubiquity/bin/ubiquity", line 655, in <module>
    main(oem_config)
  File "/usr/lib/ubiquity/bin/ubiquity", line 639, in main
    install(args[0], query=options.query)
  File "/usr/lib/ubiquity/bin/ubiquity", line 274, in install
    ret = wizard.run()
  File "/usr/lib/ubiquity/ubiquity/frontend/gtk_ui.py", line 759, in run
    telemetry.get().set_installer_type('GTK')
  File "/usr/lib/ubiquity/ubiquity/telemetry.py", line 36, in get
    _Telemetry._telemetry = _Telemetry()
  File "/usr/lib/ubiquity/ubiquity/telemetry.py", line 51, in __init__
    with open('/cdrom/.disk/info') as f:
PermissionError: [Errno 13] Permission denied: '/cdrom/.disk/info'
« Last Edit: December 28, 2018, 05:25:24 am by AndyInMokum »
Re: Peppermint 9 Respin installer always crashes
« Reply #1 on: December 27, 2018, 06:03:08 pm »
How did you create the LiveUSB ?
Offline Matthew
« Reply #2 on: December 27, 2018, 06:14:43 pm »
In Peppermint 9 via Unetbootin.
« Reply #3 on: December 28, 2018, 04:10:47 am »
If you're running Peppermint, the best tool to use is the USB Image Writer, unser "System" in the menu.
Offline Matthew
Re: Peppermint 9 Respin installer always crashes [SOLVED]
« Reply #4 on: December 28, 2018, 07:56:51 am »
Thanks to both Scifidude79 and PCNetSpec.
When I used the USB Stick Formatter on the drive and then used USB Image Writer everything worked great.  I've got the P9 Respin running and have been setting it up with the software I generally use.
« Reply #5 on: December 28, 2018, 01:04:36 pm »
Great news Matthew :)
Unetbootin has been a bit flaky with Peppermint for a while now .. we generally suggest the USB Image Writer, or Etcher (or even 'dd') in Linux
or
Rufus and Etcher in Windows.
