Author Topic: Hotkeys / shortcuts are a f'ng nightmare in peppermint  (Read 616 times)
Offline neomorph
« on: December 17, 2018, 12:05:30 pm »
Xubuntu has much better support and working basics. How come peppermint has destroyed these?
Some specific ones:
  • Windows/Meta: Start menu opens on KEY DOWN, not KEY UP event.
  • Windows/Meta+Arrows: Does not move window to edge, minimize/maximize like it should
  • No hotkeys/shortcuts for quick launch
There is others too in muscle memory. Where do i fix these?
I tried to setup a custom shortcut for "calculator" button on my keyboard, but the change does not take.
We should get these fixed, these are a tremendous buden on usability.
I can get these done and submit a patch. Where should such a patch made, and what config files are involved?
Offline Lord Rodin
Re: Hotkeys / shortcuts are a f'ng nightmare in peppermint
« Reply #1 on: December 23, 2018, 02:23:17 pm »
Modify keyboard shortcuts
in terminal type
xfwm4-settings
then click on keyboard , then select the one you want and click edit
