Author Topic: Error with vlc codecs  (Read 743 times)
Offline Daileon
« on: December 08, 2018, 01:32:09 pm »
Hello, I'm new with Linux Peppermint.
I have tried to install nvidia drivers on my desktop, and i followed this tutorial https://ubuntuforums.org/showthread.php?t=2396263, and now all works fine with the graphics, before it, my screen freezed a lot of times.
But now, i can't play any video on any media player(I tried vlc,smplayer,mplayer,banshee), when i try to see a video on vlc i receive the following message:
Codec not supported:
VLC could not decode the format "mp4v" (MPEG-4 Video)
I have uninstalled the vlc and made the instalation process again, but nothing works.
I'm very frustated.I took 3 hours until install the nvidia drivers, and now i can't play videos on my pc . :'(
Can anyone help-me, i  searched a lot on google, but i dind't find nothing.
Re: Error with vlc codecs
« Reply #1 on: December 08, 2018, 06:22:39 pm »
Try running these commands in the terminal:
sudo apt-get update
sudo apt-get dist-upgrade
If you get any updates listed on the second one, be sure to install them. If not, that's fine. After those, run this:
sudo apt-get install xubuntu-restricted-extras
After you install the packages with that last command, try playing your video again.
Offline Lord Rodin
« Reply #2 on: December 25, 2018, 10:26:20 am »
To add the Proprietary NVIDIA GPU Drivers PPA into Peppermint and update the software sources, use the following commands in the terminal
sudo add-apt-repository ppa:graphics-drivers/ppa    push enter
sudo apt-get  update
Close terminal then go to - All - Additional Drivers and install latest nVidia drivers
after that is done now check to see if  libavcodec57 is installed - you can do that through the Synaptic Package Manager
