Author Topic: Peppermint 9 on Asus notebook SD Drive get GNU GRUB ver 2.02 prompt [ABANDONED]  (Read 778 times)
Offline sdgengineer
  • Forum User
    • Scott Gardner PE
  • Peppermint version(s): 1, 3, 4, 5, 6, 8, 9
Greetings
I have this Asus TP2000s with Win 10 on it.  the small hard drive is full, but it has an SD card slot also.  So I tried installing Peppermint 9 on the SD card.  I partitioned the 32 GB  SD card as ext 4.  installed peppermint on it, and when I rebooted  I got a blank screen with a flashing cursor.   So I rebooted and hit the escape key, and brouht up a bios boot menu.  I booted successfully on windows 10, a good thing.  But when I selected ubuntu, I get a grub prompt  Version 2.02.  with a grub> prompt
I did go into the bios and change the boot order  for windows first.  but if I hit esc I can change which device boots first.  I was asked when I installed peppermint when I wanted the grub menu, and I accepted the default which is on the windows drive.
I did an ls and got the following response.
(hd0) (hd0,gpt4) (hd0,gpt3) (hd0,gpt2) (hd0,gpt1)
What command should I use to launch peppermint or can I do this, or do I need to start over?
Thanks
« Last Edit: December 06, 2018, 09:01:01 am by sdgengineer »
No Job is impossible for the  person who doesn't have to do it!
Re: Peppermint 9 on Asus notebook SD Drive get GNU GRUB ver 2.02 prompt
« Reply #1 on: December 05, 2018, 11:57:23 am »
Did you actually boot the Peppermint live USB on that machine? If so, can you give us the output of
Offline sdgengineer
  • Forum User
    • Scott Gardner PE
« Reply #2 on: December 05, 2018, 12:14:57 pm »
Yes, thanks for your quick response
her is the result of  that command:
System:    Host: peppermint Kernel: 4.15.0-23-generic x86_64 bits: 64 Desktop: N/A
           Distro: Peppermint Nine
Machine:   Device: laptop System: ASUSTeK product: E205SA v: 1.0 serial: N/A
           Mobo: ASUSTeK model: E205SA v: 1.0 serial: N/A
           UEFI: American Megatrends v: E205SA.303 date: 06/14/2017
Battery    BAT0: charge: 36.6 Wh 99.3% condition: 36.9/38.0 Wh (97%)
CPU:       Dual core Intel Celeron N3060 (-MCP-) cache: 1024 KB
           clock speeds: max: 2480 MHz 1: 555 MHz 2: 765 MHz
Graphics:  Card: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller
           Resolution: 1366x768@59.99hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 400 (Braswell)
           version: 4.5 Mesa 18.0.0-rc5
Audio:     Card Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Def. Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.15.0-23-generic
Network:   Card: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
           driver: ath10k_pci
Drives:    HDD Total Size: 2.0GB (Used Error!)
           ID-1: /dev/mmcblk0 model: N/A size: 31.3GB
           ID-2: USB /dev/sda model: USB_DISK size: 2.0GB
           ID-3: /dev/mmcblk1 model: N/A size: 32.0GB
Partition: ID-1: / size: 1.9G used: 68M (4%) fs: overlay dev: N/A
           ID-2: swap-1 size: 1.01GB used: 0.00GB (0%) fs: swap dev: /dev/zram0
           ID-3: swap-2 size: 1.01GB used: 0.00GB (0%) fs: swap dev: /dev/zram1
Sensors:   System Temperatures: cpu: 35.0C mobo: 0.0C
           Fan Speeds (in rpm): cpu: 25500
Info:      Processes: 171 Uptime: 10 min Memory: 667.9/3849.6MB
The /dev/mmcblk0 is the windows drive.
« Last Edit: December 05, 2018, 12:17:48 pm by sdgengineer »
« Reply #3 on: December 05, 2018, 12:19:38 pm »
That looks like your SD card is not being seen at the time of boot, which could mean no drivers are loaded for the card reader.
EDIT: I'm not sure though. Did you have a USB drive plugged in when you got that?
Offline sdgengineer
  • Forum User
    • Scott Gardner PE
« Reply #4 on: December 05, 2018, 12:38:04 pm »
Yes,   I Had the usb installed it with when I ran it.  Let me rerun it after I remove the USB drive I used to install it.
here is the result with the install USB drive removed:
           clock speeds: max: 2480 MHz 1: 1006 MHz 2: 500 MHz
           driver: ath10k_pci
Drives:    HDD Total Size: NA (-)
           ID-2: /dev/mmcblk1 model: N/A size: 32.0GB
Partition: ID-1: / size: 1.9G used: 74M (4%) fs: overlay dev: N/A
Info:      Processes: 168 Uptime: 38 min Memory: 687.6/3849.6MB
« Last Edit: December 05, 2018, 12:41:20 pm by sdgengineer »
« Reply #5 on: December 05, 2018, 12:44:27 pm »
I meant the "ls" when you got the GRUB prompt.
It might be worth reading the tips here, this might have a similar BIOS:
http://www.transformerforums.com/forum/asus-transformer-book-t200-alternate-os-s-development/49427-tp200sa-linux-success.html
Offline sdgengineer
  • Forum User
    • Scott Gardner PE
« Reply #6 on: December 05, 2018, 12:53:00 pm »
Sorry!   yes I had the USB drive removed when I got the result of the ls command.  I see there is no hd1 listed.  Only the Win 10 Hard Drive.  I may not be able to dual boot.
I will read the thread you mentioned...Thanks.
« Last Edit: December 05, 2018, 01:06:31 pm by sdgengineer »
« Reply #7 on: December 05, 2018, 01:19:19 pm »
Yes, some devices just can't boot from an external SD. I'd suggest installing Peppermint to the fastest USB drive you can use.
There might be a different boot manager you could use but only if it includes the drivers for the SD reader. I don't know.
Offline sdgengineer
  • Forum User
    • Scott Gardner PE
OK Based on everything I have read I can't dual boot this device. I have gone back to Win 10,  I appreciate the effort murraymint went to research this issue, Even though I have an SD card with a large drive, the BIOS doesn't load it at startup.   :'( .    I will continue to research if there is some way to load it from an SD card.  perhaps a way to load it as a persistent image. My question to the forum is should I mark this solved?
Thanks for a great forum.
« Last Edit: December 06, 2018, 03:25:12 pm by sdgengineer »
« Reply #9 on: December 06, 2018, 08:49:43 am »
You can dual boot via USB can't you? Peppermint can be fully installed to a USB stick/SSD/hard drive.
I wouldn't mark it solved but something like [ABANDONED] has been used before.
Offline sdgengineer
  • Forum User
    • Scott Gardner PE
Re:Peppermint 9 on Asus notebook SD Drive GNU GRUB ver 2.02 prompt [ABANDONED]
« Reply #10 on: December 06, 2018, 09:03:22 am »
will do
« Reply #11 on: December 06, 2018, 09:41:13 am »
Have a look here for an idea of what I was talking about:
https://sourceforge.net/p/refind/discussion/general/thread/f6e24cea/
