Author Topic: USB Sticks won't Load  (Read 1230 times)
Offline wmshay6
  • Peppermint version(s): P9
« on: December 02, 2018, 08:18:19 am »
P9 on two different machines, so I don't think it's a hardware issued.  Tried two different sticks,
They show up under "disks" but are otherwise inaccessible to put content on or off of them.  They won;t load so as to be usable for files, etc.
Both worked fine on these machines before and work fine at my work PC (Win10)
What did I change by mistake and / or what am I doing wrong?
Re: USB Sticks won't Load
« Reply #1 on: December 02, 2018, 09:17:39 am »
Do they show up in the left-hand column of the file manager (click on the icon like a drawer of a filing cabinet, near the menu button)?
Offline wmshay6
« Reply #2 on: December 02, 2018, 11:21:22 am »
No.  Thy only show up under Menu->settings-> disks. But I can't do anything with them there.  They do NOT show up in File Manager.  Weird.
« Reply #3 on: December 02, 2018, 11:30:42 am »
You could try this to have the behaviour that was in Peppermint 8
https://forum.peppermintos.com/index.php/topic,7102.0.html
if that's what you want.
Offline wmshay6
« Reply #4 on: December 02, 2018, 11:55:41 am »
I can do it manually since that appears to keep the install smaller which is my goal. I'll try to find some directions on how to manually mount them . . . .
« Last Edit: December 02, 2018, 12:00:30 pm by wmshay6 »
« Reply #5 on: December 02, 2018, 02:30:22 pm »
So they're NOT showing up under "Devices" in the file manager .. like this:-
Offline wmshay6
« Reply #6 on: December 02, 2018, 06:18:50 pm »
Correct, they do NOT show up under devices.  Only under Menu->settings->disks,  And the only option available there is to power them off, I can;t do ANYTHNG else with them.  And again, two different USB sticks on two different machines running P9,
Niw that you mention it, I don;t even have "devices" on my tree.
« Reply #7 on: December 02, 2018, 08:15:06 pm »
In the file manager, if you go to
View > Sidebar
Is "Places" selected ?
Offline wmshay6
« Reply #8 on: December 03, 2018, 01:36:06 pm »
Yes.  I was able to get one of them to show finally after formatting it .  The other one?  Who knows, I think it may have given up the ghost because it won't show anywhere now.
Anyway, thanks for the help.  I got one of them back (the importatnt one).
Online rayzer
  • Onnnn the Pep 10..
« Reply #9 on: December 04, 2018, 03:26:44 pm »
i find formatting usbs to ntfs tends to work the best, also check if the usb mount tools like pmount are installed. its a weird issue ive encountered a few times
For wallpapers ive made you can download them here https://flickr.com/photos/92410488@N03/
