Author Topic: Headphone jack issue (Solved)  (Read 606 times)
Offline markba633csi
  • Peppermint version(s): 6.0
« on: November 27, 2018, 11:22:12 pm »
Strange problem: unable to plug headphones 3.5mm plug fully home, no sound if I do. Inserting plug partway gives sound, sometimes with internal speaker, sometimes not (touchy)
I'm thinking it must be a bad jack- is there a chance it could be software related?  Phones check out fine on many other devices.  I'm stumped.  Jack looks fine inside, no broken or corroded prongs apparent.   I know some Thinkpad machines use a "combo jack" but not this one, it has separate mic and phones.
Still using and happy with Peppermint 6.
Thinkpad T400
2.4 Ghz core 2 duo, 4 Gig ram
Mark S.
« Last Edit: November 28, 2018, 08:20:12 pm by markba633csi »
Re: Headphone jack issue
« Reply #1 on: November 28, 2018, 08:04:07 am »
Not all 3.5mm jacks are identical. Have you tried a different pair of headphones?
Re: Headphone jack issue (Solved)
« Reply #2 on: November 28, 2018, 08:19:36 pm »
Must be a jack failure, second pair of phones gives same result-  I'll check the schematic and look for a used motherboard for parts- I have desoldering equipment and some experience using it (former re-work tech)
Mark
