Author Topic: IRQ issues  (Read 1577 times)
Offline Brotherred
  • No0b
  • Peppermint version(s): Pep 8 on 386, Pep 10 on AMD 64
IRQ issues
« on: November 17, 2018, 01:14:33 am »
I have had IRQ issues going on for a while. With games crashing other things. I have finally figured out that these crashes are really problems with some hardware mainly a wireless mouse and wireless game controller but just now I also have my HDMI port also reporting a firmware bug in the logs. I really enjoy these wireless devices but first I need to try and figure out this HDMI thing. I use the HDMI out to my TV a lot as of late.
Here are the logs where I searched for HDMI and the Wireless mouse also looked troublesome. I do not know for sure if the mouse is a problem on its own, but I do use it at about the same time as my wireless game controller.
System log for the HDMI
Nov 17 03:07:06 TouchyPenquen kernel: [    0.065898] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
Nov 17 03:07:06 TouchyPenquen kernel: [    0.068217] ACPI: Executed 1 blocks of module-level executable AML code
Nov 17 03:07:06 TouchyPenquen kernel: [    0.080437] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Nov 17 03:07:06 TouchyPenquen kernel: [    0.180973] ACPI: EC: EC started
Nov 17 03:07:06 TouchyPenquen systemd[1]: Started File System Check on /dev/disk/by-uuid/3E22-7EC5.
Nov 17 03:07:06 TouchyPenquen kernel: [    0.180974] ACPI: EC: interrupt blocked
Nov 17 03:07:06 TouchyPenquen kernel: [    0.190071] ACPI: \_SB_.PCI0.LPC0.EC0_: Used as first EC
Nov 17 03:07:06 TouchyPenquen systemd[1]: Mounting /boot/efi...
Nov 17 03:07:06 TouchyPenquen kernel: [    0.190074] ACPI: \_SB_.PCI0.LPC0.EC0_: GPE=0x3, EC_CMD/EC_SC=0x66, EC_DATA=0x62
Nov 17 03:07:06 TouchyPenquen kernel: [    0.190076] ACPI: \_SB_.PCI0.LPC0.EC0_: Used as boot DSDT EC to handle transactions
Nov 17 03:07:06 TouchyPenquen kernel: [    0.190076] ACPI: Interpreter enabled
Nov 17 03:07:06 TouchyPenquen kernel: [    0.190107] ACPI: (supports S0 S3 S4 S5)
Nov 17 03:07:06 TouchyPenquen systemd[1]: Mounted /mnt/data.
Nov 17 03:07:06 TouchyPenquen kernel: [    0.190109] ACPI: Using IOAPIC for interrupt routing
Nov 17 03:07:06 TouchyPenquen systemd[1]: Mounted /boot/efi.
Nov 17 03:07:06 TouchyPenquen kernel: [    0.190366] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
For the Wireless mouse
Nov 17 03:07:06 TouchyPenquen kernel: [    2.331871] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Nov 17 03:07:06 TouchyPenquen kernel: [    2.331873] ehci-pci: EHCI PCI platform driver
Nov 17 03:07:06 TouchyPenquen kernel: [    2.332249] QUIRK: Enable AMD PLL fix
Nov 17 03:07:06 TouchyPenquen kernel: [    2.332280] ehci-pci 0000:00:12.2: EHCI Host Controller
Nov 17 03:07:06 TouchyPenquen kernel: [    2.332289] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 1
Nov 17 03:07:06 TouchyPenquen kernel: [    2.332295] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
Nov 17 03:07:06 TouchyPenquen kernel: [    2.332305] ehci-pci 0000:00:12.2: debug port 1
Nov 17 03:07:06 TouchyPenquen kernel: [    2.332360] ehci-pci 0000:00:12.2: irq 17, io mem 0xf044c000
Nov 17 03:07:06 TouchyPenquen kernel: [    2.348187] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
Nov 17 03:07:06 TouchyPenquen kernel: [    2.348521] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Nov 17 03:07:06 TouchyPenquen kernel: [    2.348524] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 17 03:07:06 TouchyPenquen kernel: [    2.348526] usb usb1: Product: EHCI Host Controller
Nov 17 03:07:06 TouchyPenquen kernel: [    2.348528] usb usb1: Manufacturer: Linux 4.15.0-39-generic ehci_hcd
Nov 17 03:07:06 TouchyPenquen kernel: [    2.348529] usb usb1: SerialNumber: 0000:00:12.2
Nov 17 03:07:06 TouchyPenquen kernel: [    2.348931] hub 1-0:1.0: USB hub found
Nov 17 03:07:06 TouchyPenquen kernel: [    2.349000] hub 1-0:1.0: 5 ports detected
Nov 17 03:07:06 TouchyPenquen kernel: [    2.349820] ehci-pci 0000:00:13.2: EHCI Host Controller
Nov 17 03:07:06 TouchyPenquen kernel: [    2.349826] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 2
Nov 17 03:07:06 TouchyPenquen kernel: [    2.349831] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
Nov 17 03:07:06 TouchyPenquen kernel: [    2.349841] ehci-pci 0000:00:13.2: debug port 1
Nov 17 03:07:06 TouchyPenquen kernel: [    2.349875] ehci-pci 0000:00:13.2: irq 17, io mem 0xf044a0
inxi A
CPU~Quad core AMD A10-5745M APU with Radeon HD Graphics (-MCP-) speed/max~1132/2100 MHz Kernel~4.15.0-39-generic x86_64 Up~9 min Mem~1530.6/5165.7MB HDD~750.2GB(4.2% used) Procs~192 Client~Shell inxi~2.3.56
cableguy@TouchyPenquen ~ $
I will mark my other threads related to this topic CLOSED with a link  to this post. Unfortunately the laptop just crashed in writing this post. I will need to do a reformat reinstall before tomorrow.
Re: IRQ issues
« Reply #1 on: November 17, 2018, 11:12:37 am »
What makes you suspect IRQ issues ?
Offline Brotherred
  • No0b
Re: IRQ issues
« Reply #2 on: November 17, 2018, 12:52:18 pm »
Because the OS stalls or sleeps with out any recovery options as I have described in my other threads. This is the result of my looking or attempting to look at the logs as you requested some time ago.
In the portion of the syslog pertaining to the HDMI a bug appears to be a mentioned.
Just now however on this fresh install it crashed and I don't have any of those devices plugged in. It has not done this before...
The history of these failures doesn't seem like this most recent crash. I don't know why in the end.
Sent from my SM-N920V using Tapatalk
Offline Brotherred
  • No0b
Re: IRQ issues
« Reply #3 on: November 17, 2018, 04:36:34 pm »
https://www.dropbox.com/s/tly0p2jk8vudc60/20181117_125914.jpg?dl=0
https://www.dropbox.com/s/7xeinmtl0kdpz1d/20181117_125911.jpg?dl=0
I know that those are pitchers from a LIVE instance. This one was harder to get and is not as clear.
« Last Edit: November 18, 2018, 05:00:26 am by PCNetSpec »
Re: IRQ issues
« Reply #4 on: November 18, 2018, 05:03:44 am »
Can we have the full output from
inxi -Fzand the output from
dmesg | grep -i irqIs it ONLY games that crash the system ?
And when the system crashes, are you able to recover if you hit Ctrl+Alt+F2 (to drop to a console) .. log on in text mode .. then run:
sudo service lightdm restart?
« Last Edit: November 18, 2018, 05:12:46 am by PCNetSpec »
Offline Brotherred
  • No0b
Re: IRQ issues
« Reply #5 on: November 18, 2018, 01:17:14 pm »
Thank you for your time on this. I know that with everything you keep very busy and this is a mess.
System:    Host: TouchyPenquen Kernel: 4.15.0-39-generic x86_64 bits: 64 Desktop: N/A Distro: Peppermint Nine
Machine:   Device: laptop System: Hewlett-Packard product: HP ENVY TS m6 Sleekbook v: 0883100022305B00000320100 serial: N/A
           Mobo: Hewlett-Packard model: 1995 v: 04.50 serial: N/A UEFI: Insyde v: F.18 date: 10/08/2015
Battery    BAT1: charge: 30.1 Wh 82.7% condition: 36.4/36.4 Wh (100%)
CPU:       Quad core AMD A10-5745M APU with Radeon HD Graphics (-MCP-) cache: 8192 KB
           clock speeds: max: 2100 MHz 1: 1172 MHz 2: 1218 MHz 3: 1223 MHz 4: 1131 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Richland [Radeon HD 8610G]
           Display Server: x11 (X.Org 1.19.6 ) drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
           Resolution: 1366x768@60.03hz
           OpenGL: rendTerer: AMD ARUBA (DRM 2.50.0 / 4.15.0-39-generic, LLVM 6.0.0) version: 4.3 Mesa 18.0.5
Audio:     Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller driver: snd_hda_intel
           Card-2 Advanced Micro Devices [AMD/ATI] Trinity HDMI Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.15.0-39-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
           Card-2: Ralink RT3290 Wireless 802.11n 1T/1R PCIe driver: rt2800pci
Drives:    HDD Total Size: 750.2GB (4.3% used)
           ID-1: /dev/sda model: ST750LM022_HN size: 750.2GB
Partition: ID-1: / size: 178G used: 5.6G (4%) fs: ext4 dev: /dev/sda10
           ID-2: /home size: 9.7G used: 8.8G (97%) fs: ext4 dev: /dev/sda2
           ID-3: /boot size: 831M used: 152M (20%) fs: ext4 dev: /dev/sda11
           ID-4: swap-1 size: 2.96GB used: 0.00GB (0%) fs: swap dev: /dev/sda12
Sensors:   System Temperatures: cpu: 53.0C mobo: 20.0C gpu: 54.0
Info:      Processes: 178 Uptime: 1:03 Memory: 769.0/5165.7MB Client: Shell (bash) inxi: 2.3.56
dmesg | grep -i irq
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] NR_IRQS: 524544, nr_irqs: 456, preallocated irqs: 16
[    0.004000] do_IRQ: 1.55 No irq handler for vector
[    0.004000] do_IRQ: 2.55 No irq handler for vector
[    0.004000] do_IRQ: 3.55 No irq handler for vector
[    0.408912] ACPI: IRQ 7 override to edge, high
[    0.497000] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.497102] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.497279] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.497391] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.497496] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.497577] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.497657] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.497738] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.524072] PCI: Using ACPI for IRQ routing
[    0.528776] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    2.311552] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    2.319521] ehci-pci 0000:00:12.2: irq 17, io mem 0xf044c000
[    2.333762] ehci-pci 0000:00:13.2: irq 17, io mem 0xf044a000
[    2.350015] ohci-pci 0000:00:12.0: irq 18, io mem 0xf044d000
[    2.413018] ohci-pci 0000:00:13.0: irq 18, io mem 0xf044b000
[    2.481188] i8042: PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    2.492639] serio: i8042 KBD port at 0x60,0x64 irq 1
[    2.492643] serio: i8042 AUX port at 0x60,0x64 irq 12
[    2.493243] rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs
[    3.630442] r8169 0000:01:00.0 eth0: RTL8168g/8111g at 0x        (ptrval), a0:48:1c:d1:7b:71, XID 0c000800 IRQ 31
[    3.630864] ata1: SATA max UDMA/133 abar m2048@0xf044e000 port 0xf044e100 irq 29
[    3.767101] [drm] radeon: irq initialized.
No sorry it is not just the games that crash the system. I usually am playing Hulu streams with with my HDMI out port. I have not been able to drop to a shell prompt after a crash for some time. When I was able to do that I was not using the HDMI.
I am unsure what to do with this. This looks like code you are requesting in the event of a crash which I hopefully will be able to recover by dropping to a prompt and running that command.
For that all I can say is I will try. Up until now I have not been able to recover at all when I am using HDMI.
Regards
Offline Brotherred
  • No0b
Re: IRQ issues
« Reply #6 on: November 19, 2018, 03:17:38 am »
OK this just happened. I was watching Hulu via HDMI out as I have been doing lately. The system crashed as I have been describing. I did forget to try to drop to a prompt but as I say that has failed before. When the system crashed I checked the time and it was 5:23Am by my watch. So I looked for that time in the log, the closest I got was 5:25. I then searched for Firefox because I have made an ICE hulu application with Firefox. But then the system crashed while posting this. I copied and pasted as much of the file as I could. Regards
Nov 19 05:25:21 TouchyPenquen apparmor[626]: Skipping profile in /etc/apparmor.d/disable: usr.bin.firefox
Nov 19 05:25:21 TouchyPenquen kernel: [    0.057246] pinctrl core: initialized pinctrl subsystem
Nov 19 05:25:21 TouchyPenquen kernel: [    0.057246] RTC time: 10:24:36, date: 11/19/18
Nov 19 05:25:21 TouchyPenquen kernel: [    0.060007] NET: Registered protocol family 16
Nov 19 05:25:21 TouchyPenquen apparmor[626]: Skipping profile in /etc/apparmor.d/disable: usr.sbin.rsyslogd
Nov 19 05:25:21 TouchyPenquen kernel: [    0.060007] audit: initializing netlink subsys (disabled)
Nov 19 05:25:21 TouchyPenquen systemd[1]: Started Update UTMP about System Boot/Shutdown.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.060055] audit: type=2000 audit(1542623076.060:1): state=initialized audit_enabled=0 res=1
Nov 19 05:25:21 TouchyPenquen systemd[1]: Started Network Time Synchronization.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.060163] cpuidle: using governor ladder
Nov 19 05:25:21 TouchyPenquen kernel: [    0.060163] cpuidle: using governor menu
Nov 19 05:25:21 TouchyPenquen kernel: [    0.060163] Simple Boot Flag at 0x44 set to 0x1
Nov 19 05:25:21 TouchyPenquen kernel: [    0.060163] ACPI: bus type PCI registered
Nov 19 05:25:21 TouchyPenquen systemd[1]: Reached target System Time Synchronized.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.060163] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Nov 19 05:25:21 TouchyPenquen kernel: [    0.060235] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
Nov 19 05:25:21 TouchyPenquen systemd-resolved[640]: Positive Trust Anchors:
Nov 19 05:25:21 TouchyPenquen kernel: [    0.060248] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
Nov 19 05:25:21 TouchyPenquen kernel: [    0.060248] PCI: Using configuration type 1 for base access
Nov 19 05:25:21 TouchyPenquen kernel: [    0.061866] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Nov 19 05:25:21 TouchyPenquen systemd-resolved[640]: . IN DS 19036 8 2 49aac11d7b6f6446702e54a1607371607a1a41855200fd2ce1cdde32f24e8fb5
Nov 19 05:25:21 TouchyPenquen kernel: [    0.061866] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Nov 19 05:25:21 TouchyPenquen kernel: [    0.061866] ACPI: Added _OSI(Module Device)
Nov 19 05:25:21 TouchyPenquen kernel: [    0.061866] ACPI: Added _OSI(Processor Device)
Nov 19 05:25:21 TouchyPenquen systemd-resolved[640]: . IN DS 20326 8 2 e06d44b80b8f1d39a95c0b0d7c65d08458e880409bbc683457104237c7f8ec8d
Nov 19 05:25:21 TouchyPenquen kernel: [    0.061866] ACPI: Added _OSI(3.0 _SCP Extensions)
Nov 19 05:25:21 TouchyPenquen kernel: [    0.061866] ACPI: Added _OSI(Processor Aggregator Device)
Nov 19 05:25:21 TouchyPenquen kernel: [    0.061866] ACPI: Added _OSI(Linux-Dell-Video)
Nov 19 05:25:21 TouchyPenquen systemd-resolved[640]: Negative trust anchors: 10.in-addr.arpa 16.172.in-addr.arpa 17.172.in-addr.arpa 18.172.in-addr.arpa 19.172.in-addr.arpa 20.172.in-addr.arpa 21.172.in-addr.arpa 22.172.in-addr.arpa 23.172.in-addr.arpa 24.172.in-addr.arpa 25.172.in-addr.arpa 26.172.in-addr.arpa 27.172.in-addr.arpa 28.172.in-addr.arpa 29.172.in-addr.arpa 30.172.in-addr.arpa 31.172.in-addr.arpa 168.192.in-addr.arpa d.f.ip6.arpa corp home internal intranet lan local private test
Nov 19 05:25:21 TouchyPenquen kernel: [    0.061866] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
Nov 19 05:25:21 TouchyPenquen systemd-resolved[640]: Using system hostname 'TouchyPenquen'.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.064102] ACPI: Executed 1 blocks of module-level executable AML code
Nov 19 05:25:21 TouchyPenquen kernel: [    0.076407] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Nov 19 05:25:21 TouchyPenquen kernel: [    0.177181] ACPI: EC: EC started
Nov 19 05:25:21 TouchyPenquen systemd[1]: Started Network Name Resolution.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.177183] ACPI: EC: interrupt blocked
Nov 19 05:25:21 TouchyPenquen kernel: [    0.182109] ACPI: \_SB_.PCI0.LPC0.EC0_: Used as first EC
Nov 19 05:25:21 TouchyPenquen kernel: [    0.182111] ACPI: \_SB_.PCI0.LPC0.EC0_: GPE=0x3, EC_CMD/EC_SC=0x66, EC_DATA=0x62
Nov 19 05:25:21 TouchyPenquen systemd[1]: Reached target Host and Network Name Lookups.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.182113] ACPI: \_SB_.PCI0.LPC0.EC0_: Used as boot DSDT EC to handle transactions
Nov 19 05:25:21 TouchyPenquen systemd[1]: Started RPC bind portmap service.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.182114] ACPI: Interpreter enabled
Nov 19 05:25:21 TouchyPenquen kernel: [    0.182145] ACPI: (supports S0 S3 S4 S5)
Nov 19 05:25:21 TouchyPenquen kernel: [    0.182147] ACPI: Using IOAPIC for interrupt routing
Nov 19 05:25:21 TouchyPenquen systemd[1]: Reached target Remote File Systems (Pre).
Nov 19 05:25:21 TouchyPenquen kernel: [    0.182448] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Nov 19 05:25:21 TouchyPenquen kernel: [    0.184337] ACPI: Enabled 6 GPEs in block 00 to 1F
Nov 19 05:25:21 TouchyPenquen kernel: [    0.280845] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
Nov 19 05:25:21 TouchyPenquen kernel: [    0.280853] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.280859] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
Nov 19 05:25:21 TouchyPenquen systemd[1]: Reached target Remote File Systems.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.280876] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281311] PCI host bridge to bus 0000:00
Nov 19 05:25:21 TouchyPenquen systemd[1]: Reached target RPC Port Mapper.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281314] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281316] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281317] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281319] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281321] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
Nov 19 05:25:21 TouchyPenquen apparmor[626]:    ...done.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281322] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
Nov 19 05:25:21 TouchyPenquen systemd[1]: Started AppArmor initialization.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281324] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281325] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281327] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281328] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
Nov 19 05:25:21 TouchyPenquen systemd[1]: Reached target System Initialization.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281330] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281331] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281333] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
Nov 19 05:25:21 TouchyPenquen systemd[1]: Listening on UUID daemon activation socket.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281334] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
Nov 19 05:25:21 TouchyPenquen systemd[1]: Starting Socket activation for snappy daemon.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281336] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281337] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xf7ffffff window]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281339] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfed3ffff window]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281340] pci_bus 0000:00: root bus resource [mem 0xfed45000-0xffffffff window]
Nov 19 05:25:21 TouchyPenquen systemd[1]: Started Trigger anacron every hour.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281342] pci_bus 0000:00: root bus resource [bus 00-ff]
Nov 19 05:25:21 TouchyPenquen systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281351] pci 0000:00:00.0: [1022:1410] type 00 class 0x060000
Nov 19 05:25:21 TouchyPenquen systemd[1]: Listening on D-Bus System Message Bus Socket.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281538] pci 0000:00:01.0: [1002:990f] type 00 class 0x030000
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281551] pci 0000:00:01.0: reg 0x10: [mem 0xe0000000-0xefffffff pref]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281556] pci 0000:00:01.0: reg 0x14: [io  0x4000-0x40ff]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281562] pci 0000:00:01.0: reg 0x18: [mem 0xf0400000-0xf043ffff]
Nov 19 05:25:21 TouchyPenquen systemd[1]: Listening on CUPS Scheduler.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281581] pci 0000:00:01.0: enabling Extended Tags
Nov 19 05:25:21 TouchyPenquen systemd[1]: Started CUPS Scheduler.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281591] pci 0000:00:01.0: BAR 0: assigned to efifb
Nov 19 05:25:21 TouchyPenquen systemd[1]: Started Discard unused blocks once a week.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281611] pci 0000:00:01.0: supports D1 D2
Nov 19 05:25:21 TouchyPenquen systemd[1]: Started ACPI Events Check.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281702] pci 0000:00:01.1: [1002:9902] type 00 class 0x040300
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281714] pci 0000:00:01.1: reg 0x10: [mem 0xf0444000-0xf0447fff]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281740] pci 0000:00:01.1: enabling Extended Tags
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281767] pci 0000:00:01.1: supports D1 D2
Nov 19 05:25:21 TouchyPenquen systemd[1]: Reached target Paths.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281903] pci 0000:00:04.0: [1022:1414] type 01 class 0x060400
Nov 19 05:25:21 TouchyPenquen systemd[1]: Started Daily Cleanup of Temporary Directories.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281927] pci 0000:00:04.0: enabling Extended Tags
Nov 19 05:25:21 TouchyPenquen systemd[1]: Started Daily apt download activities.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.281957] pci 0000:00:04.0: PME# supported from D0 D3hot D3cold
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282054] pci 0000:00:05.0: [1022:1415] type 01 class 0x060400
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282078] pci 0000:00:05.0: enabling Extended Tags
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282107] pci 0000:00:05.0: PME# supported from D0 D3hot D3cold
Nov 19 05:25:21 TouchyPenquen systemd[1]: Started Daily apt upgrade and clean activities.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282252] pci 0000:00:07.0: [1022:1417] type 01 class 0x060400
Nov 19 05:25:21 TouchyPenquen systemd[1]: Listening on ACPID Listen Socket.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282275] pci 0000:00:07.0: enabling Extended Tags
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282304] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
Nov 19 05:25:21 TouchyPenquen systemd[1]: Reached target Timers.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282458] pci 0000:00:10.0: [1022:7814] type 00 class 0x0c0330
Nov 19 05:25:21 TouchyPenquen systemd[1]: Listening on Socket activation for snappy daemon.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282488] pci 0000:00:10.0: reg 0x10: [mem 0xf0448000-0xf0449fff 64bit]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282599] pci 0000:00:10.0: PME# supported from D0 D3hot D3cold
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282752] pci 0000:00:11.0: [1022:7804] type 00 class 0x010601
Nov 19 05:25:21 TouchyPenquen systemd[1]: Reached target Sockets.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282773] pci 0000:00:11.0: reg 0x10: [io  0x4118-0x411f]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282782] pci 0000:00:11.0: reg 0x14: [io  0x4124-0x4127]
Nov 19 05:25:21 TouchyPenquen systemd[1]: Reached target Basic System.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282791] pci 0000:00:11.0: reg 0x18: [io  0x4110-0x4117]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282800] pci 0000:00:11.0: reg 0x1c: [io  0x4120-0x4123]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282809] pci 0000:00:11.0: reg 0x20: [io  0x4100-0x410f]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.282818] pci 0000:00:11.0: reg 0x24: [mem 0xf044e000-0xf044e7ff]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.283027] pci 0000:00:12.0: [1022:7807] type 00 class 0x0c0310
Nov 19 05:25:21 TouchyPenquen systemd[1]: Starting mintsystem.service...
Nov 19 05:25:21 TouchyPenquen kernel: [    0.283044] pci 0000:00:12.0: reg 0x10: [mem 0xf044d000-0xf044dfff]
Nov 19 05:25:21 TouchyPenquen systemd[1]: Starting LSB: Record successful boot for GRUB...
Nov 19 05:25:21 TouchyPenquen kernel: [    0.283236] pci 0000:00:12.2: [1022:7808] type 00 class 0x0c0320
Nov 19 05:25:21 TouchyPenquen kernel: [    0.285965] pci 0000:00:12.2: reg 0x10: [mem 0xf044c000-0xf044c0ff]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.310004] pci 0000:00:12.2: supports D1 D2
Nov 19 05:25:21 TouchyPenquen kernel: [    0.310006] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot D3cold
Nov 19 05:25:21 TouchyPenquen kernel: [    0.310152] pci 0000:00:13.0: [1022:7807] type 00 class 0x0c0310
Nov 19 05:25:21 TouchyPenquen systemd[1]: Starting Modem Manager...
Nov 19 05:25:21 TouchyPenquen kernel: [    0.310171] pci 0000:00:13.0: reg 0x10: [mem 0xf044b000-0xf044bfff]
Nov 19 05:25:21 TouchyPenquen systemd[1]: Starting System Logging Service...
Nov 19 05:25:21 TouchyPenquen kernel: [    0.310334] pci 0000:00:13.2: [1022:7808] type 00 class 0x0c0320
Nov 19 05:25:21 TouchyPenquen kernel: [    0.317959] pci 0000:00:13.2: reg 0x10: [mem 0xf044a000-0xf044a0ff]
Nov 19 05:25:21 TouchyPenquen systemd[1]: Starting Detect the available GPUs and deal with any system changes...
Nov 19 05:25:21 TouchyPenquen kernel: [    0.346005] pci 0000:00:13.2: supports D1 D2
Nov 19 05:25:21 TouchyPenquen systemd[1]: Starting Dispatcher daemon for systemd-networkd...
Nov 19 05:25:21 TouchyPenquen kernel: [    0.346007] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot D3cold
Nov 19 05:25:21 TouchyPenquen kernel: [    0.346153] pci 0000:00:14.0: [1022:780b] type 00 class 0x0c0500
Nov 19 05:25:21 TouchyPenquen kernel: [    0.346366] pci 0000:00:14.2: [1022:780d] type 00 class 0x040300
Nov 19 05:25:21 TouchyPenquen systemd[1]: Started D-Bus System Message Bus.
Nov 19 05:25:21 TouchyPenquen kernel: [    0.346391] pci 0000:00:14.2: reg 0x10: [mem 0xf0440000-0xf0443fff 64bit]
Nov 19 05:25:21 TouchyPenquen kernel: [    0.346458] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
Nov 19 05:25:21 TouchyPenquen rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.32.0]
Nov 19 05:25:21 TouchyPenquen rsyslogd: rsyslogd's groupid changed to 106
Nov 19 05:25:21 TouchyPenquen rsyslogd: rsyslogd's userid changed to 102
Nov 19 05:25:21 TouchyPenquen rsyslogd:  [origin software="rsyslogd" swVersion="8.32.0" x-pid="709" x-info="http://www.rsyslog.com"] start
Nov 19 05:25:21 TouchyPenquen kernel: [    0.346554] pci 0000:00:14.3: [1022:780e] type 00 class 0x060100
Nov 19 05:25:21 TouchyPenquen kernel: [    0.346749] pci 0000:00:14.4: [1022:780f] type 01 class 0x060401
Nov 19 05:25:21 TouchyPenquen kernel: [    0.346911] pci 0000:00:18.0: [1022:1400] type 00 class 0x060000
Nov 19 05:25:21 TouchyPenquen kernel: [    0.346995] pci 0000:00:18.1: [1022:1401] type 00 class 0x060000
Nov 19 05:25:21 TouchyPenquen kernel: [    0.347077] pci 0000:00:18.2: [1022:1402] type 00 class 0x060000
Nov 19 05:25:21 TouchyPenquen kernel: [    0.347159] pci 0000:00:18.3: [1022:1403] type 00 class 0x060000
Nov 19 05:25:21 TouchyPenquen kernel: [    0.347245] pci 0000:00:18.4: [1022:1404] type 00 class 0x060000
Nov 19 05:25:21 TouchyPenquen kernel: [    0.347328] pci 0000:00:18.5: [1022:1405] type 00 class 0x060000
Nov 19 05:25:21 TouchyPenquen kernel: [    0.348098] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
« Last Edit: November 19, 2018, 03:19:31 am by Brotherred »
