Author Topic: keyboard set to UK, but reverts back to US. (SOLVED)  (Read 2011 times)
Offline worldstream
« on: November 15, 2018, 06:59:52 am »
This is the best distro, but I am in the UK so obviously need UK keyboard layout, but it keeps reverting back to the US-style keyboard.
There was a previous query a while back and he was asked for the output as below. Here's mine
worldstream@worldstream-All-Series ~ $ gedit ~/.config/peppermint-control-center/keyboard_layout
(gedit:5183): GLib-GIO-CRITICAL **: 14:49:46.172: g_dbus_proxy_new: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
worldstream@worldstream-All-Series ~ $ ls -l ~/.config/autostart/peppermint-control-center.desktop
-rwxr-xr-x 1 worldstream worldstream 195 Nov 15 09:24 /home/worldstream/.config/autostart/peppermint-control-center.desktop
I installed alongside Windows 10, so loath to re-install, probably mess up.
« Last Edit: November 15, 2018, 01:37:56 pm by worldstream »
Re: keyboard set to UK, but reverts back to US.
« Reply #1 on: November 15, 2018, 07:19:02 am »
Which version of Peppermint ?
and can you post the output from
cat /etc/default/keyboardand the CONTENTS of
xed ~/.config/xfce4/xfconf/xfce-perchannel-xml/keyboard-layout.xml
« Last Edit: November 15, 2018, 07:27:58 am by PCNetSpec »
Offline worldstream
« Reply #2 on: November 15, 2018, 11:34:13 am »
peppermint 9, just installed.
# KEYBOARD CONFIGURATION FILE
# Consult the keyboard(5) manual page.
XKBMODEL="pc105"
XKBLAYOUT="us"
XKBVARIANT=""
XKBOPTIONS=""
BACKSPACE="guess"
<?xml version="1.0" encoding="UTF-8"?>
<channel name="keyboard-layout" version="1.0">
  <property name="Default" type="empty">
    <property name="XkbDisable" type="bool" value="false"/>
    <property name="XkbOptions" type="empty">
      <property name="Group" type="string" value="grp:lalt_lshift_toggle"/>
    </property>
    </property>
</channel>
Thanks
« Reply #3 on: November 15, 2018, 11:59:24 am »
Run
gksudo xed /etc/default/keyboardmake the file read
XKBMODEL="pc105"
XKBLAYOUT="gb"
XKBVARIANT=""
XKBOPTIONS=""
BACKSPACE="guess"
Right-click the flag on your bottom panel, and select "Keyboard settings"
In the resulting dialog select the "Layouts" tab.
Make sure "Use system defaults" is UNticked.
If the "Keyboard Layouts" box only contains "English (US)", click the "+Add" button .. highlight "English (UK)", and click the "OK" button.
The Keyboard Layouts box should now list both "English (US)" AND "English (UK)" .. highlight "English (US)" and click the "Delete" button.
Click the "Close" button.
Reboot.
Offline worldstream
« Reply #4 on: November 15, 2018, 12:36:26 pm »
Thanks. Easy when you know how.
« Reply #5 on: November 15, 2018, 01:21:23 pm »
No problem my friend :)
If you're happy with the solution, can you please edit the FIRST posting in this topic and change:-
Subject: keyboard set to UK, but reverts back to US. (SOLVED)
Thanks in advance :)
Oh, and welcome to the forum :)
« Last Edit: November 15, 2018, 01:24:02 pm by PCNetSpec »
