Author Topic: was about to update untill... Then it was solved  (Read 1148 times)
Offline hankishenry
« on: November 07, 2018, 11:33:58 am »
Could not download all repository indexes
The repository may no longer be available or could not be contacted because of network problems. If available an older version of the failed index will be used. Otherwise the repository will be ignored. Check your network connection and ensure the repository address in the preferences is correct.
The repository 'cdrom://Peppermint 9 (20180621) - Release amd64 bionic Release' does not have a Release file.
Is everything all right? what does this mean? (in laymen terms)
hear is this if neccesary.
System:    Host: hankishenry-HP-Pavilion-17-Notebook-PC Kernel: 4.15.0-38-generic x86_64
           bits: 64
Machine:   Device: laptop System: Hewlett-Packard product: HP Pavilion 17 Notebook PC v: 0976110000405E00000620180 serial: N/A
           Mobo: Hewlett-Packard model: 1971 v: 95.33 serial: N/A
           UEFI: Insyde v: F.22 date: 01/20/2014
Battery    BAT0: charge: 12.4 Wh 59.0% condition: 21.1/21.1 Wh (100%)
CPU:       Dual core Intel Core i3-3130M (-MT-MCP-) cache: 3072 KB
           clock speeds: max: 2600 MHz 1: 1455 MHz 2: 1556 MHz 3: 1527 MHz
           4: 1527 MHz
Graphics:  Card: Intel 3rd Gen Core processor Graphics Controller
           Resolution: 1600x900@60.19hz
           OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile
           version: 4.2 Mesa 18.0.5
Audio:     Card Intel 7 Series/C216 Family High Def. Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.15.0-38-generic
Network:   Card-1: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
           Card-2: Realtek RTL8101/2/6E PCIE Fast/Gigabit Ethernet controller
           driver: r8169
Drives:    HDD Total Size: 750.2GB (9.2% used)
           ID-1: /dev/sda model: HGST_HTS541075A9 size: 750.2GB
Partition: ID-1: / size: 685G used: 63G (10%) fs: ext4 dev: /dev/dm-1
           ID-2: /boot size: 705M used: 300M (46%) fs: ext4 dev: /dev/sda2
           ID-3: swap-1 size: 1.02GB used: 0.00GB (0%) fs: swap dev: /dev/dm-2
Sensors:   System Temperatures: cpu: 56.0C mobo: N/A
Info:      Processes: 250 Uptime: 3 days Memory: 1527.2/3837.0MB
« Last Edit: November 07, 2018, 06:41:25 pm by hankishenry »
Re: was about to update untill...
« Reply #1 on: November 07, 2018, 03:40:26 pm »
Are you running Peppermint from a LiveUSB ?
if not, what's the contents of
xed /etc/apt/sources.list?
If that file starts with the line
deb cdrom:[Peppermint 9 (20180621) - Release amd64]/ bionic main multiverse restricted universeclose the text editor.
then back in the terminal run:
gksudo xed /etc/apt/sources.listand change the line:-
deb cdrom:[Peppermint 9 (20180621) - Release amd64]/ bionic main multiverse restricted universeto:-
# deb cdrom:[Peppermint 9 (20180621) - Release amd64]/ bionic main multiverse restricted universeSAVE the file, and exit the text editor.
Back in the terminal run:
sudo apt-get updateand you should now get no errors.
« Last Edit: November 07, 2018, 03:42:13 pm by PCNetSpec »
Offline hankishenry
« Reply #2 on: November 07, 2018, 06:40:51 pm »
First off not on a LiveUSB.
it was exactly as you put it so I edited it to have the # in front of the entire thing. then proceeded to update it. and no errors.
THANKS!
Re: was about to update untill... Then it was solved
« Reply #3 on: November 08, 2018, 04:06:53 am »
You're most welcome hankishenry, normally that line gets automatically commented out during the install .. so dunno what happened there :-\
« Reply #4 on: May 28, 2019, 07:57:48 pm »
I'm getting the same message quite frequently.  I don't know what to make of it.
synaptic
The repository 'http://archive.canonical.com/ubuntu bionic Release' no longer has a Release file.
« Reply #5 on: May 28, 2019, 08:04:19 pm »
synaptic
Then I wait a few minutes and everything is back to the way it should be:
perknh@peppermint ~ $ sudo apt update
[sudo] password for perknh:
Sorry, try again.
Hit:1 http://archive.canonical.com/ubuntu bionic InRelease
Get:2 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Hit:3 http://us.archive.ubuntu.com/ubuntu bionic InRelease
Get:4 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Hit:5 http://ppa.launchpad.net/peppermintos/p10-release/ubuntu bionic InRelease
Hit:6 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease
Ign:7 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:8 http://dl.google.com/linux/chrome/deb stable Release
Fetched 177 kB in 2s (82.1 kB/s)
Reading package lists... Done
Building dependency tree
All packages are up to date.
It's a rainy night.  Maybe I am having a network connection problem.  I know I was modifying my post and not double posting.  My connection did experience a hiccup for a moment. :-\
« Last Edit: May 28, 2019, 08:08:59 pm by perknh »
« Reply #6 on: May 28, 2019, 08:11:51 pm »
Could be at your end .. could be the mirror.
« Reply #7 on: May 28, 2019, 08:15:39 pm »
Yeah.  Thanks, PCNetSpec.  Can I run a command to see which mirror I'm using?
« Reply #8 on: May 28, 2019, 08:20:48 pm »
All is clear on the western front...
╭─vindsl@Boogaloo-6 ~
╰─$ sudo apt update
[sudo] password for vindsl:
Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://mirrors.namecheap.com/ubuntu bionic InRelease
Get:3 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Hit:4 http://dl.google.com/linux/chrome/deb stable Release
Hit:5 http://ppa.launchpad.net/alex-p/gimp/ubuntu bionic InRelease
Get:6 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Hit:7 https://s3-us-west-2.amazonaws.com/brave-apt bionic InRelease
Hit:9 http://archive.canonical.com/ubuntu bionic InRelease
Hit:10 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit:11 http://ppa.launchpad.net/anonbeat/guayadeque/ubuntu bionic InRelease
Hit:12 http://ppa.launchpad.net/atareao/atareao/ubuntu bionic InRelease
Hit:13 https://deb.opera.com/opera-beta stable InRelease
Hit:14 https://deb.opera.com/opera-stable stable InRelease
Hit:15 http://ppa.launchpad.net/canonical-kernel-team/proposed/ubuntu bionic InRelease
Hit:16 http://ppa.launchpad.net/danielrichter2007/grub-customizer/ubuntu bionic InRelease
Get:17 https://mega.nz/linux/MEGAsync/xUbuntu_18.04 ./ InRelease [1,487 B]
Hit:18 http://ppa.launchpad.net/eosrei/fonts/ubuntu bionic InRelease
Hit:19 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic InRelease
Hit:20 http://ppa.launchpad.net/mark-pcnetspec/nemo-365-testing/ubuntu bionic InRelease
Hit:21 http://ppa.launchpad.net/netgear-inc/ppa/ubuntu xenial InRelease
Hit:22 http://ppa.launchpad.net/peppermintos/p9-build/ubuntu bionic InRelease
Hit:23 http://ppa.launchpad.net/peppermintos/gimp-2102-testing/ubuntu bionic InRelease
Hit:24 http://ppa.launchpad.net/rvm/smplayer/ubuntu bionic InRelease
Hit:25 http://ppa.launchpad.net/webupd8team/y-ppa-manager/ubuntu bionic InRelease
Hit:26 http://ppa.launchpad.net/yannubuntu/boot-repair/ubuntu bionic InRelease
Fetched 179 kB in 5s (37.5 kB/s)
15 packages can be upgraded. Run 'apt list --upgradable' to see them.
╰─$ apt list --upgradable
Listing... Done
gnome-desktop3-data/bionic-updates,bionic-updates,bionic-security,bionic-security 3.28.2-0ubuntu1.3 all [upgradable from: 3.28.2-0ubuntu1.2]
initramfs-tools/bionic-updates,bionic-updates 0.130ubuntu3.8 all [upgradable from: 0.130ubuntu3.7]
initramfs-tools-bin/bionic-updates 0.130ubuntu3.8 amd64 [upgradable from: 0.130ubuntu3.7]
initramfs-tools-core/bionic-updates,bionic-updates 0.130ubuntu3.8 all [upgradable from: 0.130ubuntu3.7]
libgnome-desktop-3-17/bionic-updates,bionic-security 3.28.2-0ubuntu1.3 amd64 [upgradable from: 3.28.2-0ubuntu1.2]
libsmbclient/bionic-updates,bionic-security 2:4.7.6+dfsg~ubuntu-0ubuntu2.11 amd64 [upgradable from: 2:4.7.6+dfsg~ubuntu-0ubuntu2.10]
libwbclient0/bionic-updates,bionic-security 2:4.7.6+dfsg~ubuntu-0ubuntu2.11 amd64 [upgradable from: 2:4.7.6+dfsg~ubuntu-0ubuntu2.10]
python-samba/bionic-updates,bionic-security 2:4.7.6+dfsg~ubuntu-0ubuntu2.11 amd64 [upgradable from: 2:4.7.6+dfsg~ubuntu-0ubuntu2.10]
samba-common/bionic-updates,bionic-updates,bionic-security,bionic-security 2:4.7.6+dfsg~ubuntu-0ubuntu2.11 all [upgradable from: 2:4.7.6+dfsg~ubuntu-0ubuntu2.10]
samba-common-bin/bionic-updates,bionic-security 2:4.7.6+dfsg~ubuntu-0ubuntu2.11 amd64 [upgradable from: 2:4.7.6+dfsg~ubuntu-0ubuntu2.10]
samba-dsdb-modules/bionic-updates,bionic-security 2:4.7.6+dfsg~ubuntu-0ubuntu2.11 amd64 [upgradable from: 2:4.7.6+dfsg~ubuntu-0ubuntu2.10]
samba-libs/bionic-updates,bionic-security 2:4.7.6+dfsg~ubuntu-0ubuntu2.11 amd64 [upgradable from: 2:4.7.6+dfsg~ubuntu-0ubuntu2.10]
samba-vfs-modules/bionic-updates,bionic-security 2:4.7.6+dfsg~ubuntu-0ubuntu2.11 amd64 [upgradable from: 2:4.7.6+dfsg~ubuntu-0ubuntu2.10]
thunderbird/bionic-updates,bionic-security 1:60.7.0+build1-0ubuntu0.18.04.1 amd64 [upgradable from: 1:60.6.1+build2-0ubuntu0.18.04.1]
« Reply #9 on: May 28, 2019, 08:25:41 pm »
╰─$ apt-cache policy
Package files:
 100 /var/lib/dpkg/status
     release a=now
 700 http://ppa.launchpad.net/yannubuntu/boot-repair/ubuntu bionic/main i386 Packages
     release v=18.04,o=LP-PPA-yannubuntu-boot-repair,a=bionic,n=bionic,l=Boot-Repair,c=main,b=i386
     origin ppa.launchpad.net
 700 http://ppa.launchpad.net/yannubuntu/boot-repair/ubuntu bionic/main amd64 Packages
     release v=18.04,o=LP-PPA-yannubuntu-boot-repair,a=bionic,n=bionic,l=Boot-Repair,c=main,b=amd64
 700 http://ppa.launchpad.net/webupd8team/y-ppa-manager/ubuntu bionic/main i386 Packages
     release v=18.04,o=LP-PPA-webupd8team-y-ppa-manager,a=bionic,n=bionic,l=Y PPA Manager,c=main,b=i386
 700 http://ppa.launchpad.net/webupd8team/y-ppa-manager/ubuntu bionic/main amd64 Packages
     release v=18.04,o=LP-PPA-webupd8team-y-ppa-manager,a=bionic,n=bionic,l=Y PPA Manager,c=main,b=amd64
 700 http://ppa.launchpad.net/rvm/smplayer/ubuntu bionic/main i386 Packages
     release v=18.04,o=LP-PPA-rvm-smplayer,a=bionic,n=bionic,l=SMPlayer,c=main,b=i386
 700 http://ppa.launchpad.net/rvm/smplayer/ubuntu bionic/main amd64 Packages
     release v=18.04,o=LP-PPA-rvm-smplayer,a=bionic,n=bionic,l=SMPlayer,c=main,b=amd64
 700 http://ppa.launchpad.net/peppermintos/gimp-2102-testing/ubuntu bionic/main i386 Packages
     release v=18.04,o=LP-PPA-peppermintos-gimp-2102-testing,a=bionic,n=bionic,l=GIMP 2.10.2 Testing,c=main,b=i386
 700 http://ppa.launchpad.net/peppermintos/gimp-2102-testing/ubuntu bionic/main amd64 Packages
     release v=18.04,o=LP-PPA-peppermintos-gimp-2102-testing,a=bionic,n=bionic,l=GIMP 2.10.2 Testing,c=main,b=amd64
 700 http://ppa.launchpad.net/peppermintos/p9-build/ubuntu bionic/main i386 Packages
     release v=18.04,o=LP-PPA-peppermintos-p9-build,a=bionic,n=bionic,l=Peppermint 9 Build,c=main,b=i386
 700 http://ppa.launchpad.net/peppermintos/p9-build/ubuntu bionic/main amd64 Packages
     release v=18.04,o=LP-PPA-peppermintos-p9-build,a=bionic,n=bionic,l=Peppermint 9 Build,c=main,b=amd64
 500 https://deb.opera.com/opera-stable stable/non-free i386 Packages
     release o=Opera Software AS,a=stable,n=stable,l=The Opera web browser,c=non-free,b=i386
     origin deb.opera.com
 500 https://deb.opera.com/opera-stable stable/non-free amd64 Packages
     release o=Opera Software AS,a=stable,n=stable,l=The Opera web browser,c=non-free,b=amd64
 500 https://deb.opera.com/opera-beta stable/non-free i386 Packages
 500 https://deb.opera.com/opera-beta stable/non-free amd64 Packages
 700 http://ppa.launchpad.net/netgear-inc/ppa/ubuntu xenial/main amd64 Packages
     release v=16.04,o=LP-PPA-netgear-inc,a=xenial,n=xenial,l=applications,c=main,b=amd64
 500 https://mega.nz/linux/MEGAsync/xUbuntu_18.04 ./ Packages
     release o=obs://private/DEB/xUbuntu_18.04,n=xUbuntu_18.04,l=DEB,c=
     origin mega.nz
 700 http://ppa.launchpad.net/mark-pcnetspec/nemo-365-testing/ubuntu bionic/main i386 Packages
     release v=18.04,o=LP-PPA-mark-pcnetspec-nemo-365-testing,a=bionic,n=bionic,l=Nemo 3.6.5-1 Testing,c=main,b=i386
 700 http://ppa.launchpad.net/mark-pcnetspec/nemo-365-testing/ubuntu bionic/main amd64 Packages
     release v=18.04,o=LP-PPA-mark-pcnetspec-nemo-365-testing,a=bionic,n=bionic,l=Nemo 3.6.5-1 Testing,c=main,b=amd64
 700 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic/main i386 Packages
     release v=18.04,o=LP-PPA-graphics-drivers,a=bionic,n=bionic,l=Proprietary GPU Drivers,c=main,b=i386
 700 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic/main amd64 Packages
     release v=18.04,o=LP-PPA-graphics-drivers,a=bionic,n=bionic,l=Proprietary GPU Drivers,c=main,b=amd64
 700 http://ppa.launchpad.net/eosrei/fonts/ubuntu bionic/main i386 Packages
     release v=18.04,o=LP-PPA-eosrei-fonts,a=bionic,n=bionic,l=Color Emoji Fonts,c=main,b=i386
 700 http://ppa.launchpad.net/eosrei/fonts/ubuntu bionic/main amd64 Packages
     release v=18.04,o=LP-PPA-eosrei-fonts,a=bionic,n=bionic,l=Color Emoji Fonts,c=main,b=amd64
 700 http://ppa.launchpad.net/danielrichter2007/grub-customizer/ubuntu bionic/main i386 Packages
     release v=18.04,o=LP-PPA-danielrichter2007-grub-customizer,a=bionic,n=bionic,l=Launchpad PPA for Grub Customizer,c=main,b=i386
 700 http://ppa.launchpad.net/danielrichter2007/grub-customizer/ubuntu bionic/main amd64 Packages
     release v=18.04,o=LP-PPA-danielrichter2007-grub-customizer,a=bionic,n=bionic,l=Launchpad PPA for Grub Customizer,c=main,b=amd64
 700 http://ppa.launchpad.net/canonical-kernel-team/proposed/ubuntu bionic/main i386 Packages
     release v=18.04,o=LP-PPA-canonical-kernel-team-proposed,a=bionic,n=bionic,l=Kernels as in Proposed,c=main,b=i386
 700 http://ppa.launchpad.net/canonical-kernel-team/proposed/ubuntu bionic/main amd64 Packages
     release v=18.04,o=LP-PPA-canonical-kernel-team-proposed,a=bionic,n=bionic,l=Kernels as in Proposed,c=main,b=amd64
 500 http://dl.google.com/linux/chrome/deb stable/main amd64 Packages
     release v=1.0,o=Google LLC,a=stable,n=stable,l=Google,c=main,b=amd64
     origin dl.google.com
 500 https://s3-us-west-2.amazonaws.com/brave-apt bionic/main amd64 Packages
     release o=. bionic,a=bionic,n=bionic,l=. bionic,c=main,b=amd64
     origin s3-us-west-2.amazonaws.com
 700 http://ppa.launchpad.net/atareao/atareao/ubuntu bionic/main i386 Packages
     release v=18.04,o=LP-PPA-atareao-atareao,a=bionic,n=bionic,l=atareao-team,c=main,b=i386
 700 http://ppa.launchpad.net/atareao/atareao/ubuntu bionic/main amd64 Packages
     release v=18.04,o=LP-PPA-atareao-atareao,a=bionic,n=bionic,l=atareao-team,c=main,b=amd64
 700 http://ppa.launchpad.net/anonbeat/guayadeque/ubuntu bionic/main i386 Packages
     release v=18.04,o=LP-PPA-anonbeat-guayadeque,a=bionic,n=bionic,l=Guayadeque Music Player,c=main,b=i386
 700 http://ppa.launchpad.net/anonbeat/guayadeque/ubuntu bionic/main amd64 Packages
     release v=18.04,o=LP-PPA-anonbeat-guayadeque,a=bionic,n=bionic,l=Guayadeque Music Player,c=main,b=amd64
 700 http://ppa.launchpad.net/alex-p/gimp/ubuntu bionic/main i386 Packages
     release v=18.04,o=LP-PPA-alex-p-gimp,a=bionic,n=bionic,l=GIMP - The GNU Image Manipulation Program,c=main,b=i386
 700 http://ppa.launchpad.net/alex-p/gimp/ubuntu bionic/main amd64 Packages
     release v=18.04,o=LP-PPA-alex-p-gimp,a=bionic,n=bionic,l=GIMP - The GNU Image Manipulation Program,c=main,b=amd64
 500 http://security.ubuntu.com/ubuntu bionic-security/multiverse i386 Packages
     release v=18.04,o=Ubuntu,a=bionic-security,n=bionic,l=Ubuntu,c=multiverse,b=i386
     origin security.ubuntu.com
 500 http://security.ubuntu.com/ubuntu bionic-security/multiverse amd64 Packages
     release v=18.04,o=Ubuntu,a=bionic-security,n=bionic,l=Ubuntu,c=multiverse,b=amd64
 500 http://security.ubuntu.com/ubuntu bionic-security/universe i386 Packages
     release v=18.04,o=Ubuntu,a=bionic-security,n=bionic,l=Ubuntu,c=universe,b=i386
 500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
     release v=18.04,o=Ubuntu,a=bionic-security,n=bionic,l=Ubuntu,c=universe,b=amd64
 500 http://security.ubuntu.com/ubuntu bionic-security/restricted i386 Packages
     release v=18.04,o=Ubuntu,a=bionic-security,n=bionic,l=Ubuntu,c=restricted,b=i386
 500 http://security.ubuntu.com/ubuntu bionic-security/restricted amd64 Packages
     release v=18.04,o=Ubuntu,a=bionic-security,n=bionic,l=Ubuntu,c=restricted,b=amd64
 500 http://security.ubuntu.com/ubuntu bionic-security/main i386 Packages
     release v=18.04,o=Ubuntu,a=bionic-security,n=bionic,l=Ubuntu,c=main,b=i386
 500 http://security.ubuntu.com/ubuntu bionic-security/main amd64 Packages
     release v=18.04,o=Ubuntu,a=bionic-security,n=bionic,l=Ubuntu,c=main,b=amd64
 500 http://archive.canonical.com/ubuntu bionic/partner i386 Packages
     release v=18.04,o=Canonical,a=bionic,n=bionic,l=Partner archive,c=partner,b=i386
     origin archive.canonical.com
 500 http://archive.canonical.com/ubuntu bionic/partner amd64 Packages
     release v=18.04,o=Canonical,a=bionic,n=bionic,l=Partner archive,c=partner,b=amd64
 500 http://us.archive.ubuntu.com/ubuntu bionic-backports/universe i386 Packages
     release v=18.04,o=Ubuntu,a=bionic-backports,n=bionic,l=Ubuntu,c=universe,b=i386
     origin us.archive.ubuntu.com
 500 http://us.archive.ubuntu.com/ubuntu bionic-backports/universe amd64 Packages
     release v=18.04,o=Ubuntu,a=bionic-backports,n=bionic,l=Ubuntu,c=universe,b=amd64
 500 http://us.archive.ubuntu.com/ubuntu bionic-backports/main i386 Packages
     release v=18.04,o=Ubuntu,a=bionic-backports,n=bionic,l=Ubuntu,c=main,b=i386
 500 http://us.archive.ubuntu.com/ubuntu bionic-backports/main amd64 Packages
     release v=18.04,o=Ubuntu,a=bionic-backports,n=bionic,l=Ubuntu,c=main,b=amd64
 500 http://us.archive.ubuntu.com/ubuntu bionic-updates/multiverse i386 Packages
     release v=18.04,o=Ubuntu,a=bionic-updates,n=bionic,l=Ubuntu,c=multiverse,b=i386
 500 http://us.archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 Packages
     release v=18.04,o=Ubuntu,a=bionic-updates,n=bionic,l=Ubuntu,c=multiverse,b=amd64
 500 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe i386 Packages
     release v=18.04,o=Ubuntu,a=bionic-updates,n=bionic,l=Ubuntu,c=universe,b=i386
 500 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
     release v=18.04,o=Ubuntu,a=bionic-updates,n=bionic,l=Ubuntu,c=universe,b=amd64
 500 http://us.archive.ubuntu.com/ubuntu bionic-updates/restricted i386 Packages
     release v=18.04,o=Ubuntu,a=bionic-updates,n=bionic,l=Ubuntu,c=restricted,b=i386
 500 http://us.archive.ubuntu.com/ubuntu bionic-updates/restricted amd64 Packages
     release v=18.04,o=Ubuntu,a=bionic-updates,n=bionic,l=Ubuntu,c=restricted,b=amd64
 500 http://us.archive.ubuntu.com/ubuntu bionic-updates/main i386 Packages
     release v=18.04,o=Ubuntu,a=bionic-updates,n=bionic,l=Ubuntu,c=main,b=i386
 500 http://us.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages
     release v=18.04,o=Ubuntu,a=bionic-updates,n=bionic,l=Ubuntu,c=main,b=amd64
 500 http://mirrors.namecheap.com/ubuntu bionic/multiverse i386 Packages
     release v=18.04,o=Ubuntu,a=bionic,n=bionic,l=Ubuntu,c=multiverse,b=i386
     origin mirrors.namecheap.com
 500 http://mirrors.namecheap.com/ubuntu bionic/multiverse amd64 Packages
     release v=18.04,o=Ubuntu,a=bionic,n=bionic,l=Ubuntu,c=multiverse,b=amd64
 500 http://mirrors.namecheap.com/ubuntu bionic/universe i386 Packages
     release v=18.04,o=Ubuntu,a=bionic,n=bionic,l=Ubuntu,c=universe,b=i386
 500 http://mirrors.namecheap.com/ubuntu bionic/universe amd64 Packages
     release v=18.04,o=Ubuntu,a=bionic,n=bionic,l=Ubuntu,c=universe,b=amd64
 500 http://mirrors.namecheap.com/ubuntu bionic/restricted i386 Packages
     release v=18.04,o=Ubuntu,a=bionic,n=bionic,l=Ubuntu,c=restricted,b=i386
 500 http://mirrors.namecheap.com/ubuntu bionic/restricted amd64 Packages
     release v=18.04,o=Ubuntu,a=bionic,n=bionic,l=Ubuntu,c=restricted,b=amd64
 500 http://mirrors.namecheap.com/ubuntu bionic/main i386 Packages
     release v=18.04,o=Ubuntu,a=bionic,n=bionic,l=Ubuntu,c=main,b=i386
 500 http://mirrors.namecheap.com/ubuntu bionic/main amd64 Packages
     release v=18.04,o=Ubuntu,a=bionic,n=bionic,l=Ubuntu,c=main,b=amd64
Pinned packages:
« Reply #10 on: May 28, 2019, 08:39:56 pm »
Hi VinDSL,
I wish I could say the same, but I guess the rain has stopped.  Would you happen to know by chance a command that could tell me where the mirror I'm using is located?  Might it be located in Massachusetts or New York perhaps?
This is the output when I run that command:
« Reply #11 on: May 28, 2019, 09:09:49 pm »
Not off the top of my head. However, curl is your friend.
If you have curl installed, you can find the fastest mirror, for your IP.
Example:
╰─$ curl -s http://mirrors.ubuntu.com/mirrors.txt | xargs -n1 -I {} sh -c 'echo `curl -r 0-102400 -s -w %{speed_download} -o /dev/null {}/ls-lR.gz` {}' |sort -g -r |head -1| awk '{ print $2  }'
http://mirrors.arpnetworks.com/Ubuntu/
Takes awhile - be patient  :)
« Reply #12 on: May 28, 2019, 09:23:40 pm »
Here are a few commands I find useful for checking which repos are enabled...
List the contents of /etc/apt/sources.list and the contents of all files (PPA's) at /etc/apt/sources.list.d
cat /etc/apt/sources.list; for X in /etc/apt/sources.list.d/*; do echo; echo; echo "** $X:"; echo; cat $X; doneList the contents of /etc/apt/sources.list and ONLY ACTIVE PPA's
cat /etc/apt/sources.list; for X in /etc/apt/sources.list.d/*.list; do echo; echo; echo "** $X:"; echo; cat $X; doneList just PPA's at /etc/apt/sources.list.d
for X in /etc/apt/sources.list.d/*; do echo; echo; echo "** $X:"; echo; cat $X; doneList ONLY ACTIVE PPA's at /etc/apt/sources.list.d
List active PPA's by LAUNCHPAD NAME ONLY .. this is useful for things like 'ppa-purge', etc.
for APT in `find /etc/apt/ -name \*.list`; do grep -o "^deb http://ppa.launchpad.net/[a-z0-9\-]\+/[a-z0-9\-]\+" $APT | while read ENTRY ; do USER=`echo $ENTRY | cut -d/ -f4` PPA=`echo $ENTRY | cut -d/ -f5` ; echo ppa:$USER/$PPA ; done ; done
