Author Topic: Notebook's touchpad and keyboard dont work  (Read 2355 times)
Re: Notebook's touchpad and keyboard dont work
« Reply #15 on: November 15, 2018, 01:08:01 pm »
Do you know how to add then try these two kernel boot parameters ?
atkdb.reset i8042.nomux?
Offline jferreira94
« Reply #16 on: November 16, 2018, 05:38:38 am »
I searched in google and tried to add, but I have got an error message saying that those commands has not found
« Reply #17 on: November 16, 2018, 05:41:37 am »
Can you explain what you did to try those parameters ?
Offline jferreira94
« Reply #18 on: November 16, 2018, 06:08:02 am »
This:
https://askubuntu.com/questions/19486/how-do-i-add-a-kernel-boot-parameter
    Start your system and wait for the GRUB menu to show (if you don't see a GRUB menu, press and hold the left Shift key right after starting the system).
    Now highlight the kernel you want to use, and press the e key. You should be able to see and edit the commands associated with the highlighted kernel.
    Go down to the line starting with linux and add your parameter foo=bar to its end.
    Now press Ctrl + x to boot.
But I inserted  2 lines:
atkdb.reset
i8042.nomux
« Reply #19 on: November 16, 2018, 06:54:52 am »
You don't insert them as new lines. As per the instructions, you add them both to the end of the linux line.
Offline jferreira94
« Reply #20 on: November 16, 2018, 07:25:01 am »
Like this?
« Reply #21 on: November 16, 2018, 07:37:37 am »
Yes, that looks right.
Offline jferreira94
« Reply #22 on: November 16, 2018, 08:27:50 am »
I did it, ctrl + x, and the keyboard not worked
Offline jferreira94
« Reply #23 on: November 23, 2018, 09:22:22 am »
yesterday my keyboard worked after a lvl5 update, and stopped to work after another 4 lvl5 updates...
  :-\ it back to work after I suspended the system, maybe that was not cause the updates...
Before suspend:
⎡ Virtual core pointer                    id=2 [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              id=4 [slave  pointer  (2)]
⎜   ↳ Microsoft Microsoft® Nano Transceiver v2.0 id=11 [slave  pointer  (2)]
⎜   ↳ Microsoft Microsoft® Nano Transceiver v2.0 id=12 [slave  pointer  (2)]
⎣ Virtual core keyboard                    id=3 [master keyboard (2)]
    ↳ Virtual core XTEST keyboard              id=5 [slave  keyboard (3)]
    ↳ Power Button                            id=6 [slave  keyboard (3)]
    ↳ Video Bus                                id=7 [slave  keyboard (3)]
    ↳ Power Button                            id=8 [slave  keyboard (3)]
    ↳ Sleep Button                            id=9 [slave  keyboard (3)]
    ↳ Microsoft Microsoft® Nano Transceiver v2.0 id=10 [slave  keyboard (3)]
    ↳ USB 2.0 PC Cam                          id=13 [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard            id=14 [slave  keyboard (3)]
    ↳ Topstar Laptop extra buttons            id=15 [slave  keyboard (3)]
    ↳ CHICONY USB NetVista Full Width Keyboard id=16 [slave  keyboard (3)]
After suspend:
« Last Edit: November 23, 2018, 09:39:15 am by jferreira94 »
Offline jferreira94
« Reply #24 on: November 29, 2018, 05:51:39 am »
I partially solved the problem.
I can active the keyboard suspending the system after I turn on the netbook. The touch dont work, but I prefer to use the mouse, so it's not a great problem...
« Reply #25 on: November 29, 2018, 12:47:42 pm »
I'm seeing no difference between the two xinput outputs :-\
Can you post the output from:
lsmodboth before and after a suspend.
Offline jferreira94
« Reply #26 on: November 30, 2018, 06:39:34 am »
Before
Module                  Size  Used by
input_leds             16384  0
ccm                    20480  3
joydev                 24576  0
hid_generic            16384  0
usbhid                 49152  0
hid                   118784  2 usbhid,hid_generic
uvcvideo               86016  0
gpio_ich               16384  0
videobuf2_vmalloc      16384  1 uvcvideo
videobuf2_memops       16384  1 videobuf2_vmalloc
videobuf2_v4l2         24576  1 uvcvideo
videobuf2_core         40960  2 videobuf2_v4l2,uvcvideo
videodev              184320  3 videobuf2_core,videobuf2_v4l2,uvcvideo
media                  40960  2 videodev,uvcvideo
arc4                   16384  2
rtl8192ce              65536  0
rtl_pci                32768  1 rtl8192ce
rtl8192c_common        57344  1 rtl8192ce
snd_hda_codec_realtek   106496  1
rtlwifi                77824  3 rtl_pci,rtl8192c_common,rtl8192ce
snd_hda_codec_generic    73728  1 snd_hda_codec_realtek
snd_hda_intel          40960  3
mac80211              778240  3 rtl_pci,rtlwifi,rtl8192ce
snd_hda_codec         126976  3 snd_hda_codec_generic,snd_hda_intel,snd_hda_codec_realtek
coretemp               16384  0
snd_hda_core           81920  4 snd_hda_codec_generic,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
serio_raw              16384  0
snd_hwdep              20480  1 snd_hda_codec
snd_pcm                98304  3 snd_hda_intel,snd_hda_codec,snd_hda_core
cfg80211              622592  2 rtlwifi,mac80211
snd_timer              32768  1 snd_pcm
lpc_ich                24576  0
snd                    81920  13 snd_hda_codec_generic,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm
shpchp                 36864  0
soundcore              16384  1 snd
topstar_laptop         16384  0
sparse_keymap          16384  1 topstar_laptop
mac_hid                16384  0
binfmt_misc            20480  1
sch_fq_codel           20480  6
parport_pc             36864  0
ppdev                  20480  0
lp                     20480  0
parport                49152  3 parport_pc,lp,ppdev
sunrpc                335872  1
ip_tables              28672  0
x_tables               40960  1 ip_tables
autofs4                40960  2
btrfs                1130496  0
xor                    24576  1 btrfs
zstd_compress         163840  1 btrfs
raid6_pq              114688  1 btrfs
i915                 1617920  9
i2c_algo_bit           16384  1 i915
drm_kms_helper        172032  1 i915
syscopyarea            16384  1 drm_kms_helper
sysfillrect            16384  1 drm_kms_helper
sysimgblt              16384  1 drm_kms_helper
i2c_i801               28672  0
ahci                   36864  1
fb_sys_fops            16384  1 drm_kms_helper
libahci                32768  1 ahci
r8169                  86016  0
drm                   401408  11 drm_kms_helper,i915
mii                    16384  1 r8169
video                  45056  1 i915
After
Module                  Size  Used by
input_leds             16384  0
ccm                    20480  3
joydev                 24576  0
hid_generic            16384  0
usbhid                 49152  0
uvcvideo               86016  0
gpio_ich               16384  0
arc4                   16384  2
rtl8192ce              65536  0
coretemp               16384  0
serio_raw              16384  0
lpc_ich                24576  0
shpchp                 36864  0
mac_hid                16384  0
binfmt_misc            20480  1
parport_pc             36864  0
ppdev                  20480  0
lp                     20480  0
sunrpc                335872  1
ip_tables              28672  0
autofs4                40960  2
btrfs                1130496  0
xor                    24576  1 btrfs
i915                 1617920  9
i2c_i801               28672  0
ahci                   36864  1
r8169                  86016  0
mii                    16384  1 r8169
video                  45056  1 i915
