Author Topic: Notebook's touchpad and keyboard dont work  (Read 2354 times)
Offline jferreira94
« on: October 31, 2018, 08:34:14 pm »
Hello, I am newbie on Peppermint 9.
Well, my notebook's touch pad and keyboard was working the last time I opened the Peppermint, but now it is not working anymore, but it works on grub and on Windows.
I have no clue what I have to do and did not found answers with mother Google, can someone help me plis?
« Last Edit: October 31, 2018, 09:32:41 pm by jferreira94 »
Re: Notebook's touchpad and keyboard dont work
« Reply #1 on: October 31, 2018, 10:27:18 pm »
Hi jferreira94, welcome to the Peppermint Forum.  You've come to the right place for help  ;).  Do you have a USB keyboard and a USB  mouse you can plug into of your laptop's USB ports?  If you do, please plug them in.  If they work, please open a terminal window with the following keystrokes:
Ctrl+Alt+t
Enter (Copy & Paste) the following command into the terminal windows.   Post, (Copy & Paste) the outputs back to the forum:
inxi -FzThis will give us some detailed information about you system.  Also, have you recently updated you system?
Offline jferreira94
« Reply #2 on: November 01, 2018, 06:19:23 am »
Ctrl+Alt+t
System:    Host: tralha Kernel: 4.15.0-38-generic x86_64 bits: 64 Desktop: N/A
           Distro: Peppermint Nine
Machine:   Device: other-vm? System: Intel product: Pine Trail - M v: A serial: N/A
           Mobo: Intel model: Pine Trail - M v: A serial: N/A
           BIOS: Phoenix v: 6.00 date: 04/05/2012
CPU:       Single core Intel Atom N455 (-MT-) cache: 512 KB
           clock speeds: max: 1667 MHz 1: 1662 MHz 2: 1662 MHz
Graphics:  Card: Intel Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller
           drivers: intel (unloaded: modesetting,fbdev,vesa)
           Resolution: 1024x600@60.00hz
           OpenGL: renderer: Mesa DRI Intel Pineview M version: 1.4 Mesa 18.0.5
Audio:     Card Intel NM10/ICH7 Family High Def. Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.15.0-38-generic
Network:   Card-1: Realtek RTL8101/2/6E PCIE Fast/Gigabit Ethernet controller
           driver: r8169
           IF: enp5s0 state: down mac: <filter>
           Card-2: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce
           IF: wlp7s0 state: up mac: <filter>
Drives:    HDD Total Size: 320.1GB (2.9% used)
           ID-1: /dev/sda model: ST320LM001_HN size: 320.1GB
Partition: ID-1: / size: 55G used: 8.5G (17%) fs: ext4 dev: /dev/sda4
Sensors:   System Temperatures: cpu: 61.0C mobo: N/A
Info:      Processes: 157 Uptime: 15 min Memory: 663.8/1983.7MB
« Last Edit: November 01, 2018, 07:07:39 am by AndyInMokum »
Offline jferreira94
« Reply #3 on: November 01, 2018, 09:35:56 am »
I forgot to respond this, I will put in order what happened:
1 - I installed the Peppermint 9, all ok.
2 - I used Firefox and I shut down the notebook hours later.
3 - I turn on the notebook, the keyboard was working at grub
4 - When Peppermint was loaded, I tried do use the keyboard but it did not worked
5 - I saw a notification saying that had dozens of updates, so I connected  another keyboard and installed the updates
6 - The problem persists
« Reply #4 on: November 01, 2018, 01:14:04 pm »
Does the keyboard/mouse work if you log into the Guest session ?
Do they work if you boot a liveUSB ?
And are you saying they stopped working BEFORE you installed ANY updates ?
Offline jferreira94
« Reply #5 on: November 01, 2018, 07:11:39 pm »
No
I tried to use from pendrive and keyboard also was not working
yes, before.
« Reply #6 on: November 02, 2018, 03:45:38 am »
So it worked from the Peppermint LiveUSB when you first installed it, but now when you boot from the same LiveUSB it doesn't  :-\
Are you sure there's not a switch somewhere that disables them ?
Offline jferreira94
« Reply #7 on: November 02, 2018, 08:31:09 am »
I think I changed nothing. I found other guy with the same notebook model and with the same problem, he did not resolved it. I will use puppy on this notebook and try to use pepper in my PC when I can heal him, I like pepper interface...
« Reply #8 on: November 02, 2018, 01:53:00 pm »
It's weird that it worked at first :-\ .. can you post the make/model ?
and the output from:
xinput --list
Offline jferreira94
« Reply #9 on: November 02, 2018, 02:33:36 pm »
I am running without installation and keyboard is working aggain. I will reinstall peppermint and see what change, what i could post before I reinstal for compare later ?
ubuntu@ubuntu ~ $ xinput --list
⎡ Virtual core pointer                    id=2 [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              id=4 [slave  pointer  (2)]
⎜   ↳ ImPS/2 Generic Wheel Mouse              id=14 [slave  pointer  (2)]
⎜   ↳ USB OPTICAL MOUSE                        id=10 [slave  pointer  (2)]
⎜   ↳ USB OPTICAL MOUSE                        id=11 [slave  pointer  (2)]
⎣ Virtual core keyboard                    id=3 [master keyboard (2)]
    ↳ Virtual core XTEST keyboard              id=5 [slave  keyboard (3)]
    ↳ Power Button                            id=6 [slave  keyboard (3)]
    ↳ Video Bus                                id=7 [slave  keyboard (3)]
    ↳ Power Button                            id=8 [slave  keyboard (3)]
    ↳ Sleep Button                            id=9 [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard            id=13 [slave  keyboard (3)]
    ↳ Topstar Laptop extra buttons            id=15 [slave  keyboard (3)]
    ↳ USB 2.0 PC Cam                          id=12 [slave  keyboard (3)]
Offline jferreira94
« Reply #10 on: November 02, 2018, 04:48:44 pm »
I reinstalled, again the it works until I shut down the notebook.
In matter, I shutdown the notebook with keyboard working and when I turn on it stops working.
joel@tralha ~ $ xinput --list
    ↳ Topstar Laptop extra buttons            id=13 [slave  keyboard (3)]
    ↳ CHICONY USB NetVista Full Width Keyboard id=14 [slave  keyboard (3)]
I found that AT Translated Set 2 keyboard is missing, but dont know what to do about...
« Last Edit: November 02, 2018, 05:21:14 pm by jferreira94 »
« Reply #11 on: November 02, 2018, 05:45:32 pm »
it makes little sense to me that xinput seems to work from the LiveUSB but not once installed :-\
As an experiment, can you try running
sudo apt-get -y remove --purge xserver-xorg-input-evdev && sudo apt-get -y install xserver-xorg-input-libinputonce that finishes, reboot to test .. does the keyboard/touchpad work now ?
If not, you can UNDO that with:
sudo apt-get -y remove --purge xserver-xorg-input-libinput && sudo apt-get -y install xserver-xorg-input-evdev
Offline jferreira94
« Reply #12 on: November 02, 2018, 08:32:53 pm »
Did not worked.
« Reply #13 on: November 03, 2018, 03:12:28 pm »
Can you run:
dmesg > ~/Desktop/dmesg.txtyou'll then find a file on your desktop called dmesg.txt .. can you host that somewhere like
http://www.tinyupload.com/
and post a link to it.
Something else .. it would be nice to check if an update is breaking detection of your keyboard/touchpad
If you're up for it, could you reinstall Peppermint but reinstall WITHOUT any kind of internet connection (ie. DON'T set up wireless during the install, and don't have an ethernet connection) .. once installed, reboot and tell us if the touchpad/keyboard still works ?
« Last Edit: November 03, 2018, 03:26:07 pm by PCNetSpec »
Offline jferreira94
