Author Topic: Send a Fax  (Read 1119 times)
Send a Fax
« on: October 31, 2018, 12:29:16 pm »
Hello Peppermint people, is it possible for me to send a fax from my computer without a fax machine or fax modem? I tried sending a pdf file using Efax-gtk but got an error
efax-0.9a: 11:15:58 opened /dev/ttyS1
efax-0.9a: 11:15:58 failed page /home/albert/Documents/NARA _ e-Vetrecs _signed.pdf.001
efax-0.9a: 11:15:58 Error: tcgetattr on fd=7 failed: Input/output error
efax-0.9a: 11:15:58 Error: fax device write: Input/output error
efax-0.9a: 11:16:00 Error: tcgetattr on fd=7 failed: Input/output error
efax-0.9a: 11:16:02 Error: fax device write: Input/output error
and it continues with Dropping...
So what do I need to do? Anybody?
Offline christianvl
Re: Send a Fax
« Reply #1 on: October 31, 2018, 12:55:05 pm »
Hi alynur.
I think you actually need to hook your computer to a telephone land-line. I'm not sure, but I have the impression you can't send a fax using the internet (or a mobile phone). There are some webservices that may provide that function for you.
Re: Send a Fax
« Reply #2 on: October 31, 2018, 02:19:55 pm »
Take a look here  https://faxauthority.com/linux-fax/
Linux User #565092
Re: Send a Fax
« Reply #3 on: October 31, 2018, 05:53:59 pm »
Well you'd certainly need a fax modem to send it directly .. how else would it talk to a fax machine ?
Re: Send a Fax
« Reply #4 on: November 02, 2018, 08:08:49 pm »
Thanks Zeb, that clears it up. I don't have a phone connection on my computer so I guess I'm out of luck. Thanks guys for all the info.  :)
Re: Send a Fax
« Reply #5 on: November 02, 2018, 09:16:06 pm »
Some printers still have dial-up modems in them, so can be used as Fax machines.
Otherwise you'd either need a dial-up modem (that's how fax's speak to each other .. you remember the noise right :))), or use an online service that will send a fax for you.
Most broadband modem/routers these days, though they may still use the phone line use a completely different signal frequency and technology that is isolated from the audible band .. so an old Fax machine wouldn't "hear" it and even if it could they'd be talking different languages.
BTW, who the heck is still using fax :o
« Last Edit: November 02, 2018, 09:24:48 pm by PCNetSpec »
Re: Send a Fax
« Reply #6 on: November 02, 2018, 11:19:33 pm »
I was going to suggest the online service.
Doctor offices. Government offices. For that matter, a number of businesses. A number of businesses won't accept files in an e-mail, but they'll accept a fax. I guess they figure there's no way to send a virus in a fax. ;)
Re: Send a Fax
« Reply #7 on: November 03, 2018, 08:52:27 am »
Hmm, apparently a document sent by email isn't legally binding, but sent by fax it is
https://www.efax.co.uk/blog/why-fax-is-legally-binding
Kinda odd when you consider these fax services where you send them an email and they forward it as a fax :-\
(and if you use your wireless printers fax, the document could also easily be intercepted)
You'd think encrypted email would be the most secure method .. and the fact your decypt key worked PROVED the sender.
The system is being governed by idiots .. as usual ::)
« Last Edit: November 03, 2018, 08:55:04 am by PCNetSpec »
Re: Send a Fax
« Reply #8 on: November 03, 2018, 09:39:32 am »
They're now doing lease documents by email only so I suppose there's some method of making sure they're legally valid.
Re: Send a Fax
« Reply #9 on: November 03, 2018, 09:44:42 am »
Yep, that sums it up nicely.
Re: Send a Fax
« Reply #10 on: November 03, 2018, 09:51:59 am »
In order to connect your PC to a phone line you would need a fax modem and If I remember correctly most internal modems were winmodems and Linux support was very poor I once got it working using an external serial port modem I forget the make/model now but I still have it in my attic somewhere
Anyway here's some information about getting winmodems working in Linux if it's any help
http://www.linmodems.org/
Good luck
Re: Send a Fax
« Reply #11 on: November 03, 2018, 04:14:20 pm »
USRobotics ?
Still have a couple of 14400 somewhere I think .. though god knows why.
Re: Send a Fax
« Reply #12 on: November 03, 2018, 04:23:25 pm »
Believe it or not all UK MOT stations used these modems when the system was computerized and continued to use them up until recently
