Author Topic: new peppermint 8 install, jacked up hplip <SOLVED>  (Read 2740 times)
Re: new peppermint 8 install, jacked up hplip
« Reply #15 on: October 22, 2018, 03:39:57 pm »
Connect your printer and post the output of
lsusb
Offline adamunderwood
  • Still learning
  • Peppermint version(s): 6,8, and 9
« Reply #16 on: October 22, 2018, 03:41:25 pm »
gs1@gs1-HP-Compaq-Elite-8300-SFF ~ $ lsusb
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 002: ID 03f0:052a Hewlett-Packard
« Reply #17 on: October 22, 2018, 03:44:23 pm »
Time to re-install hplip
sudo apt-get install hplip
If you type the following on your web browser http://localhost:631  do you see the printer?
« Reply #18 on: October 22, 2018, 03:47:41 pm »
Personally I'd also install hplip-gui then use the HP Toolbox to configure the printer/scanner.
  • Still learning
« Reply #19 on: October 22, 2018, 03:50:44 pm »
ok, installed both hplip and hplip-gui.
when I put  "http://localhost:631/" into my browser it takes me to what looks like CUPS home page
« Reply #20 on: October 22, 2018, 03:53:43 pm »
It's cups webGUI, but try PCNetSpec suggestion first and use the hplipGUI.
  • Still learning
« Reply #21 on: October 22, 2018, 03:57:42 pm »
Ok I try to open the HPLIP Toolbox in the preferences menu and a window opens and immediately closes.  Just looks like a flash on the screen.
« Reply #22 on: October 22, 2018, 04:00:15 pm »
There's no way for me to test this  ???
For the scanner part have a look here, https://hanynowsky.wordpress.com/2017/12/13/hp-laserjet-pro-m1212nf-mfp-scanner-on-ubuntu/
EDIT: I guess, you have seen this thread? https://ubuntuforums.org/showthread.php?t=1792538
« Last Edit: October 22, 2018, 04:16:09 pm by pin »
« Reply #23 on: October 22, 2018, 04:04:51 pm »
what's the output from
hp-check
  • Still learning
« Reply #24 on: October 22, 2018, 04:05:33 pm »
ok I tried hp-setup in terminal and this is what I got
gs1@gs1-HP-Compaq-Elite-8300-SFF ~ $ hp-setup
error: Unable to locate models.dat file
HP Linux Imaging and Printing System (ver. 0.0.0)
Printer/Fax Setup Utility ver. 9.0
Copyright (c) 2001-15 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
(Note: Defaults for each question are maked with a '*'. Press <enter> to accept the default.)
Using connection type: usb
error: No device selected/specified or that supports this functionality.
  • Still learning
« Reply #25 on: October 22, 2018, 04:05:55 pm »
gs1@gs1-HP-Compaq-Elite-8300-SFF ~ $ hp-check
Saving output in log file: /home/gs1/hp-check.log
Dependency/Version Check Utility ver. 15.1
Note: hp-check can be run in three modes:
1. Compile-time check mode (-c or --compile): Use this mode before compiling the HPLIP
supplied tarball (.tar.gz or .run) to determine if the proper dependencies are
installed to successfully compile HPLIP.
2. Run-time check mode (-r or --run): Use this mode to determine if a distro supplied
package (.deb, .rpm, etc) or an already built HPLIP supplied tarball has the proper
dependencies installed to successfully run.
3. Both compile- and run-time check mode (-b or --both) (Default): This mode will
check both of the above cases (both compile- and run-time dependencies).
Check types:
a. EXTERNALDEP - External Dependencies
b. GENERALDEP - General Dependencies (required both at compile and run time)
c. COMPILEDEP - Compile time Dependencies
d. [All are run-time checks]
PYEXT SCANCONF QUEUES PERMISSION
Status Types:
    OK
    MISSING       - Missing Dependency or Permission or Plug-in
    INCOMPAT      - Incompatible dependency-version or Plugin-version
-Traceback (most recent call last):
  File "/usr/bin/hp-check", line 855, in <module>
    core.init()
  File "/usr/share/hplip/installer/core_install.py", line 463, in init
    self.distro_name = self.distros_index[self.distro]
KeyError: 0
« Reply #26 on: October 22, 2018, 04:12:13 pm »
what's the contents of
cat /etc/lsb-release
  • Still learning
« Reply #27 on: October 22, 2018, 04:16:40 pm »
The additional is from when I was following your recommendation to another user in another thread I found.  I was going back and forth so just left the rest as comments.
gs1@gs1-HP-Compaq-Elite-8300-SFF ~ $ cat /etc/lsb-release
 DISTRIB_ID=Peppermint
 DISTRIB_RELEASE=8
 DISTRIB_CODENAME=xenial
 DISTRIB_DESCRIPTION="Peppermint 8 Eight"
# DISTRIB_ID=Ubuntu
# DISTRIB_RELEASE=16.04
# DISTRIB_CODENAME=xenial
# DISTRIB_DESCRIPTION="Ubuntu 16.04 LTS"
« Reply #28 on: October 23, 2018, 01:28:09 pm »
Have you still got the hplip driver you downloaded from the internet in a folder somewhere ?
  • Still learning
« Reply #29 on: October 24, 2018, 02:07:57 pm »
No sir, that all got deleted when trying to get back to a fresh start.
