Author Topic: Peppermint 9 shows No Internet But Icon Shows Connected  (Read 837 times)
Offline chalupabatman
« on: October 19, 2018, 08:09:59 am »
I am running peppermint 9 on an old HP Centrino Duo laptop.  I was previously running Lubuntu - but this is so much faster and smoother - LOVE IT!
Issue I am having is that Chromium or Firefox or terminal will just randomly say it can no longer conect but the wifi indicator in the corner shows it is connected.  Only a reboot will resolve this issue.
Is there a system setting or kernal update or something I can do to remedy this?
Re: Peppermint 9 shows No Internet But Icon Shows Connected
« Reply #1 on: October 19, 2018, 08:23:27 am »
I take it this is a wireless connection we're talking about ?
Can you post the output from:
lsusband
lspci -vnn | grep -i netand
sudo lshw -C networkand the next time wireless drops out, can you also run:
rfkill listand
iwlist scanand
iwconfigcopy the output to a text file .. do whatever you need to do to get reconnected .. then post the output here
« Reply #2 on: October 19, 2018, 08:30:21 am »
Yes - it is wireless connection, sorry I should have spsecified that.
lsusb output
owner@owner-HP-Compaq-nc8430-RB553UT-ABA ~ $ lsusb
Bus 003 Device 002: ID 08ff:2580 AuthenTec, Inc. AES2501 Fingerprint Sensor
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
and lspci output
owner@owner-HP-Compaq-nc8430-RB553UT-ABA ~ $ lspci -vnn | grep -i net
08:00.0 Ethernet controller [0200]: Broadcom Limited NetXtreme BCM5753M Gigabit Ethernet PCI Express [14e4:16fd] (rev 21)
10:00.0 Network controller [0280]: Intel Corporation PRO/Wireless 3945ABG [Golan] Network Connection [8086:4222] (rev 02)
Subsystem: Hewlett-Packard Company PRO/Wireless 3945ABG [Golan] Network Connection [103c:135b]
and lshw is in spoiler tag
« Reply #3 on: October 21, 2018, 07:11:36 pm »
@PCNetSpec -
Finally had a moment to get the other logs you needed from when the wifi drops.  Below they are
iwconfig
owner@owner-HP-Compaq-nc8430-RB553UT-ABA ~ $ iwconfig
ens1      no wireless extensions.
wlp16s0   IEEE 802.11  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=14 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
iwlist
owner@owner-HP-Compaq-nc8430-RB553UT-ABA ~ $ iwlist scan
ens1      Interface doesn't support scanning.
wlp16s0   Failed to read scan data : Network is down
rfkill list
owner@owner-HP-Compaq-nc8430-RB553UT-ABA ~ $ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hp-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
When you can please advise on next steps.  Thank you kindly.
« Reply #4 on: October 22, 2018, 12:44:02 pm »
Whilst wireless is working, run:
sudo iwconfig wlp16s0 power offto disable power management on the wireless card .. and see if that makes things more stable ?
The above command will NOT survive a reboot (you'll have to apply it at each boot), I just want to know if it makes the connection stable ?
