Author Topic: wifi adapter D-LINK DWA-131 Not Working (SOLVED)  (Read 1061 times)
Offline Joesplace
  • Glad to be here!
« on: October 17, 2018, 03:00:47 pm »
Anybody have an idea of how to make wifi adapter D-LINK DWA-131 work on a consistent basis? It works sometimes and sometimes it doesn't. I installed Peppermint 9 a few days ago and this is the only problem I seem to be having. It's loaded on a Dell Inspiron 1720 . . .
« Last Edit: October 19, 2018, 05:07:40 pm by Joesplace »
Re: wifi adapter D-LINK DWA-131 Not Working
« Reply #1 on: October 17, 2018, 03:28:36 pm »
When you say it works sometimes, do you mean sometimes it doesn't work at boot .. but after a reboot it does
or do you mean wireless will suddenly drop out in the middle of using it ?
What's the output from:
lsusband
lspci -vnn | grep -i netand
rfkill listand
lshw -C networkand
Offline Joesplace
  • Glad to be here!
« Reply #2 on: October 17, 2018, 05:01:14 pm »
Thanks for the reply PCNetSpec -  sometimes it doesn't work at boot .. but after a reboot it does. Here's the output:
joe@joe-Inspiron-1720 ~ $ lsusb
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 07d1:3303 D-Link System DWA-131 802.11n Wireless N Nano Adapter(rev.A1) [Realtek RTL8192SU]
joe@joe-Inspiron-1720 ~ $ lspci -vnn | grep -i net
03:00.0 Ethernet controller [0200]: Broadcom Limited BCM4401-B0 100Base-TX [14e4:170c] (rev 02)
rfkill list - nothing here!
joe@joe-Inspiron-1720 ~ $ sudo lshw -C network
[sudo] password for joe:
  *-network
       product: BCM4401-B0 100Base-TX
       vendor: Broadcom Limited
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: eth0
       version: 02
       serial: 00:1d:09:c9:19:ff
       capacity: 100Mbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm bus_master cap_list ethernet physical mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=b44 driverversion=2.0 duplex=half latency=64 link=no multicast=yes port=twisted pair speed=10Mbit/s
       resources: irq:17 memory:fe5fe000-fe5fffff
  *-network
       physical id: 2
       bus info: usb@1:3
       logical name: wlx9094e4d4d458
       serial: 90:94:e4:d4:d4:58
       configuration: broadcast=yes driver=r8712u ip=192.168.1.98 multicast=yes wireless=IEEE 802.11bgn
joe@joe-Inspiron-1720 ~ $ inxi -Fz
System:    Host: joe-Inspiron-1720 Kernel: 4.15.0-36-generic x86_64 bits: 64
Machine:   Device: portable System: Dell product: Inspiron 1720 serial: N/A
           Mobo: Dell model: 0UK439 serial: N/A BIOS: Dell v: A09 date: 07/11/2008
Battery    BAT0: charge: 74.4 Wh 100.0% condition: 74.4/73.3 Wh (102%)
CPU:       Dual core Intel Core2 Duo T7250 (-MCP-) cache: 2048 KB
           clock speeds: max: 2001 MHz 1: 1446 MHz 2: 1831 MHz
Graphics:  Card: Intel Mobile GM965/GL960 Integrated Graphics Controller (primary)
           Resolution: 1920x1200@59.98hz
           OpenGL: renderer: Mesa DRI Intel 965GM version: 2.1 Mesa 18.0.5
Audio:     Card Intel 82801H (ICH8 Family) HD Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.15.0-36-generic
Network:   Card-1: Broadcom Limited BCM4401-B0 100Base-TX driver: b44
           IF: eth0 state: down mac: <filter>
           Card-2: D-Link System DWA-131 802.11n Wireless N Nano Adapter(rev.A1) [Realtek RTL8192SU]
           IF: N/A state: N/A mac: N/A
Drives:    HDD Total Size: 160.0GB (16.6% used)
           ID-1: /dev/sda model: Hitachi_HTS54251 size: 160.0GB
Partition: ID-1: / size: 145G used: 24G (18%) fs: ext4 dev: /dev/dm-0
           ID-2: swap-1 size: 1.02GB used: 0.00GB (0%) fs: swap dev: /dev/dm-1
Sensors:   System Temperatures: cpu: 51.0C mobo: N/A
Info:      Processes: 174 Uptime: 3:23 Memory: 697.9/3935.9MB
« Reply #3 on: October 17, 2018, 05:10:00 pm »
Next time it doesn't work on boot, run:
lsmod | grep r8712uand let me know if anything was returned
If nothing was returned, try running
sudo modprobe r8712uand let me know if wireless sprang to life
if it IS listed in the return from the first command, instead run:
sudo rmmod r8712uthen
sudo modprobe r8712uand let me know if wireless sprang to life.
Offline Joesplace
  • Glad to be here!
« Reply #4 on: October 17, 2018, 05:12:53 pm »
Thanks - I'll let you know . . . .
Offline Joesplace
  • Glad to be here!
« Reply #5 on: October 19, 2018, 05:06:43 pm »
Well PCNetSpec, I don't know what to  say - it hasn't happened again. Peppermint OS must be self healing ;D  ;D  ;D  ;D  ;D  ;D
Thanks . . .
Re: wifi adapter D-LINK DWA-131 Not Working (SOLVED)
« Reply #6 on: October 20, 2018, 12:34:23 pm »
Great news :)
Offline VinDSL
« Reply #7 on: October 20, 2018, 12:59:47 pm »
Yeah, that feature was added in... hrm
WAIT. WHAT   :D
