Author Topic: Reformat Reinstall on Touchsmart M6  (Read 2437 times)
Offline Brotherred
  • No0b
  • Peppermint version(s): Pep 8 on 386, Pep 10 on AMD 64
Re: Reformat Reinstall on Touchsmart M6 (Solved)
« Reply #15 on: October 17, 2018, 04:57:44 pm »
I guess I didn't  know the question to ask. I was or am in those links learning how to set up an ESP.
You just told me everything that I need. Thanks.
Sent from my SM-N920V using Tapatalk
« Last Edit: October 21, 2018, 12:28:13 pm by Brotherred »
Offline Brotherred
  • No0b
« Reply #16 on: October 17, 2018, 11:58:33 pm »
So as you expected that was the answer. I just installed the system.
But it literally just went to sleep while I was looking for my wifi password  (stored in keypass) on my phone, the laptop went to sleep and I can't wake it up. I can't get a prompt.
I have to shut it down.
« Reply #17 on: October 18, 2018, 03:39:56 pm »
Great to hear you've got it going. Now you'll just have to change settings in power management to prevent it from sleeping.
Offline Brotherred
  • No0b
« Reply #18 on: October 18, 2018, 03:58:18 pm »
Taptalk won't let me edit the OP topic. I will do it later tonight
« Last Edit: October 18, 2018, 04:01:16 pm by Brotherred »
Offline Brotherred
  • No0b
« Reply #19 on: October 18, 2018, 04:03:08 pm »
I don't think it slept. That's a crash.
« Reply #20 on: October 22, 2018, 02:41:47 pm »
Others here have reported similar activity upon system going to sleep, from what I've read, they all fixed the problem by disabling sleep. Maybe I missed something.
Offline Brotherred
  • No0b
« Reply #21 on: October 22, 2018, 02:45:56 pm »
No you got it. I certainly have that issue in the games crashing thread.
I just didn't like how this one happened. It seemed too quick and random. I am probably just wrong.
Offline Brotherred
  • No0b
