Author Topic: Can't access windows drives.  (Read 962 times)
Offline n6rej
  • Bear
  • Peppermint version(s): peppermint 9
« on: September 29, 2018, 07:40:51 am »
I'm not sure what in the world I"m doing wrong but I can't access any windows drives nor can i see *nix from windows.
I've gone thru samba and added users, I've shared my home folder in samba on *nix and I have lots of shares in windows.
Can someone help clear my head please.
« Last Edit: September 29, 2018, 07:44:59 am by n6rej »
Bear
Re: Can't access windows drives.
« Reply #1 on: September 29, 2018, 08:50:07 am »
So you mean across a network ?
Offline n6rej
  • Bear
« Reply #2 on: September 29, 2018, 08:59:18 am »
yes.  I have a total of 7 devices in the 192.168.0.* ip range.
Bear
« Reply #3 on: September 29, 2018, 09:41:01 am »
Are these Windows 10 & Peppermint 9 machines ?
If so, I'd suggest you make sure SMB v1 is installed and active in both Peppermint and Windows
Instructions for enabling SMB v1 in Peppermint 9 can be found here:
https://forum.peppermintos.com/index.php/topic,7086.msg72516.html#msg72516
Instructions for making sure SMB v1 is installed in Windows 10:-
  • Search in the start menu for โ€˜Turn Windows features on or offโ€™ and start it.
  • In the resulting dialog window search for โ€˜SMB1.0/CIFS File Sharing Supportโ€™ in the list of options offered, and tick the box next to it.
  • Click OK and Windows will download/install it .. You should then be prompted to reboot the PC, but if not reboot anyway.
(it's important that you REBOOT Windows because it does that very 'Windowy' thing where it's installed as part of the shutdown and bootup process)
« Last Edit: September 29, 2018, 09:43:22 am by PCNetSpec »
Offline n6rej
  • Bear
« Reply #4 on: September 29, 2018, 04:03:30 pm »
in windows 10 do I want smb server on also or just client?  I want to be able to see files both ways because ultimately I want 2 of the windows drives to be mapped in peppermint.
and yeah, its peppermint 9 & win 10 x64 pro
Bear
« Reply #5 on: September 29, 2018, 06:38:20 pm »
Just tick the box next to "SMB1.0/CIFS File Sharing Support" if it isn't already ticked.
Offline n6rej
  • Bear
« Reply #6 on: September 29, 2018, 07:58:08 pm »
it is and then there are 2 sub choices.. one is checked ( client ) the other is not.
Bear
« Reply #7 on: September 30, 2018, 08:22:37 am »
Sorry I can't remember at the moment, I don't **think** you require the server but can't remember for sure) .. try em both and see if it helps .. you can always untick the server again later.
You might also want to check your Windows PC's are in the WORKGROUP workgroup
(or alter this in samba on Peppermint)
and make sure "Network Discovery" is enabled in Windows.
Offline johnny so-low
  • everyday's a new disaster
« Reply #8 on: October 12, 2018, 06:38:00 pm »
before getting into how to set up gufw for samba try turning firewall off first and see if windows can see your linux network then
im a hillbelly i lay dwn & my belly makes a hill
