Author Topic: Format seagate hard drive to apfs  (Read 1526 times)
Offline penrose1950
« on: September 28, 2018, 07:25:07 am »
hello i have got a seagate 2tb hard drive which my mac mini does not recognize since they changed file system to apfs and i have used gparted to unmount and delete but i cannot see format to apfs,does anyone please know the command to format it to APFS?
thank you.
Re: Format seagate hard drive to apfs
« Reply #1 on: September 28, 2018, 07:32:48 am »
Any particular reason you're not formatting it on the Mac with the "Disks" utility ?
You do realise an apfs formatted disk is liable to be unreadable on a Linux PC ? .. though this might make it readable (but not writeable):
https://github.com/sgan81/apfs-fuse
If this is for external storage, doesn't the Mac Mini still support other file systems for that ?
« Last Edit: September 28, 2018, 07:41:12 am by PCNetSpec »
Offline penrose1950
« Reply #2 on: September 28, 2018, 07:40:24 am »
my mac does not recognize it and i cant see it anywhere but i can see it on my laptop?
thank you.
« Reply #3 on: September 28, 2018, 07:42:55 am »
Try opening the drive in Gparted .. then creating a new GPT partition table (be aware this will erase the drive).
Leave it unpartitioned
does the Mac recognise it now ?
Offline penrose1950
« Reply #4 on: September 28, 2018, 07:54:20 am »
it says new partition table and i can see mac ?
but not apfs
« Last Edit: September 28, 2018, 07:59:30 am by penrose1950 »
Offline penrose1950
« Reply #5 on: September 28, 2018, 08:04:46 am »
i did mac and tried again mac mini and disk utilities but still does not recognize it?
thank you.
« Reply #6 on: September 28, 2018, 08:26:03 am »
According to something I saw online:
https://www.aioboot.com/en/mac-os-extended-journaled-apfs/
Create a partition in Gparted and format it as HFS+
Then the Mac should see it
Then you can use Disks on the Mac to reformat it APFS
But if the Mac is happy to work with it when formatted as HFS+ .. I'd probably leave it that way, at least Linux will be able to read/write to it as well.
You might want to take a look at this
https://setapp.com/how-to/how-to-access-external-drive-thats-not-recognized-on-mac
« Last Edit: September 28, 2018, 08:32:53 am by PCNetSpec »
Offline penrose1950
« Reply #7 on: September 28, 2018, 08:39:38 am »
Thank you
Offline penrose1950
« Reply #8 on: September 28, 2018, 08:54:23 am »
i tried hfs+  but still not recognized so i will keep trying until i get it to work.
thank you.
Offline rayfordfromca
« Reply #9 on: November 29, 2018, 10:27:35 pm »
Reformatting the device to exFAT is the best choice, so it can be used for both Mac and Windows.
I saw the explanation here: https://www.cisdem.com/resource/flash-drive-not-showing-up-mac.html
But if formatting drive are not working for you, you can try to reset SMC.
Someone from apple discussion solved the problem by using this way.
Steps-by-steps guide: https://support.apple.com/en-us/HT201295
