Author Topic: systemd-journal-flush.service gobbling boot time [Solved]  (Read 6098 times)
Offline stevesveryown
  • Peppermint Fan
    • stevesveryown
« on: September 27, 2018, 07:49:07 am »
Hi, all my Peppermint friends!
I've been enjoying Pepp 9 on my HP 8440p laptop.  The only issue I have is the long boot time. over 25 seconds are gobbled up with  systemd-journal-flush.service.  Is there a way to reduce the time on this? Here is the out put from systemd-analyze blame
« Last Edit: September 29, 2018, 11:26:21 am by stevesveryown »
Re: systemd-journal-flush.service gobbling boot time
« Reply #1 on: September 27, 2018, 08:46:56 am »
What's the output from
journalctl --verifyand
journalctl --disk-usageand
du -hs /var/log/journal/
This link is only here for my future reference
https://forum.peppermintos.com/index.php/topic,7482.msg76881.html#msg76881
« Last Edit: September 27, 2018, 08:55:13 am by PCNetSpec »
  • Peppermint Fan
    • stevesveryown
« Reply #2 on: September 28, 2018, 06:53:05 am »
journalctl --verify
The File corruption detected is interesting.
stephen@stephen-HP-EliteBook-8440p ~ $ du -hs /var/log/journal/
497M   /var/log/journal/
« Last Edit: September 28, 2018, 06:54:39 am by stevesveryown »
« Reply #3 on: September 28, 2018, 08:35:49 am »
Okay run:
journalctl --vacuum-time=2dthen post the output from
journalctl --verifyagain.
  • Peppermint Fan
    • stevesveryown
« Reply #4 on: September 28, 2018, 09:22:56 am »
Here you go.  Looks like an issue.
« Last Edit: September 29, 2018, 06:54:55 am by stevesveryown »
« Reply #5 on: September 28, 2018, 09:50:47 am »
Sorry, try
sudo journalctl --vacuum-time=2dthen post the output from
  • Peppermint Fan
    • stevesveryown
« Reply #6 on: September 29, 2018, 07:36:41 am »
Here's the output:
« Reply #7 on: September 29, 2018, 07:38:14 am »
Okay have the boot times improved ?
  • Peppermint Fan
    • stevesveryown
« Reply #8 on: September 29, 2018, 08:42:30 am »
Boot time hasn't improved much.  systemd-journal-flush.service has dropped down in the rank.
So I know for the future, what were the commands doing?
As always, thanks for taking the time out to answer my questiion.
« Reply #9 on: September 29, 2018, 08:47:39 am »
Trimming down the systemd log files
What you need is an SSD :)
  • Peppermint Fan
    • stevesveryown
« Reply #10 on: September 29, 2018, 11:25:43 am »
Yes.  Just old school and still not 100% sure of them.   :-\
I'll mark the post solved.
Thanks!  ;)
Re: systemd-journal-flush.service gobbling boot time [Solved]
« Reply #11 on: September 29, 2018, 11:34:35 am »
I'll absolutely guarantee, an SSD would be the best purchase you've ever made (as long as your SATA port is SATA III), and once you use one you'll never touch a 'spinner' again ;)
« Reply #12 on: September 29, 2018, 12:49:26 pm »
Dito  ;).
  • Peppermint Fan
    • stevesveryown
« Reply #13 on: September 30, 2018, 08:18:45 am »
My HP specs labels the interface as a serial ata-300, which I understand to be a sata II.
« Reply #14 on: September 30, 2018, 08:32:39 am »
dmesg | grep -i ahci | grep -i Gbpsand
dmesg | grep -i sata | grep -i  'link up'
