Author Topic: How can I set the laptop to ignore when lid is closed? [Solved]  (Read 1187 times)
Offline drivebee
  • Peppermint version(s): 5
« on: September 26, 2018, 03:13:15 am »
The options do not include 'do nothing' - is there another way to set it to do nothing? My Acer Aspire One has an issue with going to sleep when it shouldn't be and I want to see if this will fix it.
« Last Edit: September 27, 2018, 03:03:31 am by zebedeeboss »
Re: How can I set the laptop to ignore when lid is closed?
« Reply #1 on: September 26, 2018, 03:56:51 am »
Hi drivebee.
you could try this
Open the /etc/systemd/logind.conf file in a text editor as root, for example,
sudo xed /etc/systemd/logind.conf
Find the line that reads
#HandleLidSwitch=suspend
and make it read
HandleLidSwitch=ignore
save the file and then close it - reboot and then see what happens when you close the lid.
If this does not work - simply edit the file again and add a # to comment out the line again
Offline drivebee
« Reply #2 on: September 26, 2018, 04:08:10 pm »
Thanks a lot, will try this.
Just a question- how come all the lines in this file are commented out? Are they just there to be used in case of issues?
« Reply #3 on: September 26, 2018, 04:33:46 pm »
Diff people want diff things  :)
This way you get to choose
Offline drivebee
« Reply #4 on: September 27, 2018, 02:37:17 am »
This totally solved the problem I was having. My Acer Aspire One was going to sleep at regular intervals for no reasons and since I made this change, it's staying on. Thank you so much!
Re: How can I set the laptop to ignore when lid is closed? [Solved]
« Reply #5 on: September 27, 2018, 03:05:16 am »
Hi
I'm just glad to hear you have the laptop running the way you want  :)  The Peppermint Way  :D
Offline ezaitsev
« Reply #6 on: November 17, 2018, 04:15:38 pm »
I have a mirror problem, when I close my laptop it does nothing, but I want power off.
In /etc/systemd/login.conf
HandleLidSwitch=poweroff
HandleLidDocked=poweroff
What I did wrong?
Pepermint 8
Offline stefanreich
  • Bot maker
    • Custom chat bots
« Reply #7 on: December 18, 2019, 04:53:28 am »
The file is called "logind.conf", no?
I make the best AI ever. https://BotCompany.de
« Reply #8 on: December 18, 2019, 05:39:03 pm »
it is .. nicely spotted stefanreich :)
