Author Topic: Peppermint 9 changes owner and permissions on exe program files (SOLVED)  (Read 3140 times)
Re: Peppermint 9 changes owner and permissions on exe program files
« Reply #30 on: September 27, 2018, 03:57:45 am »
You're most welcome .. glad we got to the bottom of the problem :)
Feel free to remove those orphaned packages with
sudo apt-get remove --purge lockfile-progs pmountif you'd like.
And if you require the automount feature back in Peppermint 9, follow these instructions
https://forum.peppermintos.com/index.php/topic,7102.0.html
« Last Edit: September 27, 2018, 04:02:16 am by PCNetSpec »
