Author Topic: Peppermint 9 changes owner and permissions on exe program files (SOLVED)  (Read 3329 times)
Offline Matthew
  • Peppermint version(s): Peppermint 10 & 10 Respin
This is a new problem for me.  I have a Journal (word processor organizer) program installed on a USB drive and run it via WINE.  The USB drive and program works as it should in Windows and in Peppermint 8 as well as Peppermint 7.
Peppermint 9 always changes the owner to root and will not let the program load.  I've been trying to understand why the permissions and owner is always wrong in Peppermint 9 and I have been unable to change them.  I've tried opening the file manager as root and I have tried various command line methods to change the ownership but nothing works.  I don't have easy access to a Windows computer so that isn't feasible every time I need to run the program and I really do not want to have to log out of Peppermint 9 and into another system.
Has anyone else had this problem?  Is there a way to force the ownership to change and stay changed in Peppermint 9?
Thanks for any help you can offer.
« Last Edit: September 27, 2018, 03:58:38 am by PCNetSpec »
Offline Matthew
Re: Peppermint 9 changes owner and permissions on exe program files
« Reply #2 on: September 12, 2018, 11:14:46 pm »
I've tried every chown command I can find and the end result is always "Operation not  permitted."
« Reply #3 on: September 12, 2018, 11:26:59 pm »
sudo chown
« Reply #4 on: September 13, 2018, 06:51:56 am »
What file system is used on the USB stick (FAT32/NTFS/EXT4/etc.)
And how are you mounting the USB stick ?
(now that we dropped the automounter in Peppermint 9)
BTW, you do realise you can add the automounter back in Peppermint 9 if you wish
https://forum.peppermintos.com/index.php/topic,7102.msg72678.html#msg72678
Offline Matthew
« Reply #5 on: September 13, 2018, 09:36:13 am »
The stick is formatted as W95 FAT32 (LBA).
I usually mount the drive by opening a file manager and clicking on the drive.  The drive opens and shows files and the problem only occurs when I try to run a program.
I do miss the automounter and will eventually put it back in.
« Reply #6 on: September 13, 2018, 12:19:25 pm »
FAT32 doesn't support Linux-style permissions so that's likely the problem. ext4 would be better.
Offline Matthew
« Reply #7 on: September 13, 2018, 09:34:03 pm »
That is what is confusing to me.  It works fine on other machines running Linux systems and even works on an old Netbook running Peppermint 9.  :-\
« Reply #8 on: September 14, 2018, 09:27:21 am »
mount the drive in Peppermint 9, then post the output from
mount
then preferably do the same in Peppermint 8 .. so we can compare.
Offline Matthew
« Reply #9 on: September 14, 2018, 09:41:53 am »
Peppermint 9
matthew@matthew-Desktop-Peppermint-9-NY550AA-ABA-p6240f ~ $ mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=4034884k,nr_inodes=1008721,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=813328k,mode=755)
/dev/sda10 on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noexec,relatime,rdma)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=40,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=1244)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
mqueue on /dev/mqueue type mqueue (rw,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=813324k,mode=700,uid=1000,gid=1000)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
pcloud on /tmp/.mount_pcloud2KJhnV type fuse.pcloud (ro,nosuid,nodev,relatime,user_id=1000,group_id=1000)
/dev/fuse on /run/user/1000/doc type fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
pCloud.fs on /home/matthew/pCloudDrive type fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
/dev/sdh1 on /media/matthew/PATRIOT_128 type vfat (rw,nosuid,nodev,relatime,sync,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro,uhelper=udisks2)
Peppermint 8
matthew@matthew-Peppermint-8-Desktop-NY550AA-ABA-p6240f ~ $ mount
udev on /dev type devtmpfs (rw,nosuid,relatime,size=4035160k,nr_inodes=1008790,mode=755)
/dev/sda2 on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=27,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=14401)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,relatime)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=813328k,mode=700,uid=1000,gid=1000)
pcloud on /tmp/.mount_pcloudUzeAjo type fuse.pcloud (ro,nosuid,nodev,relatime,user_id=1000,group_id=1000)
/dev/sdh1 on /media/matthew/PATRIOT_128 type vfat (rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks2)
« Reply #10 on: September 14, 2018, 11:06:35 am »
Yes, there's a user and group ID involved in the mounting on Peppermint 8 somehow.
« Reply #11 on: September 14, 2018, 12:11:32 pm »
Okay that's weird, for some reason your USB stick isn't being mounted with the uid=1000 and gid=1000 options set.
With the USB stick plugged in, what's the output from
lsusb?
Now remove the USB stick and run:
sudo rm /media/matthew/PATRIOT_128(DO NOT run that command with the USB stick plugged in)
Now plug the USB stick back in and post the output from:
dmesg | tail -n 40and
mount
Offline Matthew
« Reply #12 on: September 14, 2018, 10:15:38 pm »
Here is the output with the stick plugged in but not mounted.
matthew@matthew-Desktop-Peppermint-9-NY550AA-ABA-p6240f ~ $ lsusb
Bus 002 Device 005: ID 058f:6362 Alcor Micro Corp. Flash Card Reader/Writer
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 003: ID 051d:0002 American Power Conversion Uninterruptible Power Supply
Bus 007 Device 002: ID 062a:4102 Creative Labs
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 009 Device 002: ID 1058:25a2 Western Digital Technologies, Inc.
Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 010 Device 003: ID 13fe:5500 Kingston Technology Company Inc.
Bus 010 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 0c45:760a Microdia
matthew@matthew-Desktop-Peppermint-9-NY550AA-ABA-p6240f ~ $ sudo rm /media/matthew/PATRIOT_128
[sudo] password for matthew:
rm: cannot remove '/media/matthew/PATRIOT_128': No such file or directory
matthew@matthew-Desktop-Peppermint-9-NY550AA-ABA-p6240f ~ $ dmesg | tail -n 40
[45330.924101] usb 10-3: USB disconnect, device number 3
[45454.696085] usb 10-3: new SuperSpeed USB device number 4 using xhci_hcd
[45454.841682] usb 10-3: New USB device found, idVendor=13fe, idProduct=5500
[45454.841686] usb 10-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[45454.841689] usb 10-3: Product: Patriot Memory
[45454.841691] usb 10-3: Manufacturer:
[45454.841693] usb 10-3: SerialNumber: 070B66A7EC5D6F07
[45454.842199] usb-storage 10-3:1.0: USB Mass Storage device detected
[45454.843814] scsi host4: usb-storage 10-3:1.0
[45456.791540] scsi 4:0:0:0: Direct-Access              Patriot Memory   PMAP PQ: 0 ANSI: 6
[45456.791969] sd 4:0:0:0: Attached scsi generic sg8 type 0
[45456.792637] sd 4:0:0:0: [sdh] 241827840 512-byte logical blocks: (124 GB/115 GiB)
[45456.792757] sd 4:0:0:0: [sdh] Write Protect is off
[45456.792760] sd 4:0:0:0: [sdh] Mode Sense: 23 00 00 00
[45456.792878] sd 4:0:0:0: [sdh] No Caching mode page found
[45456.792884] sd 4:0:0:0: [sdh] Assuming drive cache: write through
[45456.798289]  sdh: sdh1
[45456.799202] sd 4:0:0:0: [sdh] Attached SCSI removable disk
[45457.737142] FAT-fs (sdh1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[45516.948096] xhci_hcd 0000:03:00.0: Cannot set link state.
[45516.948108] usb usb10-port3: cannot disable (err = -32)
[45516.948115] usb 10-3: USB disconnect, device number 4
[45524.548084] usb 10-3: new SuperSpeed USB device number 5 using xhci_hcd
[45524.693667] usb 10-3: New USB device found, idVendor=13fe, idProduct=5500
[45524.693670] usb 10-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[45524.693673] usb 10-3: Product: Patriot Memory
[45524.693675] usb 10-3: Manufacturer:
[45524.693677] usb 10-3: SerialNumber: 070B66A7EC5D6F07
[45524.694168] usb-storage 10-3:1.0: USB Mass Storage device detected
[45524.694393] scsi host4: usb-storage 10-3:1.0
[45526.524492] scsi 4:0:0:0: Direct-Access              Patriot Memory   PMAP PQ: 0 ANSI: 6
[45526.524911] sd 4:0:0:0: Attached scsi generic sg8 type 0
[45526.526053] sd 4:0:0:0: [sdh] 241827840 512-byte logical blocks: (124 GB/115 GiB)
[45526.526166] sd 4:0:0:0: [sdh] Write Protect is off
[45526.526173] sd 4:0:0:0: [sdh] Mode Sense: 23 00 00 00
[45526.526286] sd 4:0:0:0: [sdh] No Caching mode page found
[45526.526291] sd 4:0:0:0: [sdh] Assuming drive cache: write through
[45526.528846]  sdh: sdh1
[45526.529962] sd 4:0:0:0: [sdh] Attached SCSI removable disk
[45527.471306] FAT-fs (sdh1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
/dev/sda6 on /media/matthew/Fedora-home type ext4 (rw,nosuid,nodev,relatime,data=ordered,uhelper=udisks2)
I usually get an error message when I try to unmount or eject the stick.
[Failed to eject "Patriot_128" Error opening /dev/sdh: Device or resource busy.]  That never occurs anywhere but Peppermint 9.
« Last Edit: September 14, 2018, 10:26:00 pm by Matthew »
« Reply #13 on: September 15, 2018, 04:27:28 pm »
Have you got a Windows PC that you can use to scan the USB stick for errors ?
Offline Matthew
« Reply #14 on: September 15, 2018, 10:03:54 pm »
Yes.  I plugged it into my wife's laptop and let it scan. Found no errors or problems.  It still works fine everywhere but Peppermint 9.
Does this look like a fixable problem?  If all else fails would a system reinstall cure it?  I'm fairly certain it isn't the stick.
« Last Edit: September 15, 2018, 10:13:00 pm by Matthew »
