Author Topic: Save and restore positions of desktop icons SOLVED  (Read 2100 times)
Offline mysticmuse
  • Peppermint version(s): mintUpdate 4.6.7+peppermint1
« on: September 05, 2018, 07:19:13 pm »
Is there a way to save and restore positions of desktop icons.   Two hours of searching and trying suggestion turned up nothing that works, and the script given in another thread on this forum did not work for me.
« Last Edit: September 08, 2018, 09:32:23 am by mysticmuse »
Re: Save and restore positions of desktop icons
« Reply #1 on: September 05, 2018, 07:32:22 pm »
Can you link to the post on this forum with the script, and I'll take a look at it tomorrow.
« Reply #3 on: September 06, 2018, 09:31:26 am »
cd ~/.local/share/nemo/scripts
wget "https://dl.opendesktop.org/api/files/download/id/1508087753/s/6ca610b6bbf9dc70fffef9f317aff642/t/1536355151/u//happy_desktop ver 2.00.zip"
unzip 'Happy_Desktop ver 2.00.zip'
Now when you right-click on the desktop and select "Scripts", you should see an item called "Happy_Desktop.sh" .. which can save/restore desktop icon positions.
Hint - When using the script, be aware the "Done" button is just a "Close" button .. the one you're likely to want is the "Select" button ;)
« Last Edit: September 07, 2018, 04:27:04 pm by PCNetSpec »
Offline mysticmuse
« Reply #4 on: September 07, 2018, 03:56:33 pm »
Thanks, but I got to the unzip stage and it gave error, see below.
But I found a good copy and downloaded  it from here:
https://www.gnome-look.org/p/1195331/
Thanks Again!
$ unzip 'Happy_Desktop ver 2.00.zip'
Archive:  Happy_Desktop ver 2.00.zip
  End-of-central-directory signature not found.  Either this file is not
  a zipfile, or it constitutes one disk of a multi-part archive.  In the
  latter case the central directory and zipfile comment will be found on
  the last disk(s) of this archive.
note:  Happy_Desktop ver 2.00.zip may be a plain executable, not an archive
unzip:  cannot find zipfile directory in one of Happy_Desktop ver 2.00.zip or
        Happy_Desktop ver 2.00.zip.zip, and cannot find Happy_Desktop ver 2.00.zip.ZIP, period.
« Last Edit: September 07, 2018, 05:39:28 pm by AndyInMokum, Reason: encapsulating with [/code] »
« Reply #5 on: September 07, 2018, 04:19:08 pm »
I take it you got it working ?
wget command fixed above.
« Last Edit: September 07, 2018, 04:28:33 pm by PCNetSpec »
Offline mysticmuse
« Reply #6 on: September 07, 2018, 04:42:57 pm »
It seems to work but on starting to run it it started asking me about icon rows/spacing so I assume that it was about to rearrange all my desktop icons according to a fixed grid system.  But I want to keep my icons just as they are and be able to restore them that way in the event of an unexpected change.  Apparently the program doesn't let you keep your existing desktop??
« Reply #7 on: September 07, 2018, 05:01:25 pm »
It does allow you to save your current layout and restore it.
The questions at the beginning are for a different feature .. just enter something like
12 colums
8 rows
Offline mysticmuse
« Reply #8 on: September 07, 2018, 06:28:13 pm »
Wow, it works great.  Thanks much.
« Reply #9 on: September 07, 2018, 06:52:59 pm »
No problem.
Can you please remember to mark the topic (SOLVED), by editing the FIRST posting in this topic and appending (SOLVED) to the subject line .. TIA :)
