Author Topic: I found a new HOSTS file today...  (Read 1213 times)
    • My MeWe profile
« on: September 02, 2018, 01:14:14 pm »
while answering some questions for a buddy on iOS who wanted Blokada... I discovered a new hosts file today...   8)
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
Extending and consolidating hosts files from several well-curated sources like adaway.org, mvps.org, malwaredomainlist.com, someonewhocares.org, and potentially others. You can optionally invoke extensions to block additional sites by category.
For those of you who use HOSTS...   ;)
« Last Edit: September 02, 2018, 01:16:39 pm by spence »
 '18 Asus VivoBook
    • My MeWe profile
Re: I found a new HOSTS file today...
« Reply #1 on: September 03, 2018, 03:45:20 pm »
I was more selective in the types of google services I unblocked, so happily Ancestry.com is still functional for me... I was wondering how this list compared with the one you have in Peppermint 9's Advert Block @PCNetSpec?
 '18 Asus VivoBook
« Reply #2 on: September 03, 2018, 04:41:29 pm »
Oh chr*st, I dunno spence, they're far too big to go through and compare ???
Wouldn't matter what **I** thought anyway .. use whichever work for YOU my friend.
« Last Edit: September 03, 2018, 04:43:41 pm by PCNetSpec, Reason: typo »
Offline VinDSL
« Reply #3 on: September 03, 2018, 05:08:50 pm »
May I suggest...?
9 Best File Comparison and Difference (Diff) Tools for Linux
My personal favorite is DiffMerge.
I use it for checking for differences in contracts - and, changes I've made to program code.
Having a 29" (or larger) monitor helps  ;)
« Reply #4 on: September 03, 2018, 08:29:45 pm »
Though I'm not sure a "diff" app would help here .. I'm not sure spence is actually being that specific.
But, here's a VERY useful Nemo plugin anyway...
In addition to your "9 diff tools" link, you could install
sudo apt-get install nemo-compare
then log off/on.
Now you can right-click any file or folder and select "Compare Later" .. then right-click any other file or folder and select "Compare to <name of previous file/folder>" to compare their contents.
I find this Nemo context menu plugin (for Meld) invaluable.
Comparing 2 text files
Comparing two folders
HINT - The first time you use it, and get the meld window pictured above, you might want to go to
Meld > Preferences
and change
Syntax highlighting color scheme: Peppermint
otherwise the differences highlighted differences in text files are hard to read.
HINT 2 - You might also want to check out Meld which will now also in the main menu when you installed nemo-compare. (Meld is mentioned in VinDSL's link, and is the actual app nemo-compare is using)
HINT 3 - It also has a "File > Format as Patch" option, that will allow you to save the differences as a diff patch (in either direction).
« Last Edit: September 03, 2018, 08:58:58 pm by PCNetSpec »
    • My MeWe profile
« Reply #5 on: September 07, 2018, 03:20:19 pm »
Excellent, I compared the Dan Pollock host file with the newly discovered Steven Black one and found them to be exact copies, save the extra explanation Dan adds to his file to explain what each subset of 0.0.0 domains are blocking.
 '18 Asus VivoBook
Offline VinDSL
« Reply #6 on: September 07, 2018, 06:52:35 pm »
Comparators FTW  ;D
