Author Topic: wake from sleep failure (SOLVED)  (Read 7153 times)
Re: wake from sleep failure
« Reply #15 on: August 01, 2014, 05:56:38 pm »
Does it resume from suspend if you enter suspend with:
sudo pm-suspend --quirk-vbemode-restore
if that doesn't work .. try it with a single hyphen:
sudo pm-suspend -quirk-vbemode-restore
if it resumes from either of those .. let us know which.
Offline MattD
  • Peppermint version(s): 5
Re: wake from sleep failure (SOLVED)
« Reply #16 on: August 22, 2014, 12:25:32 pm »
YAAY! Both sleep and hibernate work for me now. Here's what I did:
Followed instructions from this thread:
ubuntuforums.org/showthread.php?t=2219537
which i think is basically what was posted earlier creating a com.ubuntu.enable-hibernate.pkla file
Followed instructions #2-5 from this thread:
ubuntuforums.org/showthread.php?t=2143370
Not sure which fixed one or both, but now I can both suspend and hibernate my laptop and recover.
Matt
« Reply #17 on: August 22, 2014, 02:06:50 pm »
Great news .. thanks for posting the solution :)
« Reply #18 on: November 30, 2014, 10:31:54 am »
Hi MattD, how's it going?  I see you have run foul of the hibernation issue.  For some unexplained reason Ubuntu has decided to disable the hibernate feature on their 14.04 release  :-\.  Anyway hibernate works from the command line.  Open a terminal, Ctrl+Alt+t.  Enter the following command:
sudo pm-hibernate
Hit enter and do the password thing if asked.
