Author Topic: 32-bit Users: All Hail Linux 4.18 (Released 12-AUG-2018)  (Read 2283 times)
« on: August 13, 2018, 02:48:53 pm »
OMG!  :o
I haven't had any joy running 32-bit Peppermint 9 on top of anything except Linux 4.15, until now.
Mind you, this Dell Dimension 3000 test machine is an oddball, but still, I expected it would run on a newer kernel. My 32-bit Mountain Mods custom game box runs fine on Linux 4.16.
Anyway, so far, so good. I hope I'm not dreaming all this ...
vindsl@Fenris-2 ~ $ sudo inxi -SGCMm
[sudo] password for vindsl:
System:    Host: Fenris-2 Kernel: 4.18.0-041800-generic i686 bits: 32
           Console: tty 2 Distro: Peppermint Nine
Machine:   Device: desktop System: Dell product: Dimension 3000 serial: CKYBY51
           Mobo: Dell model: 0N6381 serial: ..CN4811148L04H2.
           BIOS: Dell v: A03 date: 01/05/2006
CPU:       Single core Intel Pentium 4 (-MT-) cache: 1024 KB
           clock speeds: max: 2992 MHz 1: 2992 MHz 2: 2992 MHz
Memory:    Used/Total: 242.8/2010.1MB
           Array-1 capacity: 4 GB devices: 2 EC: None
           Device-1: DIMM_1 size: 1 GB speed: 400 MT/s type: SDRAM
           Device-2: DIMM_2 size: 1 GB speed: 400 MT/s type: SDRAM
Graphics:  Card-1: Intel 82865G Integrated Graphics Controller
           Card-2: NVIDIA G98 [GeForce 8400 GS Rev. 2]
           Display Server: X.Org 1.19.6 driver: nvidia
           Resolution: 1920x1080@60.00hz
           OpenGL: renderer: GeForce 8400 GS/PCIe/SSE2 version: 3.3.0 NVIDIA 340.106
vindsl@Fenris-2 ~ $ systemd-analyze time
Startup finished in 3.507s (kernel) + 10.412s (userspace) = 13.919s
graphical.target reached after 10.350s in userspace
vindsl@Fenris-2 ~ $ systemd-analyze critical-chain
The time after the unit is active or started is printed after the "@" character.
The time the unit takes to start is printed after the "+" character.
graphical.target @10.350s
└─multi-user.target @10.350s
  └─smbd.service @10.051s +297ms
    └─nmbd.service @9.221s +826ms
      └─network-online.target @9.203s
        └─NetworkManager-wait-online.service @8.346s +856ms
          └─NetworkManager.service @7.507s +833ms
            └─dbus.service @7.413s
              └─basic.target @7.389s
                └─sockets.target @7.388s
                  └─cups.socket @7.387s
                    └─sysinit.target @7.372s
                      └─systemd-timesyncd.service @7.098s +273ms
                        └─systemd-tmpfiles-setup.service @6.402s +383ms
                          └─systemd-journal-flush.service @852ms +5.547s
                            └─systemd-journald.service @575ms +274ms
                              └─syslog.socket @571ms
                                └─system.slice @537ms
                                  └─-.slice @531ms
EXTRA CREDIT READING: "Linux Kernel 4.18 Keeps Things Solid and Secure" (13-AUG-2018) ~ Linux.com
« Last Edit: August 13, 2018, 03:03:08 pm by VinDSL »
Re: 32-bit Users: All Hail Linux 4.18 (Released 12-AUG-2018)
« Reply #1 on: August 13, 2018, 05:14:48 pm »
What's 32-bit? :P
Offline rjm65
« Reply #2 on: August 14, 2018, 05:14:11 am »
will it work on 32 bit NON PAE processors????
if so would Mark kindly make a 32 bit non pae version???
Robert
Peppermint 9 User
Gateway Solo 9300 Pro
IBM T40
« Reply #3 on: August 16, 2018, 07:30:08 pm »
Not sure, but this new kernel is unreal.
Just updated to 4.18-1 and it knocked another 2 sec off my boot time.
vindsl@Fenris-2 ~ $ sudo inxi -CDMSfm
System:    Host: Fenris-2 Kernel: 4.18.1-041801-generic i686 bits: 32
           Console: tty 0 Distro: Peppermint Nine
           CPU Flags: acpi apic bts cid clflush cmov constant_tsc cpuid cx8 de
           ds_cpl dtes64 dts fpu fxsr ht mca mce mmx monitor msr mtrr pae pat pbe
           pebs pge pni pse pse36 sep ss sse sse2 tm tsc vme xtpr
Memory:    Used/Total: 430.0/2009.7MB
Drives:    HDD Total Size: 60.0GB (10.0% used)
           ID-1: /dev/sda model: Patriot_Flare size: 60.0GB
Startup finished in 3.541s (kernel) + 8.324s (userspace) = 11.866s
graphical.target reached after 8.275s in userspace
graphical.target @8.275s
└─multi-user.target @8.275s
  └─smbd.service @7.824s +450ms
    └─nmbd.service @6.035s +1.786s
      └─network-online.target @6.013s
        └─NetworkManager-wait-online.service @5.122s +890ms
          └─NetworkManager.service @3.663s +1.452s
            └─dbus.service @3.509s
              └─basic.target @3.503s
                └─sockets.target @3.503s
                  └─avahi-daemon.socket @3.503s
                    └─sysinit.target @3.493s
                      └─systemd-timesyncd.service @3.289s +203ms
                        └─systemd-tmpfiles-setup.service @3.161s +105ms
                          └─local-fs.target @3.149s
                            └─home.mount @3.029s +119ms
                              └─systemd-fsck@dev-disk-by\x2duuid-313646ae\x2d3bf5\x2d4
                                └─dev-disk-by\x2duuid-313646ae\x2d3bf5\x2d4484\x2dbfa7
« Last Edit: August 16, 2018, 07:57:58 pm by VinDSL »
Offline plumtreed
  • Been using Peppermint since it's start-up
  • Peppermint version(s): 10 64bit
« Reply #4 on: August 19, 2018, 05:33:15 am »
This is always interesting stuff.....I am amazed at the speed of Peppermint.
one question, have you disabled 'hddtemp' via systemctl or has it just not appeared on your unit? :-\
« Reply #5 on: August 19, 2018, 08:11:05 am »
Good eye and a keen mind!  :)
No, I didn't disable it.
Interestingly enough , this Dell Dimension 3000 didn't come with any sensors (from the factory), so there's nothing to monitor OOTB.
It does have a NTC thermistor physically sitting under the CPU, which controls the CPU cooling fan speed , but it's not a digital device - thus, no readings available.
Technically speaking, there are two temperature sensors in this machine now - one in the 60GB Patriot Flare SSD - and, one in the nVidia GeForce 8400 GS PCI card.
I monitor the nVidia PC card temps via my Conky script, becaise it has one of those tiiny cooling fans that look cute, but are prone to failure - and usually take out the GPU with it.
Here's the temp on my Patriot Flare, as I type, if you're curious.
vindsl@Fenris-2 ~ $ sudo hddtemp /dev/sda
/dev/sda: Patriot Flare: 33°C
No worries there...  ;)
Offline plumtreed
« Reply #6 on: August 19, 2018, 03:01:47 pm »
.....thats cool! :D
My boot time is slowed a few seconds by the 'hddtemp' but I guess I prefer to have it triggered at boot-up and sacrifice the boot time.
Hey, thanks for your words of wisdom :)
« Reply #7 on: September 16, 2018, 08:29:26 am »
In anticipation of the upcoming 4.19 release, I've started 'file-raping' the Canonical Team Unstable Kernel Repo. LoL  ;D
Here's a Peppermint 7 Xenial/Cosmic Cowboy Build (different 32bit machine than the one above)...
╭─vindsl@Boogaloo-6 ~
╰─➤  sudo inxi -CDMSfm
System:    Host: Boogaloo-6 Kernel: 4.18.0-8-generic i686 (32 bit)
Machine:   Mobo: N/A model: Canterwood
           Bios: Phoenix v: 6.00 PG date: 04/09/2004
CPU:       Single core Intel Pentium 4 (-HT-) cache: 2048 KB
           clock speeds: max: 3407 MHz 1: 3407 MHz 2: 3407 MHz
           CPU Flags: acpi apic bts cid clflush cmov cpuid cx8 de dts fpu fxsr
           ht mca mce mmx msr mtrr pae pat pbe pebs pge pse pse36 sep ss sse
Memory:    Array-1 capacity: 4 GB devices: 4 EC: None
           Device-1: A0 size: 512 MB speed: N/A type: SDRAM
           Device-2: A1 size: 512 MB speed: N/A type: SDRAM
           Device-3: A2 size: 512 MB speed: N/A type: SDRAM
           Device-4: A3 size: 512 MB speed: N/A type: SDRAM
Drives:    HDD Total Size: 1029.7GB (13.3% used)
           ID-1: /dev/sda model: Maxtor_91366U4 size: 13.5GB
           ID-2: /dev/sdb model: SAMSUNG_HD103SJ size: 1000.2GB
           ID-3: USB /dev/sdc model: Cruzer size: 16.0GB
Working great, so far...
« Reply #8 on: September 16, 2018, 08:41:21 am »
Bwahahahahaha!
I was looking at the dialog above and saw:
ID-3: USB /dev/sdc model: Cruzer size: 16.0GBI wondered where that damned thing went. This machine doesn't have USB ports, accessible from the front.
Guess I must have plugged it in the back and forgot about it...  :D
