Author Topic: Peppermint 9 on Intel stck1a32wfc  (Read 810 times)
Offline polly
« on: August 13, 2018, 12:30:15 am »
Hello again.  I removed Windows from the stick computer and converted it into a Linux machine.  It now runs 3 onboard Linux distributions and Windows 10 is installed on an external usb hard drive for use if and when.  Recently i re-visited the Peppermint website and once I found that Peppermint 9 had been released i was anxious to try it (especially after all the effort by the team to get Peppermint 8 working).  I keep Peppermint 8 up to date on another machine by the way.
I am pleased to report that Peppermint 9 installed straight away without any problems.  I downloaded it, installed it on a usb stick and then on the stck1a32wfc.  That was it, there was nothing else to do.  It is stable, starts and stops swiftly and has vlc which is a big plus for me  So a big thank you from me.
Wish list:  One thing that I miss from Windows is Netmeter - a simple real time graphical presentation of the network download and upload speed.  I wondered whether something like this is available for Peppermint Linux?.
Cheers all.
Re: Peppermint 9 on Intel stck1a32wfc
« Reply #1 on: August 13, 2018, 01:40:16 am »
Hi polly,
You might want to check out the package xfce4-netload-plugin.
Offline polly
« Reply #2 on: August 13, 2018, 05:45:56 am »
Hi Slim.
Thanks for the information.  I have found the package and some documentation so off to do some leaning.
Regards
Polly
Offline polly
« Reply #3 on: August 13, 2018, 07:37:27 am »
Hi Slim.
Done.  That was easier than I thought it would be.  Many thanks.
Polly
Offline VinDSL
« Reply #4 on: August 13, 2018, 11:37:49 am »
xfce4 - the gift that keeps on giving...  ;D
« Reply #5 on: August 13, 2018, 12:03:16 pm »
Hi polly,
Glad the information was of use. If you are satisfied that your issue has been resolved, please go back to your first post in this thread, click on Modify (found in the upper right corner) and then add (SOLVED) at the end of the Subject: line of that post. Post the result and you're finished!  8)
