Author Topic: Window control buttons to the left (SOLVED)  (Read 733 times)
Offline darrel_jw
  • Peppermint version(s): OS 8 respin 2
« on: August 06, 2018, 02:48:07 am »
Can I move the window control buttons (minimize, maximize, close) from the right side of window to the left?
Darrel
« Last Edit: August 06, 2018, 04:45:15 am by darrel_jw »
Re: Window control buttons
« Reply #1 on: August 06, 2018, 04:14:04 am »
Yes.
Open a terminal and run:
xfwm4-settingsOn the "Style" tab, under the "Button Layout" heading, drag the buttons to wherever you want them .. this will be reflected in any open application widows.
Offline darrel_jw
« Reply #2 on: August 06, 2018, 04:39:08 am »
Thank you! I knew it was there someplace.  ;D
Darrel
« Reply #3 on: August 06, 2018, 04:43:26 am »
You're most welcome :)
Can you please remember to mark the topic (SOLVED) .. you can do this by editing the FIRST posting in this topic and changing
Subject: Window control buttons
to
Subject: Moving window control buttons to the left (SOLVED)
Which will help others with the same question find a known working solution
TIA :)
