Author Topic: Teamviewer 13...(Unsolved Mystery)  (Read 3458 times)
Offline Kbrewer
« on: August 04, 2018, 05:30:27 pm »
I have downloaded Teamviewer 13 on my Dell Dimension 2400 bit..(Iknow old and wornout like me). Tried both regular program and host program, but when I try to open a dialog box in the program all I get is a box with the menu bar at top and a blank screen where the dialog should be at. I ask your forgivness if I am using the wrong termanology for what I am describing. Would post a screen shot if I knew how.
« Last Edit: August 08, 2018, 03:48:28 pm by Kbrewer »
Offline peppycrab
Re: Teamviewer 13
« Reply #1 on: August 05, 2018, 01:57:04 am »
Sometimes I get a black screen when connecting to my upstairs PC (I am currently couch-bound with a fractured ankle). Rebooting my netbook always solves that problem.
Offline TonyBronze
  • Peppermintaholic
Re: Teamviewer 13
« Reply #2 on: August 05, 2018, 02:11:31 am »
Kbrewer, what version of Peppermint are you using?
Offline Kbrewer
Re: Teamviewer 13
« Reply #3 on: August 05, 2018, 07:43:54 am »
I am using peppermint 7.
Re: Teamviewer 13
« Reply #4 on: August 05, 2018, 09:31:51 am »
Offline Kbrewer
Re: Teamviewer 13
« Reply #5 on: August 05, 2018, 10:33:21 am »
    .......Cool Cool Cool :)
Re: Teamviewer 13
« Reply #6 on: August 05, 2018, 02:25:00 pm »
So where's the blank screen where the dialog is supposed to be?
Offline Kbrewer
Re: Teamviewer 13
« Reply #7 on: August 05, 2018, 03:54:36 pm »
right under the bar that says teamviewer the rocks are my screen theme
Re: Teamviewer 13
« Reply #8 on: August 05, 2018, 04:07:12 pm »
Okay, that image of the rocks, is that your desktop on the host (and you've trimmed it in an editor) .. or is it the desktop on the client ?
Offline Kbrewer
Re: Teamviewer 13
« Reply #9 on: August 05, 2018, 04:08:38 pm »
Maybe this showes better what I am talking about
Re: Teamviewer 13
« Reply #10 on: August 05, 2018, 04:19:12 pm »
Ah right...
Has teamviewer ever worked ?
What happens if (with teamviewer closed) you open a terminal and run:
mv -v ~/.config/teamviewer ~/.config/teamviewer-oldthen
mv -v ~/.local/share/teamviewer13 ~/.local/share/teamviewer13-oldthen
mv -v ~/.cache/TeamViewer ~/.cache/TeamViewer-oldthen try to start teamviewer
/opt/teamviewer/tv_bin/script/teamviewer
« Last Edit: August 05, 2018, 04:22:47 pm by PCNetSpec »
Offline Kbrewer
Re: Teamviewer 13
« Reply #11 on: August 05, 2018, 04:42:31 pm »
Not in peppermint 7.  Downloaded Ubuntu 16.4 on another hard drive and it will work with it I just did not like the Ubuntu it was way slow reacting to commands
Re: Teamviewer 13
« Reply #12 on: August 05, 2018, 04:53:08 pm »
So what happens if you run the 4 commands above ?
Offline Kbrewer
Re: Teamviewer 13
« Reply #13 on: August 05, 2018, 04:54:31 pm »
Followed your steps and this is what I got
Re: Teamviewer 13
« Reply #14 on: August 05, 2018, 05:08:24 pm »
Can you post the output of
inxi -Fzbut NOT as a screenshot .. as text (so it's searchable).
