Author Topic: (SOLVED) Problem installing Windows 7 in Virtual Box  (Read 2085 times)
Offline jozefmw
« on: July 28, 2014, 08:35:36 am »
Error:
AMD-V is disabled in the BIOS (or by the host OS). (VERR_SVM_DISABLED).
Fehlercode:
NS_ERROR_FAILURE (0x80004005)
Komponente:
Console
Interface:
IConsole {8ab7c520-2442-4b66-8d74-4ff1e195d2b6}
« Last Edit: July 28, 2014, 10:28:24 am by jozefmw »
Re: Problem installing Windows 7 in Virtual Box
« Reply #1 on: July 28, 2014, 08:46:54 am »
If you haven't got a setting in your BIOS to enable AMD-V .. you'll need to install a 32bit version of Win7 in your VM
Offline jozefmw
(SOLVED) Re: Problem installing Windows 7 in Virtual Box
« Reply #2 on: July 28, 2014, 10:28:01 am »
32 Bit works ...
Thank's a lot !
Jozef
Re: (SOLVED) Problem installing Windows 7 in Virtual Box
« Reply #3 on: July 28, 2014, 12:26:42 pm »
No problem .. thanks for marking the topic solved :)
