Author Topic: UK's National Cyber Security Centre Gives Advice on Securing Ubuntu 18.04 LTS  (Read 5261 times)
Offline VinDSL
Securing Ubuntu Linux to meet the twelve EUD principles: https://goo.gl/PNJRFG
Online PCNetSpec
That's handy .. not that I fully agree with it all, but it does contain some useful stuff :)
Offline VinDSL
I agree with it more than the copy n' paste tripe that I read on US sites ...  ::)
Online PCNetSpec
I'm not saying they're "wrong", more that I don't think it's all "necessary" or is phrased in a way that may make certain things **seem** weaker that they are .. but I guess if you're looking at it from an "as secure as possible" standpoint it's got some useful stuff in there.
The little things I'm not overly convinced about are things like AppArmor profiles .. unless you make them yourself.
And though it's title suggests it's about 18.04, it mentions gksudo and gksu .. these are not available in 18.04, I had to add them back into our repos for Peppermint 9
(18.04 is now fully pkexec .. I added gksu back because not having it would exclude some older software people may want to run)
It's just little things, I'm not saying it's not a useful article.
And in overlooking 18.04 not having gksu they've overlooked pkexec/PolicyKit policies.
[EDIT2]
They also suggest "Several third-party anti-malware products exist which attempt to detect malicious code for this platform" .. I don't see these as necessary or beneficial, and they may be an attack vector in their own right.
And then there's "Enable secure boot" .....
« Last Edit: August 01, 2018, 07:20:14 pm by PCNetSpec »
Would you be happy entrusting your cyber security to GCHQ anyway?
Overall Ubuntu and Pepprmint look to me like tight ships.  The existence of the Apport feature in Ubuntu catches my eye, though I've never seen any equivalent feature to Ubuntu's Apport in Peppermint.  Practically speaking however, to the average end user of Ubuntu,  I doubt Apport would pose much of a risk either.  Still this is still good info to be aware of.  Thank you, VinDSL. :)
Offline VinDSL
Just when I was getting a real burn going against Linux 4.15.0-29.31
Look what I found - a signed kernel image  ...  8)
vindsl@Boogaloo-6 ~ $ inxi -SM
System:    Host: Boogaloo-6 Kernel: 4.15.0-29-generic x86_64 bits: 64 Desktop: N/A
           Distro: Peppermint Nine
Machine:   Device: desktop System: Dell product: OptiPlex 7010 v: 01 serial: N/A
           Mobo: Dell model: 0GXM1W v: A02 serial: N/A
           UEFI: Dell v: A28 date: 02/22/2018
vindsl@Boogaloo-6 ~ $ [ -d /sys/firmware/efi ] && echo UEFI || echo BIOS
UEFI
vindsl@Boogaloo-6 ~ $ mokutil --sb-state
SecureBoot enabled
Offline VinDSL
Now that I have UEFI/Secure Boot working, and I'm thinking about security ...
I enabled the 'Uncomplicared Firewall' (disabled by default):
sudo ufw enable
Sanity Test #1
vindsl@Boogaloo-6 ~ $ sudo ufw status verbose
Status: active
Logging: on (low)
Default: deny (incoming), allow (outgoing), disabled (routed)
New profiles: skip
And, I (re)set the root password (locked by default) :
sudo passwd
Sanity Test #2
vindsl@Boogaloo-6 ~ $ su -
Password:
root@Boogaloo-6 ~ #
Been working fine for hours. That's good enough for now, I suppose.
Offline VinDSL
You're welcome, perk  ;)
Online PCNetSpec
I'm not convinced activating a root password is a good idea .. personally I think the hashed one even you don't know (but elevate privileges via a time limited sudo) is safer ;)
Offline VinDSL
I've set the 'UNIX password', off n' on, over the years. Sometimes, I actually need root auth for something I'm doing, but it's rare. I don't do it out of rote. I guess it wouldn't make any difference, from a security standpoint, unless someone had physical access to a machine, like a laptop for instance, and booted with root auth via the recovery mode. What are the chances of that? Most thieves are winders users.
Dittos for the firewall. My LAN is behind a NAT router (which mimics a firewall). Good luck finding a machine behind a NAT. So, really, what difference does it make?
I'm still in a 'testing mode', I guess, seeing what works and what doesn't. That said, I always use Secure Boot, when given the opportunity, so I'm tickled pink having it working in 4.15, even if it is a haxor.
Speaking of which, I stripped that signed image out of a meta package, and installed it manually. Synaptic bulks at it - wants to downgrade to the unsigned image that it replaced. So, I don't recommend anyone trying this, just yet.
I was thinking about this signed/unsigned situation, while I was sleeping last night, and the Canonical Kernel Team has been designating signed kernel in the file name, in the past. Now, it *seems* that they've swung the opposite direction, and started designating unsigned kernels in the name.
I *wonder* (and wander) if they are going to make all future kernels signed, e.g. the new norm.
Hrm   :-\
Anyway, I ran across that signed kernel image purely by chance.  I didn't realize it was signed until Synaptic went nutz.
I configured/enabled Secure Boot in BIOS, and it's all good. Even Belarc Advisor is happy - no more warnings  ;D
Online PCNetSpec
I think that's the plan as a signed kernel will still work on a non UEFI system .. otherwise you'd need 2 kernels on a LiveUSB (which they used to have, now they only have one, it's not designated "signed" but it is).
Offline VinDSL
As fate would have it, Linux 4.15.-31.33 (including signed) just hit the Canonical Kernel Team PPA  ;D
We'll see how it goes ...
Offline VinDSL
Interesting. Never seen these dialogs before ... 8)
Offline VinDSL
Well, how cool is that?!? I just generated/installed my own custom Secure Boot key @ first boot.
System:    Host: Boogaloo-6 Kernel: 4.15.0-31-generic x86_64 bits: 64 Desktop: N/A Distro: Peppermint Nine
           Mobo: Dell model: 0GXM1W v: A02 serial: N/A UEFI: Dell v: A28 date: 02/22/2018
UEFI
SecureBoot enabled
Looks like the devs are getting keen on securing Ubuntu Peppermint  ;D
