Author Topic: Peppermint 5 - Screenshots saved on desktop from PrtSC key.  (Read 3849 times)
Do you want the PrtSC (print screen) key to save a screenshot to your desktop automatically instead of your home folder .. with a name that includes the time and date ?
Do you want Alt+PrtSc to save a screenshot of just the currently active window to your desktop automatically instead of your home folder .. with a more meaningful name that includes the date and time ?
Here's how
First let's backup the current xbindkeys.conf file .. open a terminal and run:
cp -v ~/.config/peppermint-control-center/xbindkeys.conf ~/.config/peppermint-control-center/xbindkeys.conf.bak
Now open xbindkeys.conf for editing .. run:
gedit ~/.config/peppermint-control-center/xbindkeys.conf
Find the 2 sections:-
"scrot"
   Print
"scrot -u -b"
   Alt + Print
and change them to:-
#Print Screen
"scrot 'Screenshot_%Y-%m-%d_%H:%M:%S.png' -e 'mv $f ~/Desktop/'"
   Print
#Print Window
"scrot -u -b 'Windowshot_%Y-%m-%d_%H:%M:%S.png' -e 'mv $f ~/Desktop/'"
   Alt + Print
SAVE the file, and LOG OFF/ON
Now test.
Hitting PrtSc should leave a full desktop screenshot on your desktop with a name like
Hitting Alt+PrtSc should leave a screenshot of just the active window on your desktop with a name like
If you have any problems with this tutorial, please start a topic in the main forum and we'll try to assist :)
« Last Edit: July 28, 2014, 10:21:27 am by PCNetSpec »
