Author Topic: Missing shutdown button [SOLVED]  (Read 907 times)
Offline crazysquirrel
  • Peppermint version(s): 8 - 32 bit
« on: July 26, 2018, 01:53:40 pm »
The shutdown button is grayed out. Only way to shut down a desktop was to manually shut it off by the power switch.
How to fix this??
« Last Edit: July 27, 2018, 10:11:56 am by crazysquirrel »
Offline TonyBronze
  • Peppermintaholic
Re: Missing shutdown button
« Reply #1 on: July 26, 2018, 02:19:14 pm »
Can you right click on the menu button in the task bar, a box should pop up titled whisker menu.
Click on properties then click on the commands tab
4th one down should say Log out.  In the box after it does it say
peppermint-logout
If not change it to peppermint-logout,  If it does, report back.
« Reply #2 on: July 26, 2018, 03:07:31 pm »
Did you keep a home partition from a previous distro or Peppermint version ?
« Reply #3 on: July 26, 2018, 03:17:06 pm »
it is a desktop for a friend that switched from XP to peppermint.
Will have to wait a week before I can look at it again.
Fresh install too.
Took everything at default on the install.
« Reply #4 on: July 26, 2018, 03:18:02 pm »
wife handed me a screwdriver this morning.
I asked what is this for?
She said I needed it because I have a 'screw loose'
go figure.
« Reply #5 on: July 26, 2018, 03:22:02 pm »
If this is Peppermint 8, there is a "Panel Reset" function in the Peppermint Settings Panel.
« Reply #6 on: July 27, 2018, 10:10:51 am »
it worked! YEA! lol
