Author Topic: Capture Problems n OBS-Studio with AMD graphics [SOLVED]  (Read 1513 times)
« on: July 26, 2018, 10:06:15 am »
Hi
I am trying to use OBS to capture my ETS2 game play as per usual - however
In Pep 9 with the AMD card I am getting a black window when I tell it to look at the ETS window.
This does not happen in windows 10 and does not happen in Fedora 28
Both Pep and Fedora are using
zebedee@i7-peppermint ~ $ glxinfo | grep "OpenGL version"
OpenGL version string: 3.0 Mesa 18.0.5
ps I have tried all things I can find in google search
This happens on the 4.15.0-29 kernel and the 4.17.9-041709 kernel
« Last Edit: July 27, 2018, 03:41:33 am by zebedeeboss »
Offline TonyBronze
  • Peppermintaholic
Re: Capture Problems n OBS-Studio with AMD graphics
« Reply #1 on: July 26, 2018, 10:15:21 am »
Have you tried selecting use alpha less texture format (Mesa Workaround)  Scroll to the bottom of the window properties to find it.
« Reply #2 on: July 26, 2018, 10:16:55 am »
Hiya TB,
Yeah and all I get is a washed out pink affect  :(
Offline TonyBronze
  • Peppermintaholic
« Reply #3 on: July 26, 2018, 10:36:40 am »
Hiya Zeb
Bit of a long shot but are you using a Peppermint Theme?  If so can you try using Adwaita-dark to eliminate that it may be a problem.
Reason being, Kdenlive doesn't like the Peppermint themes and gives black boxes for the save as /open file boxes but works fine with Adwaita-Dark.
Tony
« Reply #4 on: July 26, 2018, 10:43:44 am »
Hiya TonyB
Great shout but no luck unfortunately.  A friend of mine DasGeek, also has a Vega 64 card and he says he does not get the issue with xubuntu.  Very odd
« Reply #5 on: July 26, 2018, 11:00:48 am »
When I try and install OBS from the OBS PPA I am getting the following error
E: /var/cache/apt/archives/obs-studio_21.1.0-0obsproject1~bionic_amd64.deb: trying to overwrite '/usr/share/obs/libobs/bicubic_scale.effect', which is also in package libobs0:amd64 21.0.2+dfsg1-1
and then this
(Reading database ... 384009 files and directories currently installed.)
Preparing to unpack .../obs-studio_21.1.0-0obsproject1~bionic_amd64.deb ...
Unpacking obs-studio (21.1.0-0obsproject1~bionic) over (21.0.2+dfsg1-1) ...
dpkg: error processing archive /var/cache/apt/archives/obs-studio_21.1.0-0obsproject1~bionic_amd64.deb (--unpack):
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
E: Sub-process /usr/bin/dpkg returned an error code (1)
A package failed to install.  Trying to recover:
Processing triggers for mime-support (3.60ubuntu1) ...
Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.1) ...
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Processing triggers for gnome-menus (3.13.3-11ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Offline TonyBronze
  • Peppermintaholic
« Reply #6 on: July 26, 2018, 12:15:47 pm »
I got the same error with the PPA and ended up using the snap pack
Re: Capture Problems n OBS-Studio with AMD graphics [SOLVED]
« Reply #7 on: July 26, 2018, 01:22:13 pm »
Thanks TonyB,
The Snap pack of OBS-Studio worked
« Reply #8 on: July 26, 2018, 04:27:15 pm »
If you want the PPA version, try running:
sudo apt-get remove --purge libobs0then installing the version from the PPA
« Reply #9 on: July 27, 2018, 02:46:30 am »
Thanks
I will keep those instructions to hand if the Snap version gives me grief.
Offline TonyBronze
  • Peppermintaholic
« Reply #10 on: July 27, 2018, 02:55:58 am »
I have tried it and it worked to install the PPA version.
« Reply #11 on: July 27, 2018, 03:32:05 am »
Oh this just gets better and better - Sigh!!!
Now the snap OBS does not recognise my video driver...
Gong to try the ppa version again.
« Reply #12 on: July 27, 2018, 03:40:59 am »
Happy to report all working AOK now on the OBS PPA
« Last Edit: July 27, 2018, 04:14:38 am by zebedeeboss »
« Reply #13 on: July 27, 2018, 04:06:06 am »
Nice :)
Offline stevesveryown
  • Peppermint Fan
    • stevesveryown
« Reply #14 on: July 27, 2018, 06:40:47 am »
Zeb,
I don't think this was exclusive to amd. I was getting it on my desktop with nvidia graphics. I was trying to record gimp 2.10, snap version, in obs. I had closed obs and opened again and I was able to find the gimp window. When I do set for desktop recording I do get black screen.
Sent from my SM-T813 using Tapatalk
