Author Topic: Re: Trying to Get a Brother Printer to Print [Solved]  (Read 2117 times)
« Reply #15 on: July 28, 2018, 11:25:21 am »
If you're using the 64bit version of Peppermint 9, just download this file
https://code-industry.net/public/master-pdf-editor-5.0.36_qt5.amd64.deb
and double-click it to install.
Offline starchase
  • New Forum User, Old Old Forum User
« Reply #16 on: July 28, 2018, 02:00:47 pm »
Master PDF Editor looks like a great program, I installed the 32 bit version, but the screen on this netbook is small (1,024x600-pixel) and when I open the Print dialog box the actual "Print" button which I assume is at the bottom of the box, is not visible.  So that's not helpful.
« Last Edit: July 28, 2018, 02:04:58 pm by starchase »
Asus Eee PC 1025C, Intel Atom N2600 Dual Core 1.6GHz, 1GB DDR3, 320 GB HDD, Peppermint 9
Offline TonyBronze
  • Peppermintaholic
« Reply #17 on: July 28, 2018, 02:20:07 pm »
Hold down the alt key then left click on the box and drag it up.
« Reply #18 on: July 29, 2018, 08:30:30 am »
Hi starchase, I open all pdf files in libreoffice draw.
Offline starchase
« Reply #19 on: July 29, 2018, 09:48:53 am »
Thanks Tony!  That tip helps tremendously!!
And alynur, I installed Libre Draw and it does indeed open my pdf files.  When I get to work Wednesday I'll see how the print process works.  Thanks much!
« Reply #20 on: July 29, 2018, 01:54:44 pm »
If you download the .deb file from the link I provided, then double-click the .deb file, an application called gdebi will open and allow you to install the application at the click of a button.
Offline starchase
« Reply #21 on: July 31, 2018, 12:53:54 pm »
Yes sir it did, and it printed fine as well, thanks very much.  Being very new to Linux I wasn't familiar with installing programs by clicking by mouse rather than using the Terminal.  It is always fun to learn!
John
