Author Topic: Ubuntu Package Updates  (Read 1223 times)
Offline Fritz74
  • m, 46, Austria
« on: July 23, 2018, 12:21:27 pm »
Do Peppermint and other derivatives of Ubuntu keep an eye on the updates that are provided by Canonical? I had the impression that Mint and Peppermint had less stability issues than Xubuntu.
Re: Ubuntu Package Updates
« Reply #1 on: July 23, 2018, 12:36:42 pm »
Hi Fritz74,
What stability issues are you experiencing ?
Xubuntu has been rock solid for me since Beta 1 18.04
Offline Fritz74
  • m, 46, Austria
« Reply #2 on: July 23, 2018, 12:49:45 pm »
Just to be fair: It was only one issue two years ago with Xubuntu 16.04. Suddenly the volume changed by itself. I never found out why. As I NEVER had any issues with Mint Xfce or Peppermint, I probably got the premature impression that they are more stable than Xubuntu.
And today, when I was looking at sources.list, I was wondering if there are further checks of updates by derivative distributions. If not, the stability of everything based on Ubuntu would be the same, wouldn't it?
« Reply #3 on: July 23, 2018, 01:10:02 pm »
Ubuntu-based distros do rely on the upstream Ubuntu and Debian repos but each one is a combination of different packages so no two are going to behave exactly the same in practice.
« Reply #4 on: July 23, 2018, 01:18:24 pm »
Don't forget the secret sauce and 'go faster' candy stripes ;)
« Last Edit: July 23, 2018, 01:25:12 pm by PCNetSpec »
The PoorGuy
  • Guest
« Reply #5 on: July 23, 2018, 01:43:55 pm »
« Last Edit: August 27, 2018, 08:26:50 pm by The PoorGuy »
« Reply #6 on: July 23, 2018, 02:33:23 pm »
Yes, Peppermint has the Ubuntu repositories active by default, so anything that's installed that gets an update pushed through by Canonical gets updated in Peppermint as well.
