Author Topic: (Solved) What is the best virtual machine to run under Peppermint 5 ?  (Read 1397 times)
Offline jozefmw
My computer has an AMD 64bit processor.
The idea is to run Windows 7 in the virtual machine as i daily need some software
which would not run in Wine or  CrossOver
So what is the best virtual machine and most easy to install and to use?
Thank you for a hint.
Jozef
« Last Edit: July 26, 2014, 08:49:08 am by jozefmw »
Re: What is the best virtual machine to run under Peppermint 5 ?
« Reply #1 on: July 26, 2014, 06:47:15 am »
"Best" is speculative
Best in what way ?
KVM seems to be the quickest and easiest on system resources .. it'a also *probably* translates between the virtual and real hardware better as it's already part of the Linux kernel.
Feature rich would be a toss up between VirtaulBox and VMware, possibly with VirtualBox taking the edge
Out of those 2 VMware seems to take more resources to start a VM but less once it's running .. and VirtualBox is probably slightly easier to use.
All in all I'd probably pick VirtualBox (most of the time)....
